lit67
lit67
Central Illinois, USA
33 registered members (Adam M.), 258 guests, and 85 spiders.
10389 Registered Users
NickL 98
Triless 88
Mori55 83
reverb 80
Rohan 80
DavidP 72
btour 66
690,580 mail-order LSR
Topics68,051
Posts662,152
Members10,389
best way to set the timing on 1965 a65 #316329
06/01/10 6:35 am
06/01/10 6:35 am
busy Offline OP
busy  Offline OP
i'm removing the old points on my bike and replacing them with a pazon
ignition whats the best way of getting TDC
I bet someones going to tell me to adjust the primary chain and check the valve
settings first !!
Re: best way to set the timing on 1965 a65 [Re: busy] #316332
06/01/10 7:04 am
06/01/10 7:04 am
Finland
FinBSA Offline
FinBSA  Offline
Finland
U donīt need to know TDC when u install Pazon. I think you have the full advance mark (spike) in primary cover which is lined up with alternator rotors marking and then you line up pazon rotors paint dot with pickup plates anti-clockwise hole.
Or is there full adv mark in 1965 model? At least in 1969 model there is.
BSA 650 Lightning `69
Re: best way to set the timing on 1965 a65 [Re: busy] #316333
06/01/10 7:11 am
06/01/10 7:11 am
No wink , buy or make a piston stop that screws in a sparkplug hole, mount a degree wheel on the crank semi loose and then find the forward and reverse stop points and move the degree wheel so they are at equal degrees on the scale, in between at 0 is TDC. Lock the degree wheel to the crank and recheck, now remove the piston stop and move the crank to your fully advanced timing point and make a mark that a pointer can be mounted near on the rotor. You can now strobe your engine with the primary cover off.
Finbar, 65 Primary covers have no timing cover to use so you must make your own arrangments, TDC is the first point to measure.
Re: best way to set the timing on 1965 a65 [Re: kommando] #316361
06/01/10 12:38 pm
06/01/10 12:38 pm
busy Offline OP
busy  Offline OP
HI kommando
thanks as usual (this is a great forum)
when you mean a piston stop that screws into the spark plug hole
do you mean one of those TDC tools that screws into the spark plug hole ?
and what is the fully advanced timing point (degrees) for my 65 a65
Re: best way to set the timing on 1965 a65 [Re: busy] #316377
06/01/10 1:39 pm
06/01/10 1:39 pm
Take an old spark plug, cut off electrode, bust out the ceramic, thread with a 3/8 tap (10 mm works, too) and thread in an appropriate bolt.
Re: best way to set the timing on 1965 a65 [Re: Alex] #316384
06/01/10 2:32 pm
06/01/10 2:32 pm
As Alex says for the piston stop, I use a piece of wooden dowel epoxied in instead of a bolt. Don't have an A65 so don't have the timing data.
Re: best way to set the timing on 1965 a65 [Re: kommando] #316454
06/01/10 7:19 pm
06/01/10 7:19 pm
Finland
FinBSA Offline
FinBSA  Offline
Finland
Full advance for A65 would be 34 degrees BTDC.
http://sahkourakka.com/kauppa/Ajoitus.gif
