654cc
654cc
San Francisco Ca
203 registered members (68 royalstar tony), 1,685 guests, and 579 spiders.
10036 Registered Users
Lannis 146
kommando 109
478,176 mail-order LSR
Topics65,736
Posts635,448
Members10,036
BSA M20 Gearbox Help Request #34268
02/04/08 12:38 pm
02/04/08 12:38 pm
Houston Texas
Britbodger R.I.P. Offline OP
Houston Texas
A friend of mine's (yes - I does has friends RicB :p )M20 is sitting dormant because of gearbox problems. He would love to get it back on the road so I said would ask the BSA experts who resides on this board.
Unfortunately don't know the specifics of the problem but, for starters anyway, wondered whether the M20 shares the same gearbox internals as other Beeza's.
Any help/advice would be much appreciated.
Thanks in advance
Re: BSA M20 Gearbox Help Request #34269
02/04/08 1:27 pm
02/04/08 1:27 pm
The land of pleasant living
Z
Zimm Offline
Zimm  Offline
Z
Bodger:
Before he gets too deep into the box, make sure the clutch is spot on, unless absolutely sure the problem is in the box. Mine will fail to downshift if the clutch isn't right.
Getting it right includes making sure there is full movement of the clutch rod. Little stuff like the lower adjustment matters. Mine had wear in the clutch lever fulcrum point. Once I made a little bushing and installed it, it worked a lot better.
Zimm
Re: BSA M20 Gearbox Help Request #34270
02/04/08 1:41 pm
02/04/08 1:41 pm
Malcom, while the M20 box is very similar to the B31/B33/A/A10 box, the internals do not interchange. Still, M20 boxes and spares are not exactly rare, having been used on the vast quantities of WM20 as well as M33's, M21's and not quite as common M23&24.
Nice thing, though, they are dead-*** simple and very rugged in all areas except perhaps the cases, which seem to get broken a lot.
Re: BSA M20 Gearbox Help Request #34271
02/04/08 2:14 pm
02/04/08 2:14 pm
Houston Texas
Houston Texas
Thanks Zimm, but think his problems go deeper than the clutch.
And thanks for the info on the internals Alex. Now I'll start looking for source of parts once I find out what he needs.
BTW, he is a local flattracker and has a really nice Trackmaster BSA twin (amongst his huge collection of British and other bikes) that he races from time to time. Will try and post a photo when I get home.
Re: BSA M20 Gearbox Help Request #34272
02/04/08 3:34 pm
02/04/08 3:34 pm
Oooh, yea. Bodger, Domiracer will prolly have everything you need. If they don't, Draganfly certainly will.
Mmmm, trackmster.
Cheers.
Re: BSA M20 Gearbox Help Request #34273
02/04/08 5:04 pm
02/04/08 5:04 pm
Pat Offline
Pat  Offline
I have a spare BSA 4speed trany, casting no. AM 65-3394. One of the guru's will tell us if it's an M20 one.
Re: BSA M20 Gearbox Help Request #34274
02/04/08 5:23 pm
02/04/08 5:23 pm
Houston Texas
Houston Texas
Thanks Alex and Pat for the additional info bigt .
Pat,
Any idea what you want for the gearbox if it is the correct one?
P.S. Hope to see Dave Valden (the guy with the M20) this weekend and will pass on the info.
Re: BSA M20 Gearbox Help Request #34275
02/05/08 3:45 pm
02/05/08 3:45 pm
Pat Offline
Pat  Offline
I'd like $80 plus shipping for the tranny. First gears are worn but everything else is good. Comes with the clutch, worn but the plates are there.
Re: BSA M20 Gearbox Help Request #34276
02/05/08 6:44 pm
02/05/08 6:44 pm
Pat, you can identify the box by the fact that the clutch actuation lever is attached to the center of the outside cover on M-20 gearboxes. Somewhere around the end of the war they changed the lever to rotating a shaft coming in the top center of the cover inside a banjo-shaped smaller casting. This later type was also used on rigid and plunger B-series bikes. Later B and A-series boxes have a rotating shaft coming directly into the top of the cover near its joining face with the inner cover.
And speaking of which, I forgot about the plunger and rigid B-series, which used essentially the same box as the M-20 but with different ratios. Many parts from one of those boxes could interchange...but the gears themselves are different.
Cheers.
Re: BSA M20 Gearbox Help Request #34277
02/05/08 7:25 pm
02/05/08 7:25 pm
Pat Offline
Pat  Offline
Thanks Alex. Had to go look at pics to check your meaning but see that my tranny is the later type with the clutch arm on the top of the side cover. There is a no.8 stamped on the tranny case, top left side above the sprocket, does this give any indication as to model, ratio, etc? Won't fit my C10 anyhow!
