Huntmaster
Huntmaster
Ottawa, Canada
41 registered members (Alan_nc), 249 guests, and 473 spiders.
10257 Registered Users
Lannis 60
TBolt72 46
609,192 mail-order LSR
Topics67,120
Posts651,371
Members10,257
Page 2 of 14 1 2 3 4 13 14
Re: 66 T120R Project [Re: BobM] #274320
09/12/09 10:45 am
09/12/09 10:45 am
Christchurch NZ
R Moulding Online content OP
R Moulding  Online Content OP
Christchurch NZ
Hi Bob.
Unfortunately nothing much has happened. Had to lay of it for a bit after the clutch center in my TR6 fell to bits.
I have started stripping the engine but at the moment im just gathering some more cash so i can sort out some special tools and find me a tank.
Thanks for the interest,normal service will be restored soon.
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: 66 T120R Project [Re: R Moulding] #279569
10/18/09 4:51 am
10/18/09 4:51 am
Christchurch NZ
Christchurch NZ
So i got back on the T120R this week.
First job has been to finish mounting the side panel. I took templates of the missing mounting brackets from the TR6 and cut them from 16 gauge steel. I then mounted up the oil tank,straps and battery box with new rubbers to make sure i had everything in the right place. Then it was just a case of eyeballing it and comparing it to the TR6 till it sat right. Then i welded the brackets on.
The TR6R tank on the bike is the one it came with. Im currently prepping it for paint to put on my mates bike. If anyone has a slimeline tank spare id still be interested.
I have also had the instruments back from being overhauled. they came up nice
And i made a start pulling the engine down. Waiting on the crank pinion extractor to carry on.
Aside from the 60 thou over bores being worn and pistons having picked up,the worst thing i have found so far is
lots of pitting on the gearset. I'll work out what to do with this later.
So not much but hopefully enough to keep you guys amused.
Rod
Re: 66 T120R Project [Re: R Moulding] #279688
10/18/09 11:21 pm
10/18/09 11:21 pm
GrandPaul Offline
GrandPaul  Offline
Keep up the good work!
Re: 66 T120R Project [Re: GrandPaul] #280128
10/21/09 5:05 pm
10/21/09 5:05 pm
Yucca Valley, CA.
thebevman Offline
thebevman  Offline
Yucca Valley, CA.
Looking good. I hope you marked the timing pinions before you took them off though. Is that a home market tank? It looks a bit fat in the back. Looking good though.
'66 Bitsa Bonnie
Re: 66 T120R Project [Re: thebevman] #280129
10/21/09 5:12 pm
10/21/09 5:12 pm
Yucca Valley, CA.
thebevman Offline
thebevman  Offline
Yucca Valley, CA.
Red, don't forget the replace the Exh tappet metering rod behind the OPRV to a dowel. RF told me about it in a its explained in more detail in a Triumph Service Bulletin dated August 24, 1967. I found it on the net but cant remember where though.
I pulled mine upon RF telling me about this and good thing too it was chuck full of grit and other shit.
'66 Bitsa Bonnie
Re: 66 T120R Project [Re: thebevman] #280228
10/22/09 6:34 am
10/22/09 6:34 am
Christchurch NZ
Christchurch NZ
Cheers Bevman. I did mark the pinions. I'll have a look for the service bulletin ref the metering rod.
The tank is an export one. Its a 3.5 gallon from a 70 TR6R (still had some of the green and black paint). The home market is bigger again.
Rod
Re: 66 T120R Project [Re: R Moulding] #281845
10/31/09 8:11 pm
10/31/09 8:11 pm
Winona, MN
Swan Offline
Swan  Offline
Winona, MN
Redmoggy,
Very nice and keep up the good work and keep posting the progress and photos. I'll be following closely for I just picked up a 66 Bonneville project bike.
Swan
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: 66 T120R Project [Re: Swan] #285137
11/22/09 7:43 am
11/22/09 7:43 am
Christchurch NZ
Christchurch NZ
So been pottering around in the garage. The crank pinion extractor turned up so i got the cases split and the crank out. Main bearings are shot but cam bushes and cams look to be good. I also got the sludge trap all cleaned up and measured the crank journals. She has the origional light weight crank and is still on standard and within spec. Nice bit of good news! Also the big end shells were stamped with a Triumph part number so i am thinking im the first in here. Have started blasting the cases and have new bearings waiting.
Also had some high build mixed so got the oil tank and side panel primed guide coated and flatted. Will sort some black later.
You can see she still has the one year only oil tank,and the repairs to the side cover i think have come up real nice.
Thats about it for now.
Rod
Re: 66 T120R Project [Re: R Moulding] #286028
11/26/09 10:24 pm
11/26/09 10:24 pm
Wellington, NZ
kngkong Offline
kngkong  Offline
Wellington, NZ
Looking good Rod! She'll be running soon. I love the 66.
