maylar
maylar
Connecticut
35 registered members (AML), 234 guests, and 451 spiders.
10257 Registered Users
Stuart 77
Lannis 60
TBolt72 46
609,133 mail-order LSR
Topics67,118
Posts651,344
Members10,257
Easier starting Commando #315380
05/26/10 8:57 pm
05/26/10 8:57 pm
redondo beach, ca
Bob G Offline OP
Bob G  Offline OP
redondo beach, ca
I just got a 73 750 running for a friend after it had been sitting for over 10 years.
I can start it on the first or second kick. However my friend only weighs 160 pounds and is just about impossible to him to start.
What can i do to make it an easier starting bike? It has a 34 vm Mikuni Conversion and analog Boyer. He is only going to be using it for short hops around town, no freeways.
My first thoughts are to fudge the tuning specs a bit. Plug gap, timing, valve adj. What direction would I need to go on those?
My second thought is to lower compression. What is the best way to go about that? Any ideas are greatly appreciated.
Bob Gregor
Re: Easier starting Commando [Re: Bob G] #315397
05/26/10 10:54 pm
05/26/10 10:54 pm
California U.S.
Hortons Norton Offline
California U.S.
I would look into the longer kick start arms that are now on the market, Should give him more leverage. If the bike is tuned right I would not think you would want to mess with that.
Re: Easier starting Commando [Re: Hortons Norton] #315401
05/26/10 11:00 pm
05/26/10 11:00 pm
redondo beach, ca
Bob G Offline OP
Bob G  Offline OP
redondo beach, ca
Thanks, I was not aware of the longer starter arms. That would probably do the trick. He can almost start it now.
Bob Gregor
Re: Easier starting Commando [Re: Bob G] #315408
05/26/10 11:30 pm
05/26/10 11:30 pm
redondo beach, ca
Bob G Offline OP
Bob G  Offline OP
redondo beach, ca
Would you by any chance know who is selling them? I did a quick search on google and eBay and couldn't locate any
Bob Gregor
Re: Easier starting Commando [Re: Bob G] #315424
05/27/10 1:16 am
05/27/10 1:16 am
Orlando fla/ shady valley Tn
bill50cal Offline
bill50cal  Offline
I remember back when I bought a high compression 72 combat and at that time I was only about 135# and it was my daily transportation so I very quickly learned how to kick start it . the starting thing is ALL ABOUT TECHNIQUE now that I have bulked up in my old age and tip in at 200# I can start mine off the stands and with great ease.
windy
72 combat
switchbackcreek.com
Re: Easier starting Commando [Re: bill50cal] #315440
05/27/10 3:22 am
05/27/10 3:22 am
British Columbia
hh Offline
hh  Offline
British Columbia
Unless it's zero degrees, it's full of 60W and it's got 11:1 compression pistons, a stock 750 should be easy to start for someone weighing 160 lbs. Tell him to engage the kicker pawl and then throw his weight down on it.
Re: Easier starting Commando [Re: Bob G] #315441
05/27/10 3:25 am
05/27/10 3:25 am
Mercer Island, WA / Austin, TX
Rick in Seattle Offline
The analogue Boyer provides too much advance at start-up, 11 degrees or so. It is prone to kick-back. Replace it with either a Pazon SureFire (0 degrees at start-up)or, at more expense, a TriSpark or Boyer MD (5 degrees). The Pazon is available at $120 or so directly from Pazon. My Mikuni-fitted, Pazon-fitted Mk3 starts with a soft push-through on first kick, when I'm not inclined to push the starter button.
Rick in Seattle
1970 BSA 441 Victor Special
1972 Norton Commando 750 Combat
1975 Norton 850 Commando Mk3
1960 Triumph TR3A
Re: Easier starting Commando [Re: Rick in Seattle] #315446
05/27/10 6:29 am
05/27/10 6:29 am
Rick in Seattle +1 , RGM in UK do the longer kickstarts. Both combined will get him sorted. He can also help himself by treating it as asingle cylinder bike, move the kickstarter slowly to find TDC then ease it just over TDC, he can then position the starter lever to how he likes before the big kick. As the bike is just after TDC it gives least resistance and gives him time to get the crank upto speed before the next TDC, the flywheel at speed will take it over the next TDC easily.
