Mike-71-650
Mike-71-650
Al, Birmingham
194 registered members (79T140E), 2,144 guests, and 586 spiders.
koan58 90
Lannis 88
NickL 86
505,871 mail-order LSR
Topics66,065
Posts639,435
Improving Front Wheel Brakeing on a Brit #341762
11/06/10 10:38 pm
11/06/10 10:38 pm
South London UK
Sgt:Woodie Offline OP
South London UK
Single leading shoe brakes on some Brit Machines leave much to be desired. I have tried for over 50 years to improve my front brake on my BSA C12, I therefore had to smile at this I found on a site dedicated to the problem. I quote
from adealers mechanic. One of the local bikes is an Ariel Leader. The owner has fitted electric starting and a twin leading shoe front brake with much trial and error on the way.
1 longer operating arm This made the brake better but not much
2 floating brake shoes {the locating curve on the brake anchor is removed to allow the shoes to centralise ) , again a slight improvement
3 Two brake cams expanding the brakes at both ends, not recommended, no better than standard
4 Two cams with the trailing lobes removed , this used floating shoes , worked well but was slow releasing
5 Twin cams as above but with the locating curve retained though reduced to locate on the removed section of the brake cams. This was my suggestion and I have not seen him since, I blame the weather. Woodie
Re: Improving Front Wheel Brakeing on a Brit [Re: Sgt:Woodie] #341780
11/07/10 12:00 am
11/07/10 12:00 am
I wouln't try two cams on a single leading shoe braking. The consequences could be drastic. There is too much flex in those backing plates leading to a bit of servo action. Not good. I did try carbon fiber shoes once and it was basically a revelation. Slow to warm up, but once warmed up was just as good as a well set-up TLS brake. Vintage car racers use this stuff.
Re: Improving Front Wheel Brakeing on a Brit [Re: Sgt:Woodie] #341807
11/07/10 3:08 am
11/07/10 3:08 am
BC Canada
441/R3cafeSteve Offline
BC Canada
I prefer the clunky 8" TLS over conical still for looks and ease of adjustment. They look better made as well the conical always looked sort of plastic to me.
Re: Improving Front Wheel Brakeing on a Brit [Re: ] #341823
11/07/10 5:26 am
11/07/10 5:26 am
Originally Posted By: BenG
He made the brake so that the brake cam was free to move fore and aft in a slightly oval hole in the backing plate.
Is there any sort of spring mechanism to return the cam to the centre of the oval hole when you release the brake?
Re: Improving Front Wheel Brakeing on a Brit [Re: 441/R3cafeSteve] #341848
11/07/10 10:40 am
11/07/10 10:40 am
Peter R Online content
Peter R  Online Content
IMHO,the conical brake is a good stopper, these brakes can be improved by fitting longer brake lever arms. Even on a relatively heavy bike like my Trident, this brake works fine.
Re: Improving Front Wheel Brakeing on a Brit [Re: Sgt:Woodie] #341863
11/07/10 1:02 pm
11/07/10 1:02 pm
Kent
KarlB Offline
KarlB  Offline
Kent
Or just swap it for a Honda CB175 TLS brake, that works... smile
KarlB
Big day has come and gone and still no idea what Project 50 will be!
Re: Improving Front Wheel Brakeing on a Brit [Re: Sgt:Woodie] #341868
11/07/10 1:22 pm
11/07/10 1:22 pm
Kent
KarlB Offline
KarlB  Offline
Kent
Or you could find one of these rather good double sided SLS brakes that came on Ducatis etc...
KarlB
Page Time: 1.724s Queries: 15 (0.046s) Memory: 1.0348 MB (Peak: 1.2053 MB) Zlib disabled. Server Time: 2018-02-25 18:02:21 UTC
