YankeeJerry
YankeeJerry
Connecticut
25 registered members (Al Eckstadt), 195 guests, and 443 spiders.
10257 Registered Users
Stuart 75
Lannis 56
610,370 mail-order LSR
Topics67,139
Posts651,527
Members10,257
A65 Clutch Adjustment #35669
03/04/08 12:21 am
03/04/08 12:21 am
Carmel, CA
Doc_dup1 Offline OP
Doc_dup1  Offline OP
Carmel, CA
My 66 Spitfire clutch was slipping a bit on acceleration so I changed the clutch. I replaced all of the plates and I installed a new MAP cover plate. It is better now, but it still slips. I went back and rechecked everything and I can't find anything wrong except that it still slips. The only thing that I can think of at this point is to go back in and tighten the clutch cover plate screws a few more turns. Does that sound like a good plan? Thanks, Doc
Doc
Mostly Triumphs with a few BSA's a Norton, and two BMW's
Re: A65 Clutch Adjustment #35670
03/04/08 12:57 am
03/04/08 12:57 am
Christchurch, NZ
Kevin (NZ). Offline
Kevin (NZ).  Offline
Christchurch, NZ
Check to ensure you have slack on the pushrod first. Then slack at the lever second.
If it is not an adjustment issue then chances are it will be in the clutch itself somewhere.
Seems strange to have to same problem after changing the pack,- I would be having a really good look at the rigging.
How does the clutch lever action feel ?
All the best with it..
Why, Y, Dash Y..
Re: A65 Clutch Adjustment #35671
03/04/08 12:58 am
03/04/08 12:58 am
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
first thing I would check is that you have a bit of free play in the push rod mechanism (when the clutch is out) ..you can tighten the springs all you want but if there is no clearance in the push rod you will be wasting your time, first things first
Re: A65 Clutch Adjustment #35672
03/04/08 2:38 am
03/04/08 2:38 am
Carmel, CA
Doc_dup1 Offline OP
Doc_dup1  Offline OP
Carmel, CA
I did adjust the center nut on the cover plate using the instructions that came from MAP. They said to tighten it down until the free play is gone and then back it off. Perhaps I should back it out a bit more. The lever does have free play and the action feels fine.
Doc
Re: A65 Clutch Adjustment #35673
03/04/08 3:25 am
03/04/08 3:25 am
Smurdley Offline
Smurdley  Offline
Dead springs?
OVBSAOC #4062
1968 BSA A65L Lightning
2005 Triumph Bonneville
Re: A65 Clutch Adjustment #35674
03/04/08 1:25 pm
03/04/08 1:25 pm
the dungeon, in N.W. Ohio
Mitch C. Offline
Mitch C.  Offline
I had to replace the springs in my 69 lightning after it started to slip some even after new clutch, and plates. If I read the book right a free spring is suppose to be 1-13/16" long. The springs are easy to get, and aren't that expensive. Good luck!
Re: A65 Clutch Adjustment #35675
03/04/08 3:34 pm
03/04/08 3:34 pm
gavin eisler Offline
Worn cush drive rubbers, spider and end plates allow the clutch to tilt under load.
Polished and warped plain plates.
Combimation of the above.
Pod
Re: A65 Clutch Adjustment #35676
03/04/08 7:40 pm
03/04/08 7:40 pm
Carmel, CA
Doc_dup1 Offline OP
Doc_dup1  Offline OP
Carmel, CA
I did not check the springs. I'll pull them and measure the length. Thanks
Doc
Re: A65 Clutch Adjustment #35677
03/06/08 3:41 pm
03/06/08 3:41 pm
Carmel, CA
Doc_dup1 Offline OP
Doc_dup1  Offline OP
Carmel, CA
When I looked at my clutch spring screws, they were not very even. two of them had much more thread showing that the third one. I pulled the springs out and they measured 1 13/16 inches long as the book said. I put the whole thing back together and again, I need to have two of the screws tighter than the third to get everything to even when I engage the clutch. I am guessing that one of the springs must be weak in some way. I tried adjusting the screws to different points, riding the bike after each adjustment. I was amazed at how sensitive those little buggers are, but everything seems to be fine now. Thanks for the advice. Doc
Doc
