Buckshot1
Buckshot1
Diamond Springs, Kalifornia
37 registered members (Al Eckstadt), 312 guests, and 378 spiders.
10419 Registered Users
btour 88
reverb 75
Triless 75
711,216 mail-order LSR
Topics68,310
Posts665,061
Members10,419
Oil tight Triumph... myth or reality? #334425
09/20/10 5:34 pm
09/20/10 5:34 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Have any of you achieved the impossible? Stopping a British bike from leaking. I've owned my Bonnie for a year less 6 weeks now, and I've become attached to the old girl, and I use her as a daily ride. In that time I've done a few things to cure some ills, but one constant source of frustration has been trying to get this blasted motor to stop leaking. It seems the faster I go (higher the revs) the more it leaks. I pretty much decided that most Brit bikes do this. I've replaced gaskets in various areas (not all), and "gently" glassed flat some of the cases, yet it continues to seep, weep and drip.
Any tips for an oil tight 72 T120R? Most of my seepage is the primary / rocker box / cyl. head / gearbox / all drain bolts. Needless to say, I have a few drops on the garage floor. Thanks guys.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334427
09/20/10 5:47 pm
09/20/10 5:47 pm
London United Kingdom
meriden4ever Offline
It can be done- all mine are although every so often something has to be doen, like replace a seal or re-site a pushrod. This is infrequent to say the least but it isn't nor wil it ever be Japanese oil tight although my TR7T and TR65 come closest
1983 TR65T Tiger Trail
1983 TSSAV
1983 TSX
1983 TR65 Thunderbird
1982 TR7T Tiger Trail
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334431
09/20/10 6:15 pm
09/20/10 6:15 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
Proper assembly with quality parts goes a long way to insure leak free operation.
My 72 sat for five months in a storage unit while I worked out of town with no marks on the floor.
My 68 lived in my dinning room when I worked in Santa Barbara with no complaints from the landlord.
Most people are too lazy or uninterested to spend the time to do the maintenance. It is far easier to bitch.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334438
09/20/10 7:34 pm
09/20/10 7:34 pm
triton thrasher Offline
The drain bolts shouldn't leak. Put new annealed copper washers on.
if geabox oil is coming out of the kickstart and gearchange shafts, are you sure you're not overfilling it?
I doubt that any quantity woth worrying about is coming from the head joint.
Rocker box- make sure it's flat. New gaskets with sealant both sides or no gaskets just silicone or good sealant such as Hylomar.
And recheck tightness of everything after a few miles and then again after a few more.
You didn't mention the pushrod tubes.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334440
09/20/10 7:44 pm
09/20/10 7:44 pm
dave jones Offline
dave jones  Offline
Bola's point about leaking more when using high revs could indicate a breather problem. My bike definitely leaks more if the breather pipe is blocked with gunge. The breather system is different on my 67, of course. The breathing on these bikes is often complained about although I would have thought that a 72 would breathe better than my machine.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334451
09/20/10 10:18 pm
09/20/10 10:18 pm
Halifax, Nova Scotia, Canada
Queen's Horseman Offline
My Bonnie has been oil tight many times! It is the intervals in between that sometimes frustrate me.
As has been said before, quality gaskets, o-rings, and careful assembley go along way to keeping the oil in. I've had good results with MAP gaskets and I usually skim with Hylomar. Good o-rings that can with stand the heat are needed, not just something from Walmart/Home Depot. Getting everything flat and clean is a must.
If your leaks are from extended high rpm use then do a search for mods that the racers do to increase engine breathing. Might help but if run hard, eventually something will give.
Re: Oil tight Triumph... myth or reality? [Re: triton thrasher] #334485
09/21/10 1:23 am
09/21/10 1:23 am
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
What type of Hylomar do you recommend? There are a few types. And yes, push rod tubes leak a tad also.
Re: Oil tight Triumph... myth or reality? [Re: Queen's Horseman] #334501
09/21/10 6:45 am
09/21/10 6:45 am
That's a good one!
