DamienE
DamienE
Palm Bay, Fl.
36 registered members (AML), 181 guests, and 62 spiders.
10383 Registered Users
NickL 98
Mori55 89
Stuart 77
reverb 76
DavidP 71
Triless 71
Rohan 69
btour 65
689,335 mail-order LSR
Topics68,024
Posts661,788
Members10,383
How to straighten a bent cylinder head fin... #333964
09/17/10 3:53 am
09/17/10 3:53 am
Jordan, NY
Al Eckstadt Offline OP
Jordan, NY
... without breaking it. Terrible picture but you can see the top fin on the right:
There is a really thin fragile looking web in front. How can I get this back in shape?
Thanks. Al.
Al Eckstadt
Re: How to straighten a bent cylinder head fin... [Re: Al Eckstadt] #334085
09/18/10 12:04 am
09/18/10 12:04 am
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
I have had ver little luck with that situation so my advice is taken FWIW but I would attempt to heat the fin with propane then wedge some wood between the lower fins and gently bend upward . This where I usually get impatient ,crack the fin and weld it back on .But hey , it gives me an excuse to sand and polish things .
FWIW-BONZO
Re: How to straighten a bent cylinder head fin... [Re: Al Eckstadt] #334096
09/18/10 1:39 am
09/18/10 1:39 am
Jordan, NY
Jordan, NY
Bonzo, that's the same method described to me by a friend last week. I guess I'll have to try it. Thanks. Al.
Al Eckstadt
Re: How to straighten a bent cylinder head fin... [Re: Al Eckstadt] #340717
10/31/10 4:22 am
10/31/10 4:22 am
Jordan, NY
Jordan, NY
I finally got to do this tonight. I cut hardwood wedges about 1/4 inch thick and slid one in across from the front set of fins to the rear - under the bent fin. I tapped it in lightly until the wedge got a bit tight, then with a oxy/acetylen torch (small brazing tip, small flame) lightly heated the bent area. Tapping the wedge I could feel the heat had loosened it some. Kept tapping and heating a dozen times or so until the wedge was completely under the fin. I had to change to a slightly thicker wedge and continued the process until the fin was straight. No cracks! Thanks. Al.
Al Eckstadt
