SBoyd
SBoyd
Virginia, USA
43 registered members (Al Eckstadt), 252 guests, and 473 spiders.
MikeA, Jay Gilling, scratchedtank, Magic Monkey, Hybris
10252 Registered Users
Lannis 64
NickL 48
606,169 mail-order LSR
Topics67,072
Posts650,871
Members10,250
SIDE COVER /COIL MT BRACKETS A50, A65 #32102
12/19/07 4:09 pm
12/19/07 4:09 pm
Elm Grove, Wisconsin
AIRMAX Offline OP
AIRMAX  Offline OP
I need guidance. I'm restoring two unit const twins; '67 a50 and '65 a65 twin-carb-bitsa. Neither basket had correct installation of the side covers or coils. With the A50, the PO drilled holes in the frame and put in threaded rod to hold the side covers on! I'm trying to get this area sorted back to stock configuration.
Anybody got pics of the correct coil mount bits and side cover bracket installations for these two bikes or direct me to appropriate resources? (Bacon=0, Factory Parts manual=0, Haynes/Clymer=0)
One of the bits I acquired from eBay is a straight "C" shape and with odie clips and appears to clamp the coils horizontally, the only pics I've found suggest this might be for early unit Spitfire. I have another that appears to be a twisted "C" shape with odie clips in the end. I can't figure out how either would fit. How do either of these parts attach to the frame? I think I must be missing some small brackets or tabs. The a50 came with coil brackets that mount both coils directly under the single carb. Doesn't fit well, twin carb setup?
I'll try and get pics soon.
It's winter here, nothing better to do than get these guys up and running. There's good info out there and here for just about every other aspect of unit twin restoration, but I've hit a wall when it comes to this coil and side cover mount issue.
Any help would be appreciated.
Tod - Milwaukee Wisconsin
Currently riding 5 of 11
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32103
12/19/07 4:39 pm
12/19/07 4:39 pm
Rich B Offline
Rich B  Offline
The coil mounting/side cover mounting is "interesting" on that vintage. The straight "C" shaped bracket is, without pictures and guessing, the correct bracket. It requires brackets P/N 68-9279 TS and 68-9278 on the DS to mount. Coil mounting is crude. TS coil hangs from the bottom hole of 68-9279 bracket vertically. DS coil mounts horizontally from the tab on the frame on the DS to mount bracket 68-9278. The "C" shaped bracket is attached to the top holes of the 2 brackets.
Not sure what you mean by the shape of the other bracket. 68 on had a simpler mounting arrangment for the sidecovers. It was a "C" shaped bracket with vertical brackets on the end to mount the side covers. It had no adapter brackets to mount it to the frame. The coil brackets were somewhat complex on the later bikes eek
If I wasn't semi crippled at the moment and lazy :p , I'd take the side covers off my 65 and take a picture.... Until those 2 conditions pass....maybe someone else can post a picture laughing
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32104
12/20/07 3:49 am
12/20/07 3:49 am
AIRMAX Offline OP
AIRMAX  Offline OP
Rich,
Here are some photos
The '67 A50 project, some '68 parts (pipes, TLS Brake, tank etc.) included by PO.
I'm putting a 650 single carb top end on it.
I believe this is the bracket you described with 68-9278 and 68-9279. Is it for single carb, twin carb or both? How does lip in the C shaped bracket clear the lips on the fram brackets?
Can you identify which year and model this bracket and coil mount system are intended for?
IMG]http://i266.photobucket.com/albums/ii241/tstansfield/108-0881_IMG.jpg[/IMG]
I guess I need to source a 68-9340.
Thanks for your help.
Tod S. Milwaukee WI
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32105
12/20/07 4:27 am
12/20/07 4:27 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Tod,
The best source for indentifying parts on multiple years is the CD: Kim The CD Man. It has all the parts manuals and more. It is available on the site. Look along the left column in Red. I use the CD almost everyday.
