Two Alpha
Two Alpha
North Coast, BC, Canada
201 registered members (79T140E), 2,170 guests, and 562 spiders.
GabrielSoren, JoshP, spikey45, trevor's, myshootingstar68
10077 Registered Users
NickL 87
koan58 85
Lannis 81
504,148 mail-order LSR
Topics66,033
Posts639,137
Members10,077
A65 HA Frame issues #3154
06/23/05 8:34 pm
06/23/05 8:34 pm
Central Ohio
Steve in Ohio Offline OP
Central Ohio
I was putting the oil tank on the project bike (engine is a '68 Lightning) and hit a snag. No way were the oil feed lines going to fit in the appropriate hole so I started to check for frame #'s (I hadn't ever done that) I find that the frame is an A65 HA (can't read the rest) so one book tells me it is a '67 Hornet frame. My ?. is there a specific oil tank for that frame? I do have a tank that is supposed to be a hornet tank, but it is way to big to fit unless there is a special way of screwing it in plus the one I tried to install. Any help would be appreciated. I just want to get the engine running after a complete rebuild.
Steve in Ohio
'68 A65 Bitsa
Re: A65 HA Frame issues #3155
06/23/05 10:26 pm
06/23/05 10:26 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
Steve , A few pics might help , but a few thoughts come to mind . First , is it possible that you have an oil tank from a unit single there ? I have had some from B-44 that look nearly identical to the A-65 other than the oil line routing .Also , it is usually much easuier to install the oil tank with rear fender and tool tray removed . Finally , I have seen the larger oil tank on the Hornets , batteryless systems . This might be able to fit your frame , maybe some minor mods?(different tabs??) but there wont be room for a standard battery . If you dont plan to use this , I might be interetsed in swapping something for it, I like the idea of more oil capacity .
FWIW-BONZO
Page Time: 0.056s Queries: 14 (0.006s) Memory: 0.9906 MB (Peak: 1.1058 MB) Zlib disabled. Server Time: 2018-02-23 00:35:18 UTC
