The Bonneville Shop
Shadrach
Shadrach
Maryland
39 registered members (Adam M.), 244 guests, and 440 spiders.
10528 Registered Users
franko 90
NickL 66
785,221 mail-order LSR
Topics69,221
Posts674,282
Members10,528
1971 A65 OIF Lightning Frame number #24828
05/14/07 7:56 pm
05/14/07 7:56 pm
South Wales
U
UNF Offline OP
UNF  Offline OP
U
South Wales
I have recently acquired a 1971 A65 Oil-in-Frame Lightning (originally grey frame then painted over with yellow and then black!), which is in reasonable condition mechanically but will require cosmetic rebuild.
The engine number, which I believe to be a 1970 to 71 unit, is A65L/JE12838. The frame unfortunately, does not have an ident in the specified place i.e. left side of the steering head, all that I can find is a single X stamped on the steering head, albeit rather vaguely.
Can anyone offer any advise as to whether the frame number is stamped elsewhere on the bike for that year, or that it may never have been stamped at all?
Thanks.
'71 BSA A65 Lightning
Re: 1971 A65 OIF Lightning Frame number #24829
05/14/07 9:18 pm
05/14/07 9:18 pm
JE in your engine number means 1971.
Is your frame number hidden underneath layers of paint? The location should be left side of the steering head. At least that's where mine is ('71 OIF A65T).
Re: 1971 A65 OIF Lightning Frame number #24830
05/15/07 5:54 pm
05/15/07 5:54 pm
[img]http://www.mijnalbum.nl/Foto=BDJIO7VY[/img]
I just took a picture of mine. It's in the red oval but I would have to chip the paint away to read it. But it's there.
Hope this helps.
Re: 1971 A65 OIF Lightning Frame number #24831
05/16/07 9:44 pm
05/16/07 9:44 pm
South Wales
U
UNF Offline OP
UNF  Offline OP
U
South Wales
Thanks for your help Ger.
I've now removed the paint from the area where the number should be (see image below), unfortunately there was no number to be seen.
But at least the engine is stamped correctly!
Andy
Re: 1971 A65 OIF Lightning Frame number #24832
05/16/07 11:46 pm
05/16/07 11:46 pm
With the bike out of the shed, earlier this evening, I could read it reasonbly. So where yours is...
I haven't got a clue.
Someone else maybe?
Re: 1971 A65 OIF Lightning Frame number #24833
05/17/07 9:59 pm
05/17/07 9:59 pm
Toledo, OH USA
M.O.Ther Offline
M.O.Ther  Offline
Toledo, OH USA
I had a '72 A65T with the same problem. Since it was apart I chemically stripped the paint from the frame where I thought the number should be (so as not to obliterate and traces of grinding or sanding if that had occurred.) I found no trace of tampering, no thinning of the metal, and no numbers.
I did learn that quite a few of these frames had been replaced in warranty by dealers for leak problems where the swingarm pivot connects to the frame spine. The dealers were then supposed to re stamp the frames, but that didn't always happen.
I dont know how the law treats it where you live, but it seems to me if you had the right stamps, you'd just be finishing up the service work the dealer should have performed. No alteration and no intent to defraud.
M.O.Ther
Assorted Harleys
Pre Unit Triumphs
Unit BSA twins
and a Matchless Pinto
Re: 1971 A65 OIF Lightning Frame number #24834
05/18/07 5:47 pm
05/18/07 5:47 pm
South Wales
U
UNF Offline OP
UNF  Offline OP
U
South Wales
I too removed the paint carefully with paint stripper, didn't want to damage the frame number if it was lightly stamped.
Interesting to know about the warranty issues and dealer not re-stamping the frame. I know of one other person who has been in the same situation and they have re-stamped the frame. What alternative is there if the bike is to be registered with the owners club.
Re: 1971 A65 OIF Lightning Frame number #24835
05/18/07 6:07 pm
05/18/07 6:07 pm
I don't think there is an alternative. I don't know about the UK, but in my country I would re-stamp it, if only for insurence reasons in case of things you don't want to happen.
What will you do with the frame? Return to the original grey?
Re: 1971 A65 OIF Lightning Frame number #24836
05/21/07 8:01 pm
05/21/07 8:01 pm
South Wales
U
UNF Offline OP
UNF  Offline OP
U
South Wales
Re-stamping the frame it is then.
With regards to the rebuild, I will endeavour to take the bike back to original colour frame - grey. I haven't yet made my mind up about the tank and side panel colours although, I do quite like the bronze colour (not actually sure what the correct colours are but will find out in due course).
The first task though, is to get the engine started; hopefully this won't require a complete overhaul. I will find out what needs doing to the engine over the next month or so.
Re: 1971 A65 OIF Lightning Frame number [Re: UNF] #340820
10/31/10 10:51 pm
10/31/10 10:51 pm
Bishops Stortford, England
timbo Offline
timbo  Offline
Hi,just had a second look at this post,my own 1971 Thunderbolt has an X,but also a frame number of GE 10006,but with an unmatched engine. I found the original remains of the dove grey under the black topcoat. Does any folk now know for sure why the X has been added,and isnt that frame number a little odd? The bike was re-imported to UK in around 1979,but a tale going about says it was sold new in China.i Didnt know BSA sold in China?
Timbo
1971 Thunderbolt
1957 Bantam D3
1992 Triumph Trident 750
Re: 1971 A65 OIF Lightning Frame number [Re: timbo] #340897
11/01/10 12:15 pm
11/01/10 12:15 pm
Oslo Norway
Per B - R.I.P. Offline
Oslo Norway
I have a 71 Lightening with the same problem, no frame number, but again it's likely due to a frame swap as most of the early 71 got their frames change on warranty. I will satmp the number next time I am painting the frame (in 20 years time or something)
Per
best regards
Per
Goldi Clubmans
Goldi Scrambler
Rob North R3
OIF A65
