mr britsh
mr britsh
adelaide....south australia..
40 registered members (Adam M.), 255 guests, and 472 spiders.
10291 Registered Users
Stuart 92
Lannis 66
Mori55 64
637,637 mail-order LSR
Topics67,392
Posts654,290
Members10,291
Swing arm spindle removal-pre unit #321650
07/05/10 2:13 pm
07/05/10 2:13 pm
Boston -
Mike667-neighbor of the beast Offline OP
Boston -
Hey Gang
debating on redo my swing arm now on my 62 T110 while oil tank and tool box are getting powdercoated or wait till winter - its real assed tight (have greased it up and hoping it will work in a bit) and has no detectable side to side play - seems like it will be a bitch to get the spindle out (Haynes manual doesn't really address it, workshop manual just suggest its a chore). I have done my norton's but the spindle there was threaded so you can use that to pull it out - any suggestions or secrets for the pre unit spindles that might persuade me to do it now??
thx!
mike
73 850 Commando
75 Ducati 750gt
78 Laverda 1200
97 Ducati 900 SS
61 BSA A10
62 Triumph T110
Re: Swing arm spindle removal-pre unit [Re: Mike667-neighbor of the beast] #321652
07/05/10 2:28 pm
07/05/10 2:28 pm
Jon W. Whitley Offline
If it ain't broke, don't fix it.
It IS a chore without a proper press. If it did need to come off..Hawaiin Tiger made a tool to remove the spindles on Pre-Units and may share with you how to make one and or it might be found in a search on this site per this subject.
Re: Swing arm spindle removal-pre unit [Re: Jon W. Whitley] #321672
07/05/10 4:12 pm
07/05/10 4:12 pm
Boston -
Boston -
thx Jon - will look up HT post - I was leaning towards leaving it too since no play in it, but w/ rest of bike done 'up was think about frame too
ok thx
mike
73 850 Commando
75 Ducati 750gt
78 Laverda 1200
97 Ducati 900 SS
61 BSA A10
62 Triumph T110
Re: Swing arm spindle removal-pre unit [Re: Mike667-neighbor of the beast] #321749
07/06/10 10:53 am
07/06/10 10:53 am
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
Listen to Jon!! It is a real pain. I know, Iv'e done it. Dick
Re: Swing arm spindle removal-pre unit [Re: Dick Harris] #321806
07/06/10 7:41 pm
07/06/10 7:41 pm
HawaiianTiger Offline
I used a Jag jack screw as the basis for this puller. Thanks to Dr. Jaguar (Ray) for the donation of the jack screw.
You've got a 62 T110? All the literature says that they were discontinued the previous year. Pictures?
Re: Swing arm spindle removal-pre unit [Re: HawaiianTiger] #321823
07/06/10 8:37 pm
07/06/10 8:37 pm
Los Angeles
tonupjonnie Offline
tonupjonnie  Offline
Los Angeles
I am in the middle of restoring a 1957 TR6 and did not have too harder time removing the Spindle with the use of Heat, Hammer and Drift, I am about to replace the Swing Arm Bushings, the manual calls for "Working Clearance", anyone have a more accurate clearance figure for the Swing Arm to Spindle Clearance?
Cheers, Jonnie.
Re: Swing arm spindle removal-pre unit [Re: tonupjonnie] #321838
07/06/10 10:32 pm
07/06/10 10:32 pm
It is a sliding fit which is as tight as you can get it and have it still move freely. It is best to have a machine shop do this who can insure that the bushings are machined in parallel.
Re: Swing arm spindle removal-pre unit [Re: HawaiianTiger] #321847
07/06/10 11:52 pm
07/06/10 11:52 pm
Los Angeles
tonupjonnie Offline
tonupjonnie  Offline
Los Angeles
Thanks Bill.
Jonnie Green
1948 Tiger 100
1952 Triumph 6T
1956 Triumph TR5R
1958 Triumph Tiger 110
1959 Triumph T20S Tiger Cub
1959 Triumph Bonneville
1961 Triumph T110
1964 Triumph T20M Tiger Cub
1965 Triumph Bonneville
1967 Triton
1968 Triumph Bonneville
Re: Swing arm spindle removal-pre unit [Re: HawaiianTiger] #322313
07/10/10 10:14 am
07/10/10 10:14 am
Boston -
Boston -
HT
sorry for delay in response - been in the garage sweating the other stuff
61 T110 - keep getting the year of it and my A10 mixed up...(and all the other wrecks in the garage)
will post pic later after together
that's an interesting spindle remover - have to think about that one
thx as always
73 850 Commando
75 Ducati 750gt
78 Laverda 1200
97 Ducati 900 SS
61 BSA A10
62 Triumph T110