1951 5T Speedtwin
Re: 66 T120R Project [Re: kngkong] #334248
09/19/10 8:30 am
09/19/10 8:30 am
Christchurch NZ
Christchurch NZ
Not much going on. Got myself a re pop slim line tank to try out. Still rather an original but this will do for now.
Did manage to base coat the side cover and oil tank though. So dragged the frame up on the bench and mocked it all up to get the stickers placed before i clear coat them.....
Re: 66 T120R Project [Re: R Moulding] #334323
09/19/10 6:19 pm
09/19/10 6:19 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Rod,
Great work, and good pics too -- making for enjoyable reading! I notice that your garage shop stays spotless in spite of all the blasting and painting going on. Just wondering how you are protecting everything from overspray and stray blast media (especially the TR6, the car, and your finished pieces), and also what sort of breathing protection do you use for yourself?
Also, I see you are getting a lot of blasting done with only a 2.5 hp, 50 litre compressor. Do you have to wait much for it to catch up, or is it working out O.K. for you?
Finally, are you using a dust collector on your blast cabinet, or do you take it outdoors to set it up and use it?
I really need to get my own cabinet, but have no place for a permanent setup. It would still be easier to have my own cabinet on a shelf than to drive forty miles to a friend's house each time I have something to clean. Every time I think I'm all done bead blasting, I need to do some more, and have to beg another favor.
Although I don't have a blast cabinet, I do have that other essential piece of shop equipment shown in your pics -- the comfortable chair where I can sit, drink, stare, and generally ponder and meditate. This would be impossible to do without.
Carry on!
Oops! I posted this without realizing I had only read to the bottom of the first page. Hope what I asked you still makes sense. I'll proceed to read to the bottom now. What a rookie I am!
Re: 66 T120R Project [Re: R Moulding] #334325
09/19/10 6:39 pm
09/19/10 6:39 pm
Christchurch NZ
Christchurch NZ
Hi Ray
Photos can be deceiving. The garage is not always that clean,especially since i started painting for other people!
The little compressor copes really well on the small stuff. The frame was done elsewhere. For painting it has been ideal. You really need to take the cabinet outside to blast.
Over spray is a pain,mostly i use dust sheets and push everything else outside. Best advise would be to by the best gun you can afford. A good gun gives less bounce back or go for HVLP (High Volume Low Pressure) gun. Got a mask from the paint supplier.
There has been a delay with this since i broke the TR6. Its now in a corner covered in dust and over spray. Seeing your bike gave me a little inspiration to get back to working on them both!
Keep it up!
Re: 66 T120R Project [Re: R Moulding] #334345
09/19/10 9:05 pm
09/19/10 9:05 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Rod,
Thanks for the advice. I might go ahead and get a cheap cabinet and just figure on using it outdoors when I need it. The wife won't freak out as bad if I get a smaller compressor.
I'm not in the same league with you and most others on here, because I have farmed the hard stuff out (welding, plating, powder, and paint) but I guess everybody has to start somewhere. Even just doing the grunt work I sometimes feel like I'm pushing a bolder up a mountain. I'm still having fun though, and that's where it's at. I enjoy reading these project threads where you guys are doing it all yourself.
Good luck with the TR6 and the T120.
Re: 66 T120R Project [Re: R Moulding] #334387
09/20/10 6:28 am
09/20/10 6:28 am
Christchurch NZ
Christchurch NZ
Its all about the fun Ray,that and the steep learning curve.
As a side note,when you blast aluminum you open up the pores of the metal. If the part is staying in bare finish its an ideal time to drench it in a penetrating oil and leave it to soak in. I've done this on lots of parts and it helps to prevent the metal oxidizing.
All the best
Rod
Re: 66 T120R Project [Re: R Moulding] #352645
01/12/11 2:12 am
01/12/11 2:12 am
Christchurch NZ
Christchurch NZ
Well im off work for a while after my little mishap so time to do some proper work!
While i wait for some bearings for the TR6 i thought i would play with the Bonnie tank. Firstly a couple things about this paint scheme. It is for a start my favourite and the reason i wanted a 66 T120R. I have also seen a lot that have been done kinda wrong. For a start Grenadier red is a solid colour not a candy or a metallic. Also unlike later schemes with a central 'racing' stripe,the stripe tapers in at the front and rear of the tank. This stops the flanking stripes from rolling round the front of the tank.
So you can see in the earlier pics i have a re pop tank,that got about 6 coats of high build 2K primer before being guide coated and block sanded. This ensured that all the stretch marks in the steel were smoothed out. I gave it four coats of Alaskan white base coat,let that dry over night and flatted it with 800 wet and dry.Then spent some time marking out the stripes.
I use 3M blue fine line tape,its expensive but leaves a nice crist line. You can clearly see the taper in the central stripe. I then masked her up. News paper is not ideal but works well enough if you are not using dies.
