coopers
coopers
australia
195 registered members (1xfatboy), 1,788 guests, and 605 spiders.
10032 Registered Users
Lannis 144
kommando 103
Stuart 67
476,618 mail-order LSR
Topics65,721
Posts635,216
Members10,032
Wal Phillips injector #311918
05/06/10 5:43 pm
05/06/10 5:43 pm
dave jones Offline OP
Whatever happened to these things? I was reading an old mag from the 60s and it had an article about them replacing carburettors to good effect. I don't want one, just curious.
Re: Wal Phillips injector [Re: dave jones] #311919
05/06/10 6:08 pm
05/06/10 6:08 pm
Reading UK
twinspin Online content
twinspin  Online Content
Reading UK
I don't know what happened to them but I remember seeing adds for them and actually saw one or two fitted. They looked pretty crude affairs with a butterfly valve and seemed to be directly connected to the fuel tap without a reservoir from memory so there was probably some metering linked to the throttle. I think they worked though.
1971 T100R
1970 T120
Re: Wal Phillips injector [Re: dave jones] #312024
05/07/10 8:31 am
05/07/10 8:31 am
QLD, Australia
RetroRod Offline
RetroRod  Offline
QLD, Australia
Hi Dave,
I can remember a fella fiddling around with one of these on a TR6 in the mid-sixties. For whatever reason they never did catch on. RR
'72 Bonneville
"He who praises you for what you lack wishes to take from you what you have." - Don Juan Manuel
Re: Wal Phillips injector [Re: RetroRod] #312064
05/07/10 1:42 pm
05/07/10 1:42 pm
There has been a little discussion here from time to time about them. A quick search turned up this.
http://www.britbike.com/forums/ubbthread...=true#Post55864
Re: Wal Phillips injector [Re: shel] #312071
05/07/10 2:49 pm
05/07/10 2:49 pm
Rhode Island
cabletech Offline
cabletech  Offline
Rhode Island
This is what it looks like.
1983 Husqvarna WR430
1973 T150
1974 T150
1975 T160
1975 T160
I'm now a triple Freak!
Re: Wal Phillips injector [Re: cabletech] #312090
05/07/10 5:55 pm
05/07/10 5:55 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
Looks like Old Wal was rather loose in his use of the term"fuel injector". Jack
Re: Wal Phillips injector [Re: Jack Adams] #312094
05/07/10 6:24 pm
05/07/10 6:24 pm
It wasn't really an "injector" ... it just dribbled metered fuel into the venturi and off you went.
Good for drag-racers and hillclimbers, and some speedway bikes had them. If you look at the operation, it was good for constant full throttle and almost nothing else ....
We're approaching the tipping point ... where those who vote for a living will outnumber those who work for a living .....
Re: Wal Phillips injector [Re: Lannis] #312102
05/07/10 7:15 pm
05/07/10 7:15 pm
I forgot where I read it, but it was an old article, describing it as a pre carburettor fuel / air mixing device for stationary petrol engines running on a more or less constant load.
It is certainly not an injector. An injector is a pump and nozle device. This is not.
So if an injector is called an injector because it injects, this could be called a dribbler.
Re: Wal Phillips injector [Re: Ger B] #312105
05/07/10 7:29 pm
05/07/10 7:29 pm
Tridentman Online content
Tridentman  Online Content
Lannis hit it on the head.
Wal Phillips if I remember correctly was a speedway rider/manager in UK in the 1960s.
He originally developed the WP Injector for speedway bikes.
Hence no real importance placed on part throttle operation, idling or gas economy but every emphasis on flat out power.
HTH.
