Two Alpha
Two Alpha
North Coast, BC, Canada
201 registered members (79T140E), 2,180 guests, and 562 spiders.
GabrielSoren, JoshP, spikey45, trevor's, myshootingstar68
10077 Registered Users
NickL 87
koan58 85
Lannis 81
504,148 mail-order LSR
Topics66,033
Posts639,137
Members10,077
A65 primary chain tension ? #326506
08/04/10 4:06 pm
08/04/10 4:06 pm
RED BANK NJ
Kenacu Offline OP
Kenacu  Offline OP
RED BANK NJ
I just re tightened the primary chain on my 1965 A65 LR as per the manual, which states "1/8 in. of top to botom play" in the top section of chain, mid span. Now 1/8 in. play is darn near "tight" as well as I can figure. Is this right? or is there some secret meaning to this?. Ken
1965 A65LR
2005 SPORTSTER CUSTOM 1200
Re: A65 primary chain tension ? [Re: Kenacu] #326512
08/04/10 4:27 pm
08/04/10 4:27 pm
It is very close to tight...but I would modify the manual's directions to say "no less than 1/8" of play at any point in the primary drive's rotation". Rotate and check, rotate and check...do this at least four of five times. Runout in the crank sprocket and clutch basket as well as uneven wear in the chain can produce tight spots which you want to avoid.
Re: A65 primary chain tension ? [Re: Alex] #326515
08/04/10 4:44 pm
08/04/10 4:44 pm
The spec is very confusing. Does it mean "1/8 of free play" or "1/8 of chain movement"?
The chain can be as tight as the high G string on a banjo, and you can still "move" it 1/8" with your hand. I don't think that's what the spec means.
I personally interpret it to be 1/8" "Free Play", where you can wiggle the chain and feel it "hit" the non-free-play region on the up side and the down side, where it'll still move but it's tight.
That's my story and it's worked for me - my present primary chain is the same one that came on the bike new and it's never been a problem.
Re: A65 primary chain tension ? [Re: Lannis] #326749
08/06/10 12:49 am
08/06/10 12:49 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Believe it or not, but the manufacturer of industrial chains and sprockets, Browning, described the identical process. For a few bucks you could buy an aftermarket chain tensioning measuring device, but I have found the freeplay, feel system to be adequate. The greater the center distance between sprockets the more free play. On the a65 you want it reasonably tight but not so tight that you put excessive load on the bearings which are further loaded when you accelerate. You will also wear out the chain prematurely if it is too tight and stretch it. If it is too loose you will know it when the rear wheel drives the engine..going down a hill with the throttle closed because now you have the tensioner on the driven side where it does not work so well.. I set mine where I can deflect the chain about 1/8 to 1/4 inch with modest force at the midpoint..whatever that is..... and it seems to work well.
Re: A65 primary chain tension ? [Re: Mr Mike] #326842
08/06/10 10:38 pm
08/06/10 10:38 pm
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
I set mine so it deflects 1/8" inch with a light touch of the finger.
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
Page Time: 0.123s Queries: 15 (0.006s) Memory: 1.0168 MB (Peak: 1.1688 MB) Zlib disabled. Server Time: 2018-02-23 00:26:00 UTC
