aprophet
aprophet
Chesapeake Virginia
205 registered members (57nortonmodel77), 2,337 guests, and 681 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,353 mail-order LSR
Topics66,021
Posts638,989
Members10,073
Fitting taper roller steering head bearings #328425
08/16/10 2:29 pm
08/16/10 2:29 pm
Bath, UK
steverat Offline OP
steverat  Offline OP
Bath, UK
Bike is a wideline featherbed '59 ES2.
I've pushed the outer races into the steering head so the edge of the races are flush with the ends of the steering head tube. I think they are seated down in the bottom of the bearing housing counterbore.
However upon assembling the fork yokes (triple trees I think you American chaps call them), into the steering head with the inner races on them, the cover at the top and the lower yoke at the bottom are significantly proud of the steering head. Plenty of space for grease to get out and muck to get in - I can even see the rollers. What do you think? Is that the way its supposed to be?
1924 SS80
1953 18S
1955 18CS
2013 Striple
Re: Fitting taper roller steering head bearings [Re: steverat] #328444
08/16/10 5:47 pm
08/16/10 5:47 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
The norton's up to the commando had balls and races.
The tapered roller bearings is what people convince them selves they need. Yet I have almost never heard of anyone bothering to install an inner tube and shim the inner column for correct bearing preload. The inner column (nut)is then tightened to exceed the highest possible dynamic load. That way the parts are not chaffing thmselves to death on bumpy roads or when crashing down from wheelies.
The sealed ball bearing such as the commando might as well be enough of an upgrade from the individual balls, and not allow the dirt to get in unless you engineer a suitable seal to finish the job.
I perceive this tapered roller bearing mod as a "race only" mod and therefore dirt exclusion and long life are not essential.
2c
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: Fitting taper roller steering head bearings [Re: Dave Comeau] #328451
08/16/10 6:29 pm
08/16/10 6:29 pm
Bath, UK
steverat Offline OP
steverat  Offline OP
Bath, UK
Thanks for that, Dave.
I managed to push the outer races right down further into the steering head so they are definitely seating at the bottom of the counterbores now, so hopefully it wont be so bad.
There was no inner tube when I took the forks apart, presumably the nut is usually locked with the top nut on the steering column shaft?
I'm thinking it would be good to give it just a bit of preload by taking up all the slack then putting maybe another 45 degrees of nut movement in, before locking the whole thing up.
1924 SS80
1953 18S
1955 18CS
2013 Striple
Re: Fitting taper roller steering head bearings [Re: steverat] #328607
08/17/10 2:38 pm
08/17/10 2:38 pm
Paonia, Colorado
Myles Offline
Myles  Offline
Paonia, Colorado
Steverat, Not sure if this applies but I have a BMW R90 and the factory manual says to adjust the tapered roller head bearings until the forks just fall to one side on their own when off-centered (with the front wheel off the ground). As these bearings don't actually spin I suspect that pre-load is not desirable.
Re: Fitting taper roller steering head bearings [Re: Myles] #330347
08/28/10 5:36 am
08/28/10 5:36 am
San Mateo, CA
Cookie Offline
Cookie  Offline
San Mateo, CA
And then on some Hondas preload is said to help handling problems. It can give a small dampening effect. I have also seen a couple of conversions of neck bearings that required a person to make sealing surfaces because the new rollers are thicker that the stock balls. I had to do this on an early Goldwing by fitting cups made to hold the seals. The results were very good but I think next time I'd just go stock or to All Balls company which give you seals if needed, rollers, spacers, and directions.
I imagine those are only available for common bikes.
Re: Fitting taper roller steering head bearings [Re: Dave Comeau] #332053
09/06/10 7:29 pm
09/06/10 7:29 pm
Bath, UK
steverat Offline OP
steverat  Offline OP
Bath, UK
Happy to say everything is fitted up now and looks great.
A tip for UK residents who are thinking about fitting taper rollers into a featherbed frame - B&Q do a misc orings pack for about 2, and one of the orings in the pack is a perfect fit as dust excluder top or bottom. So you need to buy two packs, but still a cheap way of finishing the job.
Steve smile
1924 SS80
1953 18S
1955 18CS
2013 Striple
Moderated by  Dave Comeau
Page Time: 0.045s Queries: 15 (0.005s) Memory: 1.0254 MB (Peak: 1.1831 MB) Zlib disabled. Server Time: 2018-02-21 15:03:11 UTC
