Denis J
Denis J
Sacramento, CA
20 registered members (Adam M.), 215 guests, and 412 spiders.
10418 Registered Users
btour 89
Triless 78
reverb 76
710,145 mail-order LSR
Topics68,304
Posts665,017
Members10,418
4 speed transmission interchangability #345590
11/29/10 3:36 am
11/29/10 3:36 am
Ontario , Canada
peter berry Offline OP
Ontario , Canada
I am looking at a complete 4 speed transmission , layshaft & main shaft with gears . Are they interchangable between all 650 unit twins or are they specific to years Thanks Peter
76 T140
66 TR6 project
Re: 4 speed transmission interchangability [Re: peter berry] #345807
11/30/10 8:09 pm
11/30/10 8:09 pm
Ontario , Canada
Ontario , Canada
Any body have any idea on this would be greatly appreciated , cant find anything specific in the archives Thanks again Peter
Re: 4 speed transmission interchangability [Re: peter berry] #345822
11/30/10 9:19 pm
11/30/10 9:19 pm
John Healy Offline
John Healy  Offline
As a donor set, all bits from a single motorcycle, they are interchangeable from 1964 (1963 has a different high gear spline) to 1970. 1971-72 can also be used with a bit of thought, again you want a set of gears from a single donor motorcycle.
There were changes in the diameters of the shafts and gears, some were made by BSA to a different standard than Triumph used, and you need to be a wiz kid to sort out an odd set of 4 speed gears and shafts. It can be done, but some experience required.
Re: 4 speed transmission interchangability [Re: peter berry] #345823
11/30/10 9:24 pm
11/30/10 9:24 pm
John: Does any of the above rational apply to the mixing and matching of unit T100 gears sets between the years, either complete sets or odd gears?
Re: 4 speed transmission interchangability [Re: Gordo in Comox] #345828
11/30/10 9:47 pm
11/30/10 9:47 pm
Ontario , Canada
Ontario , Canada
Thanks , Im looking at a complete matched 4 speed set not sure what year Peter
Re: 4 speed transmission interchangability [Re: peter berry] #345839
12/01/10 12:36 am
12/01/10 12:36 am
John Healy Offline
John Healy  Offline
Gordo:
There does not seem to be the same situation with the 500 gear sets. To my knowledge all of the 500 gears and shafts were all made in Meriden using the Triumph standard for shafts diameters and gear bores.
There is a Wall Poster based upon some work done by Jack Shortland, US export parts manager, and a couple of others. It illustrates both the BSA and Triumph standards and gives dimensions. It also has an interchange which in theory was intended to allow you to identify alternate gears, but as Jack confided to me that even they could not sort all of this out and the chart was their "best guess".
I am sure some one can post the dimensions which should help people identify compatible gears and shafts.
Re: 4 speed transmission interchangability [Re: peter berry] #345871
12/01/10 6:46 am
12/01/10 6:46 am
Thanks John.
Re: 4 speed transmission interchangability [Re: peter berry] #345887
12/01/10 9:15 am
12/01/10 9:15 am
dave jones Offline
dave jones  Offline
Peter- The only things I can think of that would be of any use is that in 1968 the clutch oil seal changed in size to run on the high gear itself rather than the high gear bush. Not sure if you need the whole plate behind the clutch to go with this or if you can use the same one. The other thing is that early machines require the speedo to be driven from the gearbox and early gearsets are designed for this. Otherwise, as John Healy says, you can put any four speed set in.
Don't know if you can put a four speed in five speed cases.
Re: 4 speed transmission interchangability [Re: dave jones] #346071
12/02/10 5:32 am
12/02/10 5:32 am
Goldendale, Washington
4
40 Below! Offline
40 Below!  Offline
Yes, you can put a 4spd in a 5 spd case.
"Growing old is obligatory - growing up is optional"
2015 HD Geezer Glide
85 Sportster Rocket Ship
69 Sportster resto project
66 TR6SR(750 tracker)
?? TR25 tracker
67 441 resto project
Re: 4 speed transmission interchangability [Re: 40 Below!] #346076
12/02/10 8:04 am
12/02/10 8:04 am
redondo beach, ca
Bob G Offline
Bob G  Offline
redondo beach, ca
I seem to remember the old Glenn's Triumph manual had a very detailed chart that showed gear and shaft interchangeability (with part numbers) between the different years.
Thia would be a great help for anyone trying to mix and match transmission parts.
Bob Gregor
Re: 4 speed transmission interchangability [Re: Bob G] #346098
12/02/10 12:19 pm
12/02/10 12:19 pm
Ontario , Canada
Ontario , Canada
I think I have an old Glens lying around I will take a look Thanks
