elchacal
elchacal
Martha's Vineyard
17 registered members (ChrisX), 156 guests, and 459 spiders.
MikeA, Jay Gilling, scratchedtank, Magic Monkey, Hybris
10252 Registered Users
Lannis 64
NickL 48
606,416 mail-order LSR
Topics67,080
Posts650,911
Members10,252
70 T120R flywheel confusion #331416
09/03/10 3:56 am
09/03/10 3:56 am
Columbus, OH. USA
shrugger Offline OP
shrugger  Offline OP
Columbus, OH. USA
To make a long story short. I'm pretty sure The machinist ruined
my crankshaft flywheel with a lot of large holes and a 50%
balance. mad
So I've been looking for another. The problem is the severely
confusing part numbers for them. My parts book has the early
numbers and it's E9687 However, the number stamped into it is 70-9745
Poor Trevor over at Britishonly has found several that look
identical. But every one of them has a different part number.
Hopefully, someone can help clarify this unruly number mess.
"Thanks to denial, I'm immortal" -Phillip J. Fry
Re: 70 T120R flywheel confusion [Re: shrugger] #331446
09/03/10 12:48 pm
09/03/10 12:48 pm
JubeePrince Offline
JubeePrince  Offline
WTF!?
Hopefully you can get your "machinist" to pay for the new flywheel...
Part number should transpose to 70-9687. These flywheels were used late '69 - '70.
I know that there are lighter flywheels available out there.....your "machinist's" work not withstanding, perhaps you have the lighter version (70-9745).
AFAIK, the consensus seems to be the heavier the flywheel the better.
HTH,
Re: 70 T120R flywheel confusion [Re: JubeePrince] #331453
09/03/10 1:58 pm
09/03/10 1:58 pm
Columbus, OH. USA
shrugger Offline OP
shrugger  Offline OP
Columbus, OH. USA
I kinda had a feeling the numbers might be different weight ranges.
So likely any number that falls between the parts book and my flywheel
will probly work fine.
Anyone got a 69 book to look up that part number?
I could have a leftover as the bike was built first production month. August 69
Re: 70 T120R flywheel confusion [Re: shrugger] #331458
09/03/10 2:17 pm
09/03/10 2:17 pm
A fellow here in Holland posted pictures allmost similar to yours, Shrugger. The job was done in the UK and he was very content with the result.
Re: 70 T120R flywheel confusion [Re: Ger B] #331461
09/03/10 2:32 pm
09/03/10 2:32 pm
Columbus, OH. USA
shrugger Offline OP
shrugger  Offline OP
Columbus, OH. USA
I'll never be comfortable riding the bike with this flywheel.
The thought of a hand grenade that could go off at any time
would always be on my mind. shocked
Re: 70 T120R flywheel confusion [Re: shrugger] #331462
09/03/10 2:32 pm
09/03/10 2:32 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
'66-'68 had light flywheels ,they'll shake you teeth out at high speed.The flywheel is visibly different,about 2-1/2 lbs lighter.
'69-'70 was more comfortable with a heavier flywheel.
I've got a feeling they got heavier after that,but at some time the inner diameter changed and got bigger.'71-'72 has a different part number and I'm not sure if that will fit,maybe too big.
Re: 70 T120R flywheel confusion [Re: shrugger] #331465
09/03/10 2:44 pm
09/03/10 2:44 pm
GrandPaul Offline
GrandPaul  Offline
Shrugger-
I don't believe the casting numbers have anything to do with the actual Triumph part numbers. At least, that's typically the case with almost any other part on the bike. Why? Heck if I know; "because THAT'S why"!
I've seen cranks drilled a lot worse than that, and made negative comments along the lines of your post, then got excoriated for being such a numbskull and not knowing what I was talking about (okay, sure).
Heavy -vs- light flywheels both have thier plusses and minuses. A heavy flywheel makes for a more stable idle and smoother torque delivery (an object in motion tends to stay in motion, and all that). A light flywheel builds revs quicker (some racing disciplines want that).
OEM flywheels are easy to differentiate:
Heavy - same width all the way around the edges
Light - wide at the "bottom", narrower at the "top".
Re: 70 T120R flywheel confusion [Re: GrandPaul] #331469
09/03/10 2:53 pm
09/03/10 2:53 pm
Columbus, OH. USA
shrugger Offline OP
shrugger  Offline OP
Columbus, OH. USA
LOL.
Guess I'll have Trevor pick one at random. Then I'll send it to
you so your guy can go over it properly.
Re: 70 T120R flywheel confusion [Re: shrugger] #354717
01/25/11 3:39 am
01/25/11 3:39 am
florida
big head Offline
big head  Offline
florida
Gents,
Resurrecting this old post: while at the machinist its determined my crank ('66 t120) is no longer good. So they go and replace it with the later (heavier) '69 crank.
Questions:
- should i be concerned or will this crank run fine in my '66?
- am i going to have any power loss? I did have the head completely redone, .40 jugs, new pistons, etc.
- It seems I will benefit from less vibrations?
Thanks for any info.
1968 T-120 (In progress)
Re: 70 T120R flywheel confusion [Re: big head] #354733
01/25/11 5:19 am
01/25/11 5:19 am
Vic. Australia
Vic. Australia
Don't be concerned;be thankful! You'll still make the same power at the crankshaft.
In the low gears you'll notice a little less acelleration and engine braking,like as if you added 30 lbs weight to the bike.In top gear,I doubt that you'd notice it (like about 1 % difference).
The cush-drive,clutch,and other transmission parts will have an easier life;not much,but a little.
The engine will idle smoother.
You will notice less vibration.Your crankshaft will be happy.
If you're still using '66 rods ('69 rods are better and heavier),check the balance factor.If its not more than 85%,don't change it.
Last edited by Pete R; 01/25/11 5:39 am. Reason: "If you're - - - don't change it."
Re: 70 T120R flywheel confusion [Re: shrugger] #354758
01/25/11 12:18 pm
01/25/11 12:18 pm
florida
big head Offline
big head  Offline
florida
Yes, forgot to add, new Rods as well and the Crank was Balanced to specs. Considering I'm doing a complete rebuild, the vast difference in performance will be very noticeable regardless. (i hope).
Thanks for the info...
Re: 70 T120R flywheel confusion [Re: shrugger] #354760
01/25/11 12:32 pm
01/25/11 12:32 pm
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
I'm with Pete,I wouldn't worry a bit about the flywneel exploding.I also have seen worse. The only thing I would be a BIT concerned with, is the 50% balance factor,however,if the crank was dynamically balanced,which I doubt,because it appears the neither web has any sign of balance work,I doubt that you could notice a problem. Dick
Re: 70 T120R flywheel confusion [Re: shrugger] #354768
01/25/11 1:25 pm
01/25/11 1:25 pm
florida
big head Offline
big head  Offline
florida
by the way that crank pictured is not mine...I just brought up the question of the different cranks from '66 to '69. My '66 crank was no good and was replaced with the heavier '69.
thanks
Re: 70 T120R flywheel confusion [Re: shrugger] #354782
01/25/11 2:49 pm
01/25/11 2:49 pm
kommando Offline
kommando  Offline
I have just done same as an upgrade (well its a 65 so I just put it back to being heavy), next task is to get it static and then dynamically balanced.
Re: 70 T120R flywheel confusion [Re: shrugger] #354809
01/25/11 5:33 pm
01/25/11 5:33 pm
albion New York
charlie akey Offline
albion New York
Parts book 1969 e9686 (70-9686) crankshaft assembly .British cycle ref . you to 71-2600 crankshaft assembly . Charlie
