iansoady
iansoady
Birmingham UK
33 registered members (998John), 215 guests, and 455 spiders.
10257 Registered Users
Stuart 80
Lannis 57
610,000 mail-order LSR
Topics67,134
Posts651,487
Members10,257
trident norman hyde 867 big bore kit #335121
09/25/10 12:02 am
09/25/10 12:02 am
il.
gtx Offline OP
gtx  Offline OP
il.
anybody know if stock wrist pins and clips fit the 867 pistons?
(2)atlas,(1)g-15,(1)g15mk2,(2+)E-starts,(1+)comm.(2)trident,(3+)tri.twins,(1)lambretta,(1) atlas nor-trump
Re: trident norman hyde 867 big bore kit [Re: gtx] #335308
09/25/10 11:16 pm
09/25/10 11:16 pm
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
I don't think I've heard of a Hyde "867" kit?
The two normal Hyde big bore kits are 831cc (71mm x 70mm) and the long stroke 973cc (71mm x 82mm) both of which use modified 650 Bonneville pistons which have the same pin diameter as the Trident (.6882-.6885") but according to the workshop manual information, the 650 pins are shorter-even though the pistons are bigger.
Re: trident norman hyde 867 big bore kit [Re: L.A.B.] #335324
09/26/10 1:28 am
09/26/10 1:28 am
Stuart Offline
Stuart  Offline
Hi Les,
67 x 82 - i.e. standard bore with long-stroke crank; I remember Norman advertising 'em.
Re: trident norman hyde 867 big bore kit [Re: Stuart] #335343
09/26/10 8:54 am
09/26/10 8:54 am
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
OK-as the only '867' kit I'd heard of, was the Routt big-bore kit.
So presumably, the Hyde 867 kit would have used standard triple pistons modified to suit?
Re: trident norman hyde 867 big bore kit [Re: L.A.B.] #335344
09/26/10 10:02 am
09/26/10 10:02 am
Stuart Offline
Stuart  Offline
Hi Les,
Tbh, I can't now remember what Norman sold in the kit - whether it included his taller barrel suitably bored or, as you say, modified standard pistons.
I did always think it was a weird combination of bore and stroke.
Re: trident norman hyde 867 big bore kit [Re: gtx] #335346
09/26/10 10:17 am
09/26/10 10:17 am
Stuart Offline
Stuart  Offline
sales@normanhyde.co.uk?
Re: trident norman hyde 867 big bore kit [Re: Stuart] #335382
09/26/10 3:10 pm
09/26/10 3:10 pm
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
Stuart,
What I meant was, that as the crank stroke is increased by 12mm and with the taller Hyde cylinder block, I wondered if the skirts of the standard triple pistons also required machining to prevent them from clouting the crank webs at (or near) BDC in the same way that the 71mm '650 twin' pistons have to be modified for use with the 1000 (973cc) kit? But it wasn't important, just me 'thinking out loud'.
Re: trident norman hyde 867 big bore kit [Re: gtx] #335401
09/26/10 4:38 pm
09/26/10 4:38 pm
il.
gtx Offline OP
gtx  Offline OP
il.
cyl id is 72mm this is a re-sleve kit
Re: trident norman hyde 867 big bore kit [Re: gtx] #335402
09/26/10 4:39 pm
09/26/10 4:39 pm
il.
gtx Offline OP
gtx  Offline OP
il.
Re: trident norman hyde 867 big bore kit [Re: gtx] #335420
09/26/10 6:39 pm
09/26/10 6:39 pm
Stuart Offline
Stuart  Offline
+0.040" (max. overbore) 71mm pistons, which sounds like you have oversize modified 650 pistons, that Les mentioned earlier in the thread,
Fwiw, this piston diameter with a standard crank is 855cc or with the 82mm-stroke crank is a gnat's over a litre.
Re: trident norman hyde 867 big bore kit [Re: gtx] #335548
09/27/10 2:25 pm
09/27/10 2:25 pm
Mark Parker Offline
Mark Parker  Offline
I've bored routt liners to .080" and used T120 pistons with altered valve cutaways and shortened skirts. There has to be better pistons available now days. Those T120 pistons use a wire type circlip, the T150 pistons use a worse type in my view which are square section with eyelets. If they spin loosly in their groove with any up and down play, they will break and come out, I had that with routt 867 pistons when I used T150 circlips which sort of fitted but were a little loose, probably because the groove was deeper and needed the correct clip or buttons, circlips need to be tight in the piston with spring tension so as not to pound up and down.