These late bike are supposed to have adequate breathers.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334502
09/21/10 6:47 am
09/21/10 6:47 am
I thought there was only blue Hylomar.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334512
09/21/10 9:25 am
09/21/10 9:25 am
QLD, Australia
RetroRod Offline
RetroRod  Offline
QLD, Australia
[quote=Bola]
Any tips for an oil tight 72 T120R? Most of my seepage is the primary / rocker box / cyl. head / gearbox / all drain bolts. Needless to say, I have a few drops on the garage floor. Thanks guys. [quote/]
Have a read here for some opinions.
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=334338#Post334338
I agree with Desco.
A PCV will do more to stop leaks than most anything else. The original breather is plain hopeless and just simply contributes to pressuring oil from the inside out. I'll stick my neck out and say that this is the main contributing factor in the difference between our bikes and rice burners. RR
'72 Bonneville
"He who praises you for what you lack wishes to take from you what you have." - Don Juan Manuel
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334515
09/21/10 9:46 am
09/21/10 9:46 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
IME oil leaks are quite preventable but weepage is not if you use the bike at 60/70 MPH for fair mileages.
Been doing this with one engine for 7 yrs and 32K miles and whilst they will not weep if paraded around town they will at 4000/4500 sustained RPM in the bush.
What you see is rockerbox gasket leakage and that can be fixed with copper gaskets very lightly coated with silicone.
1969 TR6R
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334579
09/21/10 8:00 pm
09/21/10 8:00 pm
Very much depends on the year of manufacture as well. I've seen late 750's with corroded fasteners that snap off when trying to disassemble the engine. Very oil tight. Everyone knows that pre units leak like a sieve. I've got two pre units. One only leaks from the breather pipe and that does not qualify as a leak in my book. A leak is a flow of oil that needs repair. My other pre unit is leak free except that awful primary cover. It really takes patience, money and skill to make these leak free. Tiger's suggestion of copper rocker box gaskets with a light coating of a silicone compound is very similar to my technique. I use Permatex Ultra Blue but there are lots of others out there that do a decent job. Ultra Blue is a silicone sealer but it has a texture that is quite different from the clear foul smelling stuff that backyard hacks used to ruin many a engine.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334587
09/21/10 8:50 pm
09/21/10 8:50 pm
Asheville, NC
Mike Baker Online content
Mike Baker  Online Content
Asheville, NC
After stating (bragging?) in a post re: oil usage a couple of weeks ago that neither of my triumphs leaked, I need to eat those words.
My boys came to visit/ help move house and we took the bikes out for an all day thrash in the world's best motorcycle playground, Western North Carolina. The rented BMW came back clean. The Triumphs, not so much. Both needed a piece of cardboard under them to keep the new garage floor from getting stained. I hate new concrete...
Primary cover leaks, it appears. 200+ miles of high rpm 2nd and 3rd gear riding is the apparent cause?
I'll take the leaks anytime if it's the price one pays for a sh*t eating grin.
Mike
Re: Oil tight Triumph... myth or reality? [Re: Mike Baker] #334598
09/21/10 9:50 pm
09/21/10 9:50 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Mike
Tend to agree with you Mike, but would be nice to have both the grin and a clean floor. smirk Thanks all for your suggestions. Will try a few.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334624
09/22/10 12:31 am
09/22/10 12:31 am
Angus, Scotland
mick2 Offline
mick2  Offline
Angus, Scotland
my t120 was oil tight for a while but noe the damn primary is leaking, through the seal at the back of the clutch i think. its a new seal and gasket 1000 miles ago. gearbox is also starting to weep when on the sidestand. not elved into it yet but can only be the either the seal on the shaft or at back of the layshaft roller bearing which was filled with silicone, im hoping its just that, an easy fix.
but i wouldnt swap it for anything, i still get butterflies in my stomach as i wheel her out the garage smile
Re: Oil tight Triumph... myth or reality? [Re: mick2] #334627
09/22/10 1:07 am
09/22/10 1:07 am
spfld vt
phantom309 Offline
phantom309  Offline
spfld vt
A triumph should not leak a drop of oil.Thats the bottom line. even my race bike is oil free.
