Lars Melin
Lars Melin
Sweden
30 registered members (Adam M.), 173 guests, and 442 spiders.
Andy Mac, kwbikr, RandomTask, George Henstorf, IanBSABurns44
10378 Registered Users
Mori55 94
NickL 86
DavidP 82
Stuart 82
reverb 73
Triless 69
687,851 mail-order LSR
Topics67,995
Posts661,404
Members10,378
C15 Backfiring on over-run #334197
09/18/10 10:36 pm
09/18/10 10:36 pm
birmingham uk
dave thomas Offline OP
birmingham uk
My newly built C15 Trials bike backfires like a b****** on overrun. The exhaust/silencer clamps seem good, the carb and inlet are new, so could this be down to lack of back pressure? The short silencer is a token gesture and the outlet is approx the same as the headers..? (its been modified since this pic)
Re: C15 Backfiring on over-run [Re: dave thomas] #334204
09/18/10 11:20 pm
09/18/10 11:20 pm
Tucson, AZ, USA
CafeLoco Offline
CafeLoco  Offline
Tucson, AZ, USA
Howdy Dave: Beautiful C-15 Trials. I just finished a 65' C-15 in café mode with complete rebuild. After fitting a new AMAL Concentric 626 (190 main jet), start-up with the air mixture screw at two turns out and open megaphone exhaust (no back pressure) I had only one experience of backfire on overrun because it was too rich. I've since reduced the main jet to 170, re-installed the meager megaphone baffle, air mixture screw 1-1/2 out, velocity stack (no air cleaner) and haven't had a backfire since. Idles and pulls evenly through all throttle advances. Important balancing act between the mixture screw and the throttle cable adjustment. Make sure you have no change in throttle when you move the steering head. Can get interesting when you least want it, and check the spark plug color after a hot run.
Jeff
Re: C15 Backfiring on over-run [Re: dave thomas] #334205
09/18/10 11:25 pm
09/18/10 11:25 pm
Tucson, AZ, USA
CafeLoco Offline
CafeLoco  Offline
Tucson, AZ, USA
Dave; What forks have you fitted, did you retain the C-15 yolks, and what year C-15? I'd like to upgrade mine and yours look great.
Jeff
Re: C15 Backfiring on over-run [Re: CafeLoco] #334218
09/19/10 12:58 am
09/19/10 12:58 am
Canada
LarryLebel Offline
LarryLebel  Offline
Canada
Put the needle on the top notch to lean it out before you start buying new bits.
Re: C15 Backfiring on over-run [Re: LarryLebel] #334250
09/19/10 8:35 am
09/19/10 8:35 am
birmingham uk
birmingham uk
Thanks for the answers, I`ll have a play with the carb and see what happens.
Jeff; the front end is off a Can-Am Bombadier, the forks are Betor with alloy triple clamps and I used the brake too. They were all in military green but once cleaned up look great.The brake looks quite retro and polishes up well, and weighs about 6lb. The stem is the same dia as Bsa, just needs shortening.It can`t be shortened to totally the correct length but a spacer about 1/4" on top of the lower bearing sorts it out. Or just re-thread the top? Easy to understand once you have the parts in your hand.
From the other side..
Re: C15 Backfiring on over-run [Re: dave thomas] #334267
09/19/10 11:22 am
09/19/10 11:22 am
BSA_WM20 Offline
BSA_WM20  Offline
Also have a good look at your ignition.
If you still have points, they can stick and not retard on overun so the sparks occur at the wrong time.
Air leaks in the exhaust will also make it backfire on over run if the timing is correct.
and then there is the problem of a sticking slide
Re: C15 Backfiring on over-run [Re: dave thomas] #334268
09/19/10 11:22 am
09/19/10 11:22 am
Very nice looking bike. Backfire on overrun is almost invariably due to an air leak. Incorrect idle mixture (particularly if the idle circuit is plugged) can exacerbate this. Don't bother with any of the other carb settings as they are unaffected at closed throttle.
Re: C15 Backfiring on over-run [Re: Alex] #334287
09/19/10 2:16 pm
09/19/10 2:16 pm
birmingham uk
birmingham uk
Hi, thanks for suggestions. Carb is new 622 with 120 main and .106 needle. Ignition is PVL type , and I`m sure that its not far off.I did read that engines with low back pressure exhausts can often pull a weak mixture through when the throttle closes? I`d accept the odd backfire, but these are pretty constant. ( Jeff, its a `66 )
Re: C15 Backfiring on over-run [Re: dave thomas] #334303
09/19/10 3:34 pm
09/19/10 3:34 pm
Canada
LarryLebel Offline
LarryLebel  Offline
Canada
Exhaust backfire is caused by too rich, don't ignore the carb settings.
Re: C15 Backfiring on over-run [Re: dave thomas] #334311
09/19/10 4:20 pm
09/19/10 4:20 pm
British Columbia
hh Offline
hh  Offline
British Columbia
Put your (gloved) hand over the exhaust when it's running and look and feel for leaks at the head. I'd bet there are some.
Re: C15 Backfiring on over-run [Re: dave thomas] #334315
09/19/10 4:26 pm
09/19/10 4:26 pm
Dave....do you have a kill switch in the system? Long shot but...if you do....disconnect it and see if that helps.
Been there, done that, lost some head hair in the process...GG in NC
Re: C15 Backfiring on over-run [Re: Gordon Gray] #334329
09/19/10 7:00 pm
09/19/10 7:00 pm
birmingham uk
birmingham uk
Hi Larry and others, cheers for taking time to reply.The reason I suggested it pulling a lean mix thru on overrun is I was under the impression that backfires can be due to the pilot cicuit (closed throttle, highish revs) fuel passing thru unburnt as too lean, then firing in the exhaust?
I`ll check the kill switch too, although it`s new, but I`m pretty certain its fuel related.
Not been able to get out today and have a mess around ,but hopefully will one evening this week
Re: C15 Backfiring on over-run [Re: dave thomas] #334347
09/19/10 9:16 pm
09/19/10 9:16 pm
Originally Posted By: dave thomas
...snip....I`ll check the kill switch too, although it`s new.............
Dave....don't just check it out...take it out of the circuit. Mine was new too, it had a weak spring and when I reved it up...the vibration would cause an arch....and a BIG backfire. When it settled down...it ran fine. When it first started...I pulled the rubber cover off and looked it over...and saw no problem. So....it took over a month of chasing EVERYTHING ELSE blush before I finally, as a last ditch effort...just unpluged it.
Just a thought...and easy to do.....proud to be one of the BSA unit single guys...Gordon Gray in NC, USA
Re: C15 Backfiring on over-run [Re: dave thomas] #334372
09/20/10 1:50 am
09/20/10 1:50 am
Tucson, AZ, USA
CafeLoco Offline
CafeLoco  Offline
Tucson, AZ, USA
(...proud to be one of the BSA unit single guys...Gordon Gray in NC, USA)
Hip, hip, hurray, Gordon Gray! We 'single-unit' guys are often lost in the world of numerous twins. A 'thumper" owner since 1965 (Ducati Diana MkIII, Bultaco Montesa, and Triumph Cub. Long live the Thumpers.
Jeff
