Mike-71-650
Mike-71-650
Al, Birmingham
196 registered members (79T140E), 2,138 guests, and 585 spiders.
koan58 90
Lannis 88
NickL 86
505,871 mail-order LSR
Topics66,065
Posts639,435
Amal 276 float height #311209
05/03/10 3:25 am
05/03/10 3:25 am
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
Having a great time breaking in the new engine by taking the long way to work on the coastal roads. The Sppedtwin is running great except that it doesn't like to idle once its hot. Starting the bike usually takes a bunch of kicks, I go easy on the tickle cause it seems to flood too easily, but the bike will idle nicely once it starts cold. I usually ride for about a half hour and when I arrive the bike will usually shut itself down as I coast to a stop. Restarting the bike at this point is pretty hard and usually needs a good rest.
If I set the idle high it will run all day.
Im thinking this must be a carb issue. It is a new carb and I didnt do a clean out before installing. Does the pilot jet on the 276 use the same #78 drill to clean like on the 930's or is it something else. I know Ive read of people just using the wire from twisty ties.
Also, not having much luck searching for info regarding AMAL 276 float height setting. Can anyone run me through setting my float height or point me towards some documentation. I dont believe the owners manuals explains it for the 276, it does for the later monoblock.
Ive checked for air leaks and havent found any yet.
1951 5T Speedtwin
Re: Amal 276 float height [Re: kngkong] #311213
05/03/10 3:44 am
05/03/10 3:44 am
North Georgia, USA
RF Whatley Online content
RF Whatley  Online Content
North Georgia, USA
Mr Kong -
Sure. No prob.
The pilot jet you seek is under the small dome nut on the underside of the carb. Use a 1/8W wrench to remove the dome nut. Then a standard straight blade screwdriver to remove the jet itself. Do the usual blow though, look through. You should see straight through. The most common issue is a single drop of water blocking the jet.
Note the chamfered end. The pilot jet will leak and go rich if not seated tightly into the body. Run it in to about 1 ft-lb of torque, turn the fuel tap ON and gas should run out freely, then replace the nut.
Pilot jets are numbered and available in various sizes. #25 and #30 are the most popular, I believe.
The float level on all Monoblocs is at the "pip" in the middle of the round cover, right smack in the middle of the word "AMAL". With the pilot jet dome nut removed, place a 6" piece of clear 1/8" ID tubing over the pilot, and make a U-turn so that the open end lies on the float bowl cover. Turn ON the fuel and the liquid level should rise to the "pip".
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Amal 276 float height [Re: RF Whatley] #311218
05/03/10 4:10 am
05/03/10 4:10 am
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
Most excellent, thanks a lot RF! Been searching for days for that info.
Ill give all that a try.
Anything else you can think of regarding running worse when warm (ie, half hour ride on a nice cool day)?
1951 5T Speedtwin
Re: Amal 276 float height [Re: kngkong] #311220
05/03/10 4:21 am
05/03/10 4:21 am
Isn't the 276 carb the pre-Monobloc with the separate float chamber?
Re: Amal 276 float height [Re: Gordo in Comox] #311223
05/03/10 4:34 am
05/03/10 4:34 am
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
yeah, its the pre-Monobloc. Were those instructions for the Monobloc? I didnt realise.
1951 5T Speedtwin
Re: Amal 276 float height [Re: kngkong] #311426
05/03/10 10:19 pm
05/03/10 10:19 pm
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
can anyone help with the same info for pre-Monobloc?
1951 5T Speedtwin
Re: Amal 276 float height [Re: kngkong] #311435
05/03/10 11:24 pm
05/03/10 11:24 pm
United kingdom
Phil Beresford Offline
United kingdom
AMAL never published a fuel level for the Pre-Monobloc carburetter and there are no easily identifiable marks to judge it against. The weight of the float and the position of the groove in the needle were calculated to give the correct fuel level which was not expected to require adjustment. Three lengths of Mixing Chamber Union Nut were used to allow for the angle of downdraught on the carburetter and keep the fuel at the correct level.
There is a drilled and tapped hole in the float chamber boss that can provide an attachment for a tube to show the existing fuel level.
As the Speed Twin uses a carburetter with a 7 degree downdraught you have the option of adjusting the position of the float chamber relative to the carburetter. Moving it rearwards will raise the fuel level slightly.
The other adjustable option is the the thickness of the fibre washer above the float mounting boss.
The pilot jet is a drilling in the front edge of the jet block and is easy to get at and clean once the jet block is removed.
Of course, not idling and being hard to start when hot are also classic symptoms of a weakness in the ignition system. Have you checked the condition of the spark on both cylinders when the engine is hot?
Re: Amal 276 float height [Re: Phil Beresford] #311436
05/03/10 11:34 pm
05/03/10 11:34 pm
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
Thanks for the answers Phil. Ive been wondering what Ive doing wrong that I couldnt find much carb maintenance info on the 276. I noticed this morning when starting cold I got her to idle but I think it may be firing intermittently on only one cylinder at idle. If I raise the throttle it is definately firing on both. A little messing with the cables and it seemed to affect the mis-firing cylinder at idle.
I think Ill give the jet a clean out to make sure but I dont think its the culprit. Ill make sure the Im getting good connection to the mag on the offending cable.
To check spark when hot are you suggesting just taking out the plug and laying it on the cylinder to check for spark?
Though, I would think if I was having ignition issues with heat it would affect above idle as well? It doesnt feel like an ignition problem as it just plain shuts off as I get back down to idle after a ride. Hmmmmmm smile
1951 5T Speedtwin
Re: Amal 276 float height [Re: kngkong] #311438
05/03/10 11:56 pm
05/03/10 11:56 pm
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
also...
What is the cause of weak ignition when hot?
1951 5T Speedtwin
Re: Amal 276 float height [Re: kngkong] #311487
05/04/10 6:46 am
05/04/10 6:46 am
Mr. Kong,
The most common cause of weak ignition when hot on these bikes is a bad condenser, the second being a break in the windings of the mag's armature. For a diagnosis, try attaching a common automotive condenser to the kill button terminal to see if the spark intensity returns to normal. This may be your idle problem when hot but it seems to me unlikely. It probably wouldn't run well at any speed.
Re: Amal 276 float height [Re: HawaiianTiger] #311648
05/05/10 2:30 am
05/05/10 2:30 am
Wellington, NZ
kngkong Offline OP
kngkong  Offline OP
Wellington, NZ
Originally Posted By: HawaiianTiger
Mr. Kong,
Thanks HawaiianTiger!
Sounds like a good test. Ill try it but like you mention it might not be the problem. Ive started a new thread here regarding why Im only running on one cylinder as its not really related to float height.
And where do you attach the condensor? On the end of the mag? Just inline?
Thanks for the tip!
john
1951 5T Speedtwin
Page Time: 0.774s Queries: 15 (0.028s) Memory: 1.0698 MB (Peak: 1.2742 MB) Zlib disabled. Server Time: 2018-02-25 17:47:26 UTC