Tim Joyce
sponsors
D@D cycles
Works shocks
Glass from the past
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334631
09/22/10 2:05 am
09/22/10 2:05 am
JubeePrince Offline
JubeePrince  Offline
Mine's been oil free/tight since I re-did the top end in the spring '10, but it took awhile to get there.
To wit: spring '09, I replaced the seals and O-rings in the primary and mainshaft of the transmission, spring '08, I replaced all the original oil lines, spring '07, I replaced......you get the idea...
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334663
09/22/10 10:47 am
09/22/10 10:47 am
Asheville, NC
Asheville, NC
Tim-
Not taking anything away from you or your skills as a rider and builder.
But how many actual miles do you put on a racebike in a season? And is the engine ever taken apart and reassembled (new gaskets, etc) during the season?
Going to try to get to Barber this year, will stop by your pit to say hi.
Mike
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334664
09/22/10 10:54 am
09/22/10 10:54 am
I don't think I've ever seen a running dynamo-equipped Pre-unit Triumph that didn't leak a little from where the dynamo meets the back of the timing case and I've looked at a great many of them.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334676
09/22/10 12:27 pm
09/22/10 12:27 pm
It is said that if a Triumph ain't leakin' oil , it's cos there ain't any in there !
1983 TSSAV
1983 TSX
Re: Oil tight Triumph... myth or reality? [Re: Mike Baker] #334682
09/22/10 12:50 pm
09/22/10 12:50 pm
spfld vt
phantom309 Offline
phantom309  Offline
spfld vt
Mike,I would guess it gets about 1200 wfo miles in a season.The head has been off twice this yr and the gear box several times. Run no gaskets in the gear box and copper on the topend, map pushrod seals.The head has come off only to inspect but the trans main shaft has been a problem this season.Trying a outrigger bearing at Barber to help suport it and only hope it doesn't cause another problem.
Tim Joyce
sponsors
D@D cycles
Works shocks
Glass from the past
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334687
09/22/10 1:32 pm
09/22/10 1:32 pm
Charlotte NC
RHall-HCV Offline
RHall-HCV  Offline
Charlotte NC
Tims bike is a testament to the reliability of a triumph. It gets run to death race after race and keeps going. But Tim also takes very good care of his bike and does the right things.
ROB HALL
HCV MOTORSPORTS
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334705
09/22/10 3:56 pm
09/22/10 3:56 pm
Blue Ridge, Georgia, USA
Rob Harper Offline
Rob Harper  Offline
Reminds me of the old saw about the two types of skylights: those that leak and those that don't leak yet. I've fought the primary on my '71 for 27 years with only periodic success.
Re: Oil tight Triumph... myth or reality? [Re: Bola] #334706
09/22/10 4:44 pm
09/22/10 4:44 pm
Deltona, FL
lrutt Offline
lrutt  Offline
Deltona, FL
My 71 has not leaked a drop for 10 years. It has some wetness around a few places, very minor, but no outright leaks or drops. I think I have my 70 at the same point. Had a problem on the top but that seems to have been corrected. I actually had a crack in the primary case on the 70. Got that welded and fixed the stripped plug, some RTV on the gasket and no leaks.
1970 Tiger
1971 Trophy
1973 Commando
1976 CB750k
1965 CA77
1978 CB750k
1970 T250II
1971 RT1B
1977 Lemans
2001 M900
2001 XR650L
1994 FLSTC
2006 XL1200C
1984 XV1000
1981 C70
1973 Z50
1989 Hawk GT
2006 Scrambler
1970 CT90
1965 CT200
1977 R75/7
Re: Oil tight Triumph... myth or reality? [Re: RetroRod] #334723
09/22/10 5:29 pm
09/22/10 5:29 pm
Orleans Massachusetts
Skeet Offline
Skeet  Offline
My Brits don't leak. Not a bit. They're just porous thats all. laugh
Skeet
1964 Hornet
1970 TR6R
1971 Norton
1972 XLH
