The Bonneville Shop
MotorEddy
MotorEddy
Lancashire, UK
46 registered members (Al Eckstadt), 311 guests, and 394 spiders.
JD8, John Rowley, Zoot, sal pisciotta, Shawn G
10529 Registered Users
franko 89
Lannis 82
NickL 72
785,984 mail-order LSR
Topics69,227
Posts674,397
Members10,529
A65 valve guide replacement #318559
06/15/10 12:38 pm
06/15/10 12:38 pm
Farnham, Surrey, UK
gunner Online content OP
gunner  Online Content OP
Farnham, Surrey, UK
Ive been inspecting the valve guides on my 68 Firebird head and have noticed that the valves can be rocked back and forth slightly, indicating worn guides.
So IM now looking at my options for replacing the guides and am considering doing it myself.
I have some questions:-
- how easy it it to fit new guides? The BSA manual suggests that a suitably sized drift can be used to knock them out but what about refitting?
- how do you ensure the new guides are concetric with the seats?
- do the new guides need reaming to fit the valve stems?
- what type of guides are best, iron or bronze?
- do the seats need to be recut and is this a diy job?
All info welcome
Re: A65 valve guide replacement [Re: gunner] #318572
06/15/10 1:30 pm
06/15/10 1:30 pm
It really depends on your level of experience and confidence. Replacing the guides themselves is really very straightforward as you have stated. All you really need is a suitable drift and some way to heat the head.
You don't. Replacing the guides almost guarantees that the seats need to be cut. Since the cutter uses the guide as a pilot, concentricity is guaranteed in this way.
IME, most Bronze ones do, most iron guides don't.
This really can open up a can of worms, particularly when it comes to which brand of bronze guides to use. Cast iron guides are often more durable and generally don't have problems with sticking...and they usually don't have to be reamed and honed as stated above.
I would never replace guides without cutting the seats. NewWay makes a relatively inexpensive ($400 US) cutter set for a three-angle valve cut that leaves a superior valve seat with a bit of practice and care. Worth it if you're going to do this a few times...
Re: A65 valve guide replacement [Re: Alex] #318581
06/15/10 2:26 pm
06/15/10 2:26 pm
Farnham, Surrey, UK
Farnham, Surrey, UK
Thanks for the info, looks like iron guides then.
Next question, (and I know this is an age old issue), do you heat the head to remove/replace the guides or do it cold?
Re: A65 valve guide replacement [Re: gunner] #318613
06/15/10 5:53 pm
06/15/10 5:53 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
The first thing you do is clean ALL the carbon off the guides,inside the ports.The best way is by soda-blasting.
If you want to minimize damage to the head,and also make the guides easier to remove then drill them part-way through.Starting from inside the port,drill the guide bore bigger,but not all the way through.Core them out until the wall thickness is 0.040" or less on any part of the guide that has an interference fit in the head.
Find or make a punch that will fit in cored-out section of the guide and stop against the un-drilled section.The advantage of this (besides reducing the wall thickness of the guide)is that the guides are removed in tension,so they are drawn thinner when you punch them.
Put the punch in the freezer,and heat the head in an oven to 150-160 C.Each time you punch out a guide,put the punch back in the freezer and the head back in the oven.
When the old guides are out and the head has cooled,measure the guide holes in the head.The new guides should have 0.001"-0.0015" interference if they are bronze;not less than 0.0015" interference if they are iron.
Before you fit the guides,coat them with moly grease and put them in plastic bags in the freezer.The punch you use should also go in the freezer.If this punch locates in the guide bore,make sure the corner radius is under-cut to avoid flaring the top of the guide.Heat the head again to 150-160 C.
When the guides are fitted and the head has cooled,you must measure valve-stem clearance in the guides (measure the stems,and measure the guide-bores).Before you do any reaming,the tightest part of the guide will be close to the centre.
Iron guides can run about 0.001" tighter than bronze guides.
Let the experts cut the seats if they can guarantee less than 0.001" runout.
Re: A65 valve guide replacement [Re: Pete R - R.I.P.] #318635
06/15/10 8:42 pm
06/15/10 8:42 pm
FYI, I never heat the head to drive out the guides. There's just not enough difference in CTE for the guides to loosen significantly. Never had a problem yet. I always heat the head and freeze guides to drive them in.
Re: A65 valve guide replacement [Re: gunner] #318657
06/16/10 12:00 am
06/16/10 12:00 am
Farnham, Surrey, UK
Farnham, Surrey, UK
Great answers guys, thanks
Re: A65 valve guide replacement [Re: gunner] #318696
06/16/10 7:13 am
06/16/10 7:13 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The factory had a tool for installing guides reasonably centered to the existing seat. I made one by cutting a 45 degree taper on an alloy plug that will sit in the seat and a 1/4" coarse threaded rod in the port end of the plug that goes through the guide hole. The new guide is put on the rod with an old guide as a pusher and a coupling nut. Wind the coupling nut down the rod and push the guide in place. Less chance of whacking in the guide crooked with a hammer. For removal, I use a long 3/8" Allen head bolt with the threads turned down to 5/16" to fit in the guide.
Re: A65 valve guide replacement [Re: DMadigan] #318700
06/16/10 8:36 am
06/16/10 8:36 am
BSA_WM20 Offline
BSA_WM20  Offline
I bought a removal tool nearly 40 years ago.
A stepped ball shaped head ( locates on the seat ) with a long threaded rod through it.
The remover is a threaded sleeve that screws down the shaft and bears against the guide.
Bog simple , works a treat.
Never thought of boring out the guide but I can see the logic in it ( one to add to the list)
Re: A65 valve guide replacement [Re: BSA_WM20] #318705
06/16/10 9:33 am
06/16/10 9:33 am
Au
markoz Offline
markoz  Offline
Au
This can be one of the cheapest jobs to get done by a pro get them to clean the head for you at the same time and it will look good and save you a lot of grief. Mark
Re: A65 valve guide replacement [Re: markoz] #318718
06/16/10 11:56 am
06/16/10 11:56 am
Mark Parker Offline
Mark Parker  Offline
Rather than replacing the guides why not have them K/lined the guides are bored a liner pressed in and sized. They can run quite tight clearances esp with a Nitrided valve. Usually they are pretty well aligned but doing a three angle seat is well worth the effort. Ever since useing some grinding stones I'm converted to that method. What you don't want is a head shop cutting the seats deep using a 3 angle cutter in a machine. The little hemi head needs the top cut to blend with the chamber not be down a step. If the valves are sunk into the head; using O/size valves or seat inserts can get the valve back up where it should be. Head shops can do seat inserts quite cheaply.
Re: A65 valve guide replacement [Re: Mark Parker] #318833
06/16/10 11:40 pm
06/16/10 11:40 pm
Jerseyville, Illinois
ljm Offline
ljm  Offline
I just had a total rebuild on my 65 Hornet head. Like Mark Parker said I opted for the K/line insert. Turned out perfect. The seats were cut just like using the old guides. The line up is darn near perfect. I used Ed V's valve springs and NOS valves.
ljm
