Kenacu
Kenacu
RED BANK NJ
203 registered members (1xfatboy), 2,156 guests, and 545 spiders.
koan58 89
Lannis 82
505,158 mail-order LSR
Topics66,049
Posts639,308
Wheel offset from frame? #325358
07/29/10 2:49 pm
07/29/10 2:49 pm
Toronto
beans n toast Offline OP
Toronto
This is going to possibly be the dumbest question ever!
OK, once I get my rear sprocket to line up with the gearbox sprocket on the pre-unit, and the wheel sits nicely in the swingarm, the wheel is offset from the centreline of the frame by almost an inch to the drum side!
This is not normal, and might surely kill me, right?
Are there any tips to how to rectify?
1957 T110
Re: Wheel offset from frame? [Re: beans n toast] #325369
07/29/10 3:43 pm
07/29/10 3:43 pm
John Healy Online content
John Healy  Online Content
Main (front) frame or rear frame?
Re: Wheel offset from frame? [Re: John Healy] #325371
07/29/10 3:59 pm
07/29/10 3:59 pm
Toronto
Toronto
The front.
1957 T110
Re: Wheel offset from frame? [Re: beans n toast] #325382
07/29/10 5:17 pm
07/29/10 5:17 pm
new jersey, usa
Jersey Kev Offline
Jersey Kev  Offline
new jersey, usa
Don't know if this will help, but I had a similar problem with my '76 T140V Bonnie. I know, completely different bike but, I had a seriously offset rear tire, so close to the sprocket was the tire that I couldn't hardly fit a matchbook between the chain & tire, let alone a chainguard. I finally discovered after installing a newer rim and stainless steel spokes, that a PO had laced the wheel backwards. How do I know it was he, and not me? I replaced spoke for spoke, one at a time (due to 4 different sizes). Well, when I (thought I) was done, the chain wouldn't fit at all. Only then did it dawn on me that it was backward from the start. I got it sorted out, and now there is sufficient clearence for the chain, and I now have a chainguard to boot. Oh, I was also able to remove a "shim" washer on the rear caliper which was needed in order to make that work. The tire still looks kind of offset, but at least it work better now. Maybe someday I'll get it figured out completely.
Hope this helps,
Jersey Kev
Jersey Kev
67 TR6P Saint
76 T140V Bonneville
95 Daytona 900
(removed non-brit from list)
Re: Wheel offset from frame? [Re: Jersey Kev] #325389
07/29/10 6:01 pm
07/29/10 6:01 pm
Toronto
Toronto
Thanks Kev,
My issue isn't so much clearance. Everything lines up great, (brake stay, sprockets, etc.. and the tire fits great in the swingarm...
But when I look at the tire, it doesn't fall directly in line with the centre of the front frame section. It's about an inch to the left (sprocket side) when I'm looking at it from the rear.
I imagine this would cause all sorts of handling problems, especially at higher speeds?
Unless this is one of those quirky pre-unit things?
1957 T110
Re: Wheel offset from frame? [Re: beans n toast] #325396
07/29/10 6:20 pm
07/29/10 6:20 pm
1954 to 1960 Triumph twins 2 9/16"
This offset dimension is given from the center of the rim to the furthest hub projection OPPOSITE the brake drum side.
This is taken from the Western Triumph and Ariel Motorcycle Dealers Supplemental Information Booklet put out by Johnson Motors. January 1960
Re: Wheel offset from frame? [Re: John Healy] #325418
07/29/10 8:37 pm
07/29/10 8:37 pm
Toronto
Toronto
Thanks John,
I'll measure when I get home.
But I'm right to think the rear wheel should align centered to the backbone of the frame and the front wheel?
1957 T110
Re: Wheel offset from frame? [Re: beans n toast] #325434
07/29/10 9:48 pm
07/29/10 9:48 pm
Los Angeles
tonupjonnie Offline
tonupjonnie  Offline
Los Angeles
Here is a shot of a 1957 TR6 Iam currently restoring showing the wheel centered, this frame and subfram were both in need of straightening after some rough years in the So Cal Desert.
Jonnie.
Re: Wheel offset from frame? [Re: tonupjonnie] #325472
07/30/10 2:16 am
07/30/10 2:16 am
Johnie: What's your offset as compared to the figures given by Johnson Motors?
I often find the "book" figures don't jive with the those taken from the bike itself.
Re: Wheel offset from frame? [Re: beans n toast] #325492
07/30/10 3:58 am
07/30/10 3:58 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
I don't know why people insist on using some part of the hub (which may or may not be in its ideal position) as a reference point for wheel-building.
If you have a Triumph 500/650/750 unit or pre-unit and its built with standard parts,the centreline of the gearbox sprocket and chain is 3" from the frame centreline.
So if the centreline of the rear sprocket is 3" from the rim centreline,a 1950 Speed Twin would be happy with that.If the chain is aligned ,the wheel will be centred in the frame.
Because unit engines are noticably heavier on the primary side (with alternator,duplex/triplex chain,and a heavier clutch),I shorten that centre to centre distance to 2-15/16".
The chain stays aligned and the rim moves slightly toward the weight centre (primary side).
This keeps a unit happy.
Re: Wheel offset from frame? [Re: Pete R - R.I.P.] #325494
07/30/10 4:42 am
07/30/10 4:42 am
Los Angeles
tonupjonnie Offline
tonupjonnie  Offline
Los Angeles
Funny you should say that John, I have that Wheel Lacing Info up on my blog, as you suggest it give 2-9/16 as the correct measurement when in reality it needed to be set at 2-1/4, at this measurement the Rim is perfectly centered, here is that chart that I should probably remove from the blog if not amend it.
[email:http://tonupclassics.blogspot.com/]http://tonupclassics.blogspot.com/[/email]
Re: Wheel offset from frame? [Re: tonupjonnie] #325547
07/30/10 2:20 pm
07/30/10 2:20 pm
Toronto
Toronto
Well, something's not right then. Sprockets line up, wheel is not centered to the frame.
I hope it's not the frame being bent, but just the wrong wheel.
I'm gonna take it to my mechanic tomorrow, and he will probably call me a moron and an idiot and yell at me... then I will pay him for the pleasure.
1957 T110
Re: Wheel offset from frame? [Re: beans n toast] #325612
07/30/10 9:03 pm
07/30/10 9:03 pm
Shingle Springs, California
Roadwarrior Online content
Roadwarrior  Online Content
Beans, can you post a picture?
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Re: Wheel offset from frame? [Re: Roadwarrior] #325956
08/01/10 10:10 pm
08/01/10 10:10 pm
Toronto
Toronto
Well, gents, looks to be a bent swingarm. frown
Anyone have a straight pre-unit swingarm for a 57 t110?
b
1957 T110
Re: Wheel offset from frame? [Re: beans n toast] #326032
08/02/10 10:21 am
08/02/10 10:21 am
Vic. Australia
Vic. Australia
If you decide to press it straight,put some neat-fitting pieces of solid shaft into the bushes to stop that area being squashed out-of-round.
If you're straightening it,over-bend it first to destroy it's memory;then press it back a little to the final straight position.
Page Time: 0.071s Queries: 15 (0.008s) Memory: 1.1011 MB (Peak: 1.3408 MB) Zlib disabled. Server Time: 2018-02-24 14:15:11 UTC