With it all masked i gave the exposed white paint a thorough clean with panel prep,blew her of with an air line and got some red laid down. Basically the idea is to start with a mist coat or grip coat,this is rough enough to allow subsequent coats to cling. I then add two more coats to build it up.
Couldn't resist resting it back on the frame! In a day or two i will key it in and clear coat it ready for the gold. Hopefully get the oil tank and side cover done as well.
Rod
Re: 66 T120R Project [Re: R Moulding] #355766
01/31/11 4:24 am
01/31/11 4:24 am
British Columbia, Canada
Steve P Offline
Steve P  Offline
Great Job Redmoggy. I'm inspired, albeit lightyears behind in skill set.
Re: 66 T120R Project [Re: R Moulding] #355818
01/31/11 2:43 pm
01/31/11 2:43 pm
GrandPaul Offline
GrandPaul  Offline
Great to see your 3 month delay is over with.
Re: 66 T120R Project [Re: GrandPaul] #357548
02/10/11 11:06 pm
02/10/11 11:06 pm
Christchurch NZ
Christchurch NZ
Still waiting for the TR6 Barrels to come back so back to this tank for a bit this morning.
Now generally speaking white is very forgiving. However soon as you add a second colour and start thinking about a clear coat you have to be really careful. The finish on base coat is generally rough and you want at least an 800 grit sanded finish for the clear to cling. The problem comes when you sand the second colour,that coloured water clings to the surface tinting the white. This means lots of effort to ensure everything is spotless or its going to show up. You could also clear coat the white first,but this brings more problems as the clear is actually opaque and you risk turning the white yellow.
Anyhow, lots of cleaning and panel wipe later and i mixed some clear. Simple 2-1 with no thinner as the finish at this point is not important.
This is basically a sacrificial coat,in a day or two Iíll flat it with 800 wet and dry to smooth out the paint lines. That stops me having a sharp line through my pin stripe. And can then stripe it and clear it again.
Re: 66 T120R Project [Re: R Moulding] #357574
02/11/11 2:01 am
02/11/11 2:01 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
That is beautiful work. The lines look perfectly symmetrical to me. I can't imagine doing that, even with some kind of template.
Re: 66 T120R Project [Re: R Moulding] #357601
02/11/11 6:01 am
02/11/11 6:01 am
Christchurch NZ
Christchurch NZ
I had similar thoughts when i looked into it. I was trying to gauge how much the central stripe bowes out in the middle. Normally the stripe is the width of the rear mounting tag and straight up and down.. After a bit of research i found Rask cycles site. They have pictures and marking out advise for Bonnie paint schemes. Its not an exact science, and was a bit of a challenge, but not as hard as it looks.
I did spend some time in the chair with a beer or two staring though. I'm pretty happy how it looks at the moment.
Re: 66 T120R Project [Re: R Moulding] #357649
02/11/11 3:30 pm
02/11/11 3:30 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
So if it isn't as hard as it looks, how do you do it with only two hands? Did you have someone holding a scale for you while you were taping? Is it all by eyeball only? I see stuff like this, but still don't believe it. How many attempts with the tape before you were happy with it?
Re: 66 T120R Project [Re: R Moulding] #357684
02/11/11 7:38 pm
02/11/11 7:38 pm
Christchurch NZ
Christchurch NZ
Nah not so bad. With this one, centre stripe is 2" wide at the mounting tab and at the front of the tank. So use the centre rib as a datum and mark an inch either side with a chino-graph pencil. About an inch below the filler it should widen out to 2 3/4", so another mark. At the seat nose we want 2 1/2" so same again. Fine line tape is nice and flexible so we can use it to make the curved line following the marks. Now eyeball and adjust until they look right.
The outer stripes are 3/8" away from the inner and 3/8" wide. So mark 3/8" either side of the central stripe, i put a mark every inch or so and run more tape. Same again and your done. Now just eyeball till your happy with it.
Took a couple attempts to get it right around the mounting tab and now the paints on, one side looks a little wrong. But there is some room for adjustment when i put the stripe down.
Now i did a Hinkley tank, the guy wanted a 78 T140 scheme. This has to scallops from the badge back to a point at the seat base. It then has an 8th" double pin stripe. That was a nightmare!!
Re: 66 T120R Project [Re: R Moulding] #357731
02/12/11 12:52 am
02/12/11 12:52 am
Westminster, MD, USA
J. Charles Smith Offline
How do you think Hinkley does it at the factory? Is it maybe done by machine, like by a computer-controlled pinstriper?
Re: 66 T120R Project [Re: R Moulding] #357850
02/12/11 7:48 pm
02/12/11 7:48 pm
Christchurch NZ
Christchurch NZ
According to the sales literature Hinkley line there tank by hand.
Re: 66 T120R Project [Re: R Moulding] #357923
02/13/11 2:55 am
02/13/11 2:55 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Rod, finish your tank like this guy at the Enfield Factory. Report back and let us know how it went.
http://www.youtube.com/watch?v=G9wUc8rpBhc&feature=player_embedded
