Barb
Barb
Western Washington State (USA)
25 registered members (Andy Higham), 185 guests, and 405 spiders.
10256 Registered Users
Stuart 75
Lannis 66
608,497 mail-order LSR
Topics67,110
Posts651,229
Members10,256
B Magneto Help - No Spark #312463
05/09/10 9:58 pm
05/09/10 9:58 pm
PA
maximini Offline OP
maximini  Offline OP
PA
I was hoping that some of the experts might help me with a magneto problem. I pulled my B34 out after the winter and could not get it started. Checked it over and found no spark. I tested the HT wire and spark plug and both are fine. I did notice a very small spark between the contact breaker points. The bike worked just fine when put away for the winter.
I'm obviously no Lucas magneto expert! Does anyone have any hints.
Re: B Magneto Help - No Spark [Re: maximini] #312472
05/09/10 10:56 pm
05/09/10 10:56 pm
Ontario , Canada
RGSROB Offline
RGSROB  Offline
Ontario , Canada
Assume you have all ready removed plug cap from HT lead and tried to see if there is a spark directly from the HT lead.follow this logic down to the pick up brush. Also the points can sometimes get a corrosion film on them that acts as an insulator -First try cleaning the points.
Also see if there is any evidence of up and down play at the points end. if so your petaled insulating washers around the mag bearings are goners and must be replaced.
I doubt if it is the condenser in the armature as they usually only decide to quit when hot.
Re: B Magneto Help - No Spark [Re: RGSROB] #312838
05/11/10 9:11 pm
05/11/10 9:11 pm
PA
maximini Offline OP
maximini  Offline OP
PA
Thanks for the reply Rob. I cleaned the points and set the gap. I notice that I am getting intermittent spark that will jump about a half inch to ground. I removed the pickup, cleaned it and then cleaned the slip ring inside the magneto. I tested the continuity through the pickup and it seems okay. When I kick it I get a pretty strong spark, but then no spark for the next several kicks, then one spark again. Any ideas? I'm stumped.
Re: B Magneto Help - No Spark [Re: maximini] #312923
05/12/10 10:34 am
05/12/10 10:34 am
Ontario , Canada
RGSROB Offline
RGSROB  Offline
Ontario , Canada
sounds like you may have to take the mag off and disassemble.
First check for up and down play as i said previosly.
I have seen quite a few mags recently where the petaled fibre insulating washers are allowing the armature to go to ground
Re: B Magneto Help - No Spark [Re: RGSROB] #313046
05/12/10 11:47 pm
05/12/10 11:47 pm
BSA_WM20 Offline
BSA_WM20  Offline
What type of HT lead are you using ?
This is exactly how graphite ( silicone) car leads behave.
It is essential that you use either a solid copper conductor or even better are the spiral wound leads any thing else will give you grief often intermittantly and drive you crazy
Re: B Magneto Help - No Spark [Re: BSA_WM20] #313209
05/13/10 11:47 pm
05/13/10 11:47 pm
PA
maximini Offline OP
maximini  Offline OP
PA
I'm using a HT lead with stranded wire core. I am getting spark with the plug out, but if I put a plug in and create compression, no spark
Re: B Magneto Help - No Spark [Re: maximini] #313454
05/15/10 9:41 am
05/15/10 9:41 am
BSA_WM20 Offline
BSA_WM20  Offline
No spark with new "clean" plugs or no spark with old plugs ?
Modern "fuel" will quickly coat the electrodes and is quite conductive at cylinder pressure.
Pull one out , hold it upside down and "cook" the thread with a strong flame ( oxy ).
If there is a deposit there it will start to burn off and yield a quite yellow ( rich) flame.
Re: B Magneto Help - No Spark [Re: maximini] #313568
05/16/10 4:56 am
05/16/10 4:56 am
Santa Barbara, Cal.
Bodger Offline
Bodger  Offline
Santa Barbara, Cal.
before tearing up the mag any further at least try a new plug...easy and cheaper and quick...then tear the mag down grin
under compression iffy plugs may not do it.
hey, you needed a known good spare, right?
Re: B Magneto Help - No Spark [Re: maximini] #313648
05/16/10 3:13 pm
05/16/10 3:13 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
The fact that you're getting a strong, but intermittent spark makes me think that perhaps your points may not be 100% cleaned up. Could be that you still have a spot of oxide remaining, which will prevent the points from making a good closed contact every once in a while.
I would remove the points and scrape them clean, ensuring there are no pits or oxide remaining. Then, for good measure, coat with a preservative like Electrolube.
.. Gregg
magneto@spyder-it.com
Re: B Magneto Help - No Spark [Re: gREgg-K] #313969
05/18/10 1:02 pm
05/18/10 1:02 pm
PA
maximini Offline OP
maximini  Offline OP
PA
Thanks to all for all the tips. I changed the points to my spares set, which are brand new and surgically clean and replaced the plug - but the problem persists.
I obtained a spare mag that was recently rebuilt from a friend, but the manual advance/retard control cable threads are stripped. Does anyone know if I can take a spare left-hand end cap(complete with cam face, etc.) and swap it for the stripped right-hand end cap?
I'll use the spare mag until I can get the original refurbished.
Re: B Magneto Help - No Spark [Re: maximini] #314145
05/19/10 9:11 am
05/19/10 9:11 am
BSA_WM20 Offline
BSA_WM20  Offline
Yes.
