C.B.S
C.B.S
Lancaster, California
34 registered members (21inGoldie), 219 guests, and 356 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,628 mail-order LSR
Topics68,845
Posts670,611
Members10,478
51 GF wiring #35370
02/26/08 7:07 am
02/26/08 7:07 am
Lake Conjola NSW Australia
pooch Offline OP
pooch  Offline OP
Can anyone point me to a wiring diagram for a 51 golden flash.
In particular, the wiring on a repo Lucas style headlight switch.
Haynes and other info I have does not show any detail on what the click on off rocker on top of switch with a plug terminal attachment does.
56 B31 with B33 barrel
51 Golden Flash with Dusting sidecar
Re: 51 GF wiring #35371
02/26/08 3:00 pm
02/26/08 3:00 pm
Re: 51 GF wiring #35372
02/27/08 9:04 am
02/27/08 9:04 am
BSA_WM20 Offline
BSA_WM20  Offline
That is probably because BSA did not fit this variation of the switch, to A7/10s as far as I know any way.
Power in goes to the post with the nut on it.
The next closest gets the pilot globe.
The one next to that gets the tail lamp & instruments.
The 3rd gets the feed to the dip switch.
Me thinks that rockers on the top were used with alternator bikes to switch in & out power coils prior to the zenner so it might actually be correct for a ceefer
Re: 51 GF wiring #35373
02/27/08 5:55 pm
02/27/08 5:55 pm
pooch Offline OP
pooch  Offline OP
Alex, thanks, I have 2 other diagrams here, but they were useless.
Yours works with my switch.
Trevor, the power cannot go into the nut, as , if the pilot was next around, it would be on all the time.
To simplify the diagram, seeing there is no 6 pin on the repo switch, forget 6 and 7 and just put snap connectors in place direct to headlamp filaments.
6 and 7 do nothing but join the wires together.
Trevor, I think you are right, the rocker is for alternator models.
In this diagram, why is the switch wiring shown different, even though it says swinging arm model?
The switches I have on the SA and plunger only have 3 ways, off/low/high.
In a normal 3 way switch, off is between 4 and 5, so how does the tail light/speedo work when headlight is on?
It seems, this diagram would be correct if the bridge was to 5 and not 6.
Re: 51 GF wiring #35374
02/27/08 11:56 pm
02/27/08 11:56 pm
BSA_WM20 Offline
BSA_WM20  Offline
If the ball is bridging the post with the nut on it & the next terminal, then move the connections around one place.
The set up is still the same, pilot + tail & instruments ( no head lamp ) then tail & instruments + headlamp ( no pilot ).
If you want to do away with the dip switch & don't mind having the pilot lamp on with the head lamp you can join the instruments, pilot & tail lamp all together on one post, put the low beam on the post before it & the high beam on the post after it
Re: 51 GF wiring #35375
02/28/08 5:23 am
02/28/08 5:23 am
pooch Offline OP
pooch  Offline OP
If the next post to nut is skipped, then the pilot light will be on both low and high.
