29 registered members (Alan_nc), 214 guests, and 453 spiders.
10257 Registered Users
Stuart 77
Lannis 56
610,291 mail-order LSR
Topics67,138
Posts651,518
Members10,257
Page 2 of 2 1 2
Re: How to improve oil flow to T100 rocker boxes? [Re: highway] #325973
08/02/10 12:29 am
08/02/10 12:29 am
hampshire, england
t120mike Offline
t120mike  Offline
hampshire, england
Unfortunately, the leakage you see when loosening the acorn nuts only indicates that the oil is getting that far. When they are tightened again, how much is getting all the way in?
mike
Member #: 147
1960 T120 Bonneville
1999 H*%^a VFR 800 FI
V4 Triton Project (still keeping me sane (Ha-Ha!))
Re: How to improve oil flow to T100 rocker boxes? [Re: t120mike] #325988
08/02/10 1:51 am
08/02/10 1:51 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
The only way I can see involves measuring the pressure head with the engine running.Obviously at higher engine speeds there will be a higher pressure,so say we measure it at 3000 rpm.
Run a T-piece off the rocker feed line with a clear hose coming off vertically.See how high the oil level rises in the clear hose.That will give you the pressure head on both rocker spindles.
If you apply that pressure head to one spindle at a time,that should show how much oil each one consumes.
The only catch is that for a given pressure there will be more oil flow when the oil is hot.There is also less pressure in the return line with hot oil,so it should balance out.
I would test the pressure head with the engine cold,then do the consumption test with cold oil.
Re: How to improve oil flow to T100 rocker boxes? [Re: Pete R - R.I.P.] #325993
08/02/10 2:18 am
08/02/10 2:18 am
hamilton on. can.
H
highway Offline
highway  Offline
H
hamilton on. can.
I'm of the opinion that the pressure to lift the oil to the rockers is so low that it is little more than drip feed. I,ve got the 500 that had the extended forks I was talking about, at my shop now. I'll experiment with the feed tomrrow and get back.
Re: How to improve oil flow to T100 rocker boxes? [Re: highway] #326120
08/02/10 7:28 pm
08/02/10 7:28 pm
Toronto, Ontario, Canada
Matthew in TO Offline OP
I went for a 35 km run at 60+ mph yesterday and when I got home I removed the rocker caps. BTW, I have those tall, optional hex caps with the deep internal cavity within the cap. All four caps all oil splashed about on the inside, and all four rockers had some oil sheen. One cap had a lot more oil than the other three.
1970 Triumph T100S (1969 T100S motor)
Re: How to improve oil flow to T100 rocker boxes? [Re: Matthew in TO] #326139
08/02/10 8:54 pm
08/02/10 8:54 pm
John Healy Offline
John Healy  Offline
And Matthew you have a stock oil tank? There are issues with after market chopper tanks often seen on bikes with extended fork tubes. But that is only a small part of the problem!
Look at your rocker arms and then the rocker shaft spindle, if the light doesn't go on you will have to wait for the next issue of Vintage Bike.
Re: How to improve oil flow to T100 rocker boxes? [Re: John Healy] #326184
08/03/10 2:14 am
08/03/10 2:14 am
Yep, standard oil tank. You won't see any chopper parts on the bike while I own it.
The rocker arms and spindles all have some oil sheen, at least as seen through the top caps. Perhaps I'll open up the side rocker caps and have a look. I replaced one of the spindles last year as it was very loose (the other was fine - within spec), so I don't want to wreck the replacement.
Re: How to improve oil flow to T100 rocker boxes? [Re: Matthew in TO] #328369
08/16/10 1:51 am
08/16/10 1:51 am
Okay, I've got my cotter pin, but how do I stick in onto the oil tank return? I look into my tank and do not see a pipe outlet.
Re: How to improve oil flow to T100 rocker boxes? [Re: Matthew in TO] #328376
08/16/10 2:25 am
08/16/10 2:25 am
John Healy Offline
John Healy  Offline
We did an article on this in the next Vintage Bike which is at the printer. It should be mailed in the next week. The answer to this vexing problem isn't cured with a cotter pin.
Re: How to improve oil flow to T100 rocker boxes? [Re: John Healy] #328434
08/16/10 4:32 pm
08/16/10 4:32 pm
Excellent, I look forward to receiving my issue.
I'd like something more than just a recommendation to install a Morgo rotary pump in place of the standard plunger pump, as that's out of my budget right now.
Re: How to improve oil flow to T100 rocker boxes? [Re: Matthew in TO] #333166
09/12/10 9:16 pm
09/12/10 9:16 pm
Went for a good run this weekend. Took off the rocker box caps and could clearly see a collection of fresh oil at the end of each spindle at the outside edge of the spindle. Since the oil starts at the centre top of the spindle, I assume the oil is making its way along the spindle, and then drops down to the push rod tubes.
Page 2 of 2 1 2