Re: Easier starting Commando [Re: kommando] #315476
05/27/10 12:51 pm
05/27/10 12:51 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
The Alton electric starter conversion kit for pre-MkIII Commandos should be on the market soon.
http://www.alton-france.com/en/index.php
(photo originally posted on the accessnorton [Norton Commando] forum by "doug")
Re: Easier starting Commando [Re: L.A.B.] #315479
05/27/10 12:57 pm
05/27/10 12:57 pm
GrandPaul Offline
GrandPaul  Offline
I weigh about 140 and there isn't a Commando I've come across that I was unable to start after tuning it properly (by the book). I like Sparx, but want a box full of Tri-Sparks.
Re: Easier starting Commando [Re: GrandPaul] #315621
05/28/10 3:25 am
05/28/10 3:25 am
redondo beach, ca
Bob G Offline OP
Bob G  Offline OP
redondo beach, ca
Thanks, lots of great ideas. The bike in my opionion is a normal starting Commando. My buddy is a little on the feeble side and is having a hard time grasping the technique of kickstarting.
I think I will start off with an ignition change.
Bob Gregor
Re: Easier starting Commando [Re: Bob G] #315668
05/28/10 12:45 pm
05/28/10 12:45 pm
GrandPaul Offline
GrandPaul  Offline
Good idea, ONE THING AT A TIME.
If you do multiple changes and then the bike doesn't run right, you may be working one problem against another.
Re: Easier starting Commando [Re: GrandPaul] #315936
05/29/10 9:04 pm
05/29/10 9:04 pm
Having lived with my Commando for 27 years I've got the secret to starting it quite pat. First, the previous poster was correct, the Commando is harder to start with the old fashioned now old school Boyer. I never liked the single Mikuni on my bike either and as soon as I was able I went back to properly refurbished Amals (AMR)
1. Turn on gas.
2. Tickle carbs just until the gas shows
3. Ignition off, give one kick.
4. Ignition on and ease the engine to the top of the compression stroke and kick
Sometimes my bike starts when I am easing the piston to TDC.
If it doesn't start after a couple of kicks, you've likely flooded the engine. Kick through a few times with throttle WFO and repeat steps 2-4.
I understand about the "feeble" quality of some owners. Perhaps they would be better off with a bike that doesn't even come with an optional kick starter.
Its an owner/bike mis-match.
Re: Easier starting Commando [Re: HawaiianTiger] #315961
05/29/10 11:05 pm
05/29/10 11:05 pm
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
I do as Hawaiian Tiger. My 73' starts, first ignition-on kick, at least down to 30 degrees trmperature. I haven't tried it colder than that. Its all stock, I did replace a worn AAU unit. Carbs, jetting, points, and timing is to the book. It starts and runs without fail. I have a more difficult time to RE-start HOT. Ambient 90 degrees and above.. Running, shut down, heat soak for 20-30 mimutes and then start. Prone to stall under those conditions and does not idle properly until run and air cooled down the road. I think too, owner/bike mis-match. Unless he is willing to love and learn. And as Bill50Cal says, ALL ABOUT TECHNIQUE. You really don't "kick" the bike to start it. ???
Re: Easier starting Commando [Re: nert] #316154
05/31/10 1:40 am
05/31/10 1:40 am
Springfield Nebraska
Richrd Offline
Richrd  Offline
Bill50 doesn't weigh 200 even in soaking wet leathers and socks!!!
U
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Easier starting Commando [Re: Richrd] #316161
05/31/10 2:28 am
05/31/10 2:28 am
New Zealand
johnm Offline
johnm  Offline
New Zealand
Yes.
If you don't put in the time to learn how to start it - then you really shouldn't really be riding it.
A good Commando will just about start if you look at it sideways !!! . You can put it on its stand. Stand off to the side, hands in pockets, push the kick start down with your toes and it will start.
The analogue Boyer do provide too much advance at start-up. They are prone to kick-back.
Follow what Hawaiian tiger says.
Re: Easier starting Commando [Re: johnm] #316292
05/31/10 11:22 pm
05/31/10 11:22 pm
Richrd Offline
Richrd  Offline
I agree with everything but..........
I weigh 120 after a big meal with leathers, and have boyers on both Nortons.
They NEVER kick back unless the voltage is low. and that's only
if I let them sit too long in the garage.
and the Snake Bike
and a Honda?
Moderated by  Dave Comeau