What model '67 A50 do you have? I'm looking for a Wasp (A50WA).
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32106
12/20/07 4:37 am
12/20/07 4:37 am
Mark Z Offline
Mark Z  Offline
The long C-shaped bracket and the straight coil bracket look like those on my '67 A65L. On the straight coil bracket, the hole that's about halfway down is where it mounts to the frame. You should have two tabs with threaded holes sticking straight up off the frame cross-tube. The left-side coil clamp looks correct, but there should be another piece between it and the side panel bracket, with a hole for mounting to the frame, like on the other side. Looks like a '67 Factory Spares manual (and a '65 as well) would help greatly here.
When you get it all back together, note that the side panel bracket can be moved to the left or the right when the mounting bolts are loose. You should leave the bolts a little loose, mount the side panels, and then move the bracket so that there is equal tension on the panels and oddie clips, then tighten up the bolts. Failure to center the bracket will cause one panel to rattle and the other one to crack.
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32107
12/20/07 12:48 pm
12/20/07 12:48 pm
Rich B Offline
Rich B  Offline
That is 68-9279 bracket mounted correctly. The lip seems to me to keep the coil clamp from rotating.
That is the correct arrangement for dual carb (and probably most single carb) bikes from 65 - 67. There was also a strange mounting system used by early single carb that actually used the carb studs to mount the bracket. The arrangement you have may have also been used on 64 Hornet's (memory is a bit foggy and I am too lazy to check :p ).
You just need to find/make a 68-9278 bracket. You can use the existing bracket as a pattern if you want to make it. Just leave off the area under the middle hole.
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32108
12/20/07 4:31 pm
12/20/07 4:31 pm
AIRMAX Offline OP
AIRMAX  Offline OP
Thankyou a bunch guys.
The bike is a '67 Royal Star (A50RA38**)I bought it in '77 with some unusual 'upgrades' and some extra parts.
My last pic flubbed, I'll retry.
I've got these coil mts and another 'twisted' bracket (placed on my 2nd frame for illustration only). Can you describe what years/models the coil mt system is for? and is the side panel bracket supposed to be slightly twisted?
I have a factory spares manual but I'm having trouble visualizing these parts.
Tod S.
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32109
12/20/07 4:32 pm
12/20/07 4:32 pm
AIRMAX Offline OP
AIRMAX  Offline OP
P.S.
That CD looks great. I think I'll let Santa know.
Tod S.
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32110
12/20/07 4:46 pm
12/20/07 4:46 pm
Rich B Offline
Rich B  Offline
The coil brackets are for 68 on. Though I have seen some late 67's those brackets. Not sure if someone added it or another BSA mystery. They will work with whatever you are trying to build. Make sure you make a sketch or take pictures as you take them apart, they are tedious to reassemble.
The twisted "C" shaped bracket looks like an attempt by a PO to make that bracket work without using the 2 brackets I listed the P/N for above. Probably won't is my guess.
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32111
12/20/07 9:07 pm
12/20/07 9:07 pm
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32112
12/22/07 7:53 am
12/22/07 7:53 am
Norway
Ola Offline
Ola  Offline
Norway
Form Roy Bacons book:
Best regards
(Doug Hele, 1919 - 2001)
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32113
12/27/07 3:22 pm
12/27/07 3:22 pm
AIRMAX Offline OP
AIRMAX  Offline OP
Thankyou Rich, Alex, et al!
I've mocked up what I think is the correct configuration of bracketry for the twin carb style. Smaller bracket is a fabrication from steel strap. What do you think.
Ola, thanks for posting pics. My copy of Bacon has these pictures but the're a little too contrasty to reveal the level of detail I see here.
Happy Holidays!
Tod S. -- Elm Grove WI
Re: SIDE COVER /COIL MT BRACKETS A50, A65 #32114
12/27/07 3:49 pm
12/27/07 3:49 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
Now check to see if that works with the side covers.Slap a seat on there when you fitting them.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
