MrBean
MrBean
Tasmanian Devil country
20 registered members (bc1977), 191 guests, and 139 spiders.
Bart223, Duckster, IDG1, pemdoc65, creativecroc
10172 Registered Users
Lannis 96
reverb 84
Stuart 79
NickL 68
koan58 61
550,560 mail-order LSR
Topics66,561
Posts645,255
Members10,172
1960 A10 Piston/Ring Clearances? #33883
01/28/08 4:10 pm
01/28/08 4:10 pm
Buffalo, NY
Wyn Offline OP
Wyn  Offline OP
Buffalo, NY
Hey Gang, Just received .060 pistons and rings from SRM Engineering. They are 7.5:1 compression. My engine is a DA10R (Super Rocket) I just want to confirm, what I want as far as clearance goes, when I talk to the engine borer. It has .040 in there now. The Haynes manual states .004-.0055 piston clearance for a Super Rocket with 8.5:1 pistons.
Setting them to .0045" would be good then? States the comp. rings at .013" and the oil ring at .011".
Do you ALL agree with those specs? Would appreciate your thoughts. I don't want to screw this up. LOL Thanks, Wyn
Re: 1960 A10 Piston/Ring Clearances? #33884
01/28/08 10:23 pm
01/28/08 10:23 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
Wyn, you need to know the type of alloy they are cast from. (Talk to manf.),some low expansion stock could safely have you running .003 and some drop forged jobs may have you needing near .005. From reading here it's better to set the ring gaps to the larger sizes given again talk to the Manf.,no pat answerers sorry.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: 1960 A10 Piston/Ring Clearances? #33885
01/28/08 10:37 pm
01/28/08 10:37 pm
Asheville, North Carolina
ca7a Offline
ca7a  Offline
Piston clearances sort of depend on manufacturer's specification. SRM should provide you with that info. Rings, too.
Otherwise, I'm sure some very knowledgeable forum folks will chime in, Wyn.
Re: 1960 A10 Piston/Ring Clearances? #33886
01/28/08 11:37 pm
01/28/08 11:37 pm
Buffalo, NY
Wyn Offline OP
Wyn  Offline OP
Buffalo, NY
There is absolutely NO mfg. markings on the pistons at all. The only markings are on the top of the piston and show 060. I've emailed SRM twice about any specs they might have, and have gotten no answer
since thrs. These damn pistons aren't cheap, but even more, I just want to do it right the first time. The two pistons just came in two plain brown
boxes with no markings at all.
Re: 1960 A10 Piston/Ring Clearances? #33887
01/28/08 11:57 pm
01/28/08 11:57 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
Wyn, Can you tell if they are cast or forged pistons. This will narrow it a little, a picture might help. You have to find what the metal is to know so we need some help to identify them.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Re: 1960 A10 Piston/Ring Clearances? #33888
01/29/08 1:41 pm
01/29/08 1:41 pm
Buffalo, NY
Wyn Offline OP
Wyn  Offline OP
Buffalo, NY
Thanks for the input guys. I just received a reply from SRM on fitting the pistons to the bore. I'm going to take this email reply, along with the spec sheet from Haynes, give it to the machine shop, and hope for the best. Thanks again, Wyn
Here's their reply:
Pistons are of Euro origin, but we always fit Hepolite or equivalent rings, just to make sure.
If bore is finished honed to the correct size, clearance and ring gaps will be correct, just fit and go.
Bore and plateau hone to exactly 71.50mm thats 2.8150" +/- 2 tenths.
Bore size is standard BSA, if bore is finished to this size, whatever make piston you fit, will have the correct clearance, piston manufacturers use different alloys, different thickness alloys, so they know the expansion rates for their piston, so they are all made to suit the stock BSA bore sizes.
It is dangerous to deviate from the BSA bore size and go only for clearances, BSA clearances are for BSA pistons only, and do not apply to any other piston.
Regards Gary
Page Time: 0.084s Queries: 14 (0.004s) Memory: 1.0209 MB (Peak: 1.1780 MB) Zlib disabled. Server Time: 2018-04-22 07:08:04 UTC
