Mike, in Idaho
Mike, in Idaho
orofino Idaho
42 registered members (Alan_nc), 262 guests, and 231 spiders.
10173 Registered Users
Lannis 94
reverb 86
Stuart 72
koan58 66
NickL 66
551,558 mail-order LSR
Topics66,576
Posts645,450
Members10,173
Cast Iron or Bronze Guides for A65? #30964
11/06/07 9:25 pm
11/06/07 9:25 pm
Gordo in Comox Offline OP
The winter plan calls for new valves and guides for my 1965 A65. Currently I have cast iron guides and steel valves but my supplier has both cast iron and bronze guides plus steel and stainless steel valves. What is the best combination?
Re: Cast Iron or Bronze Guides for A65? #30965
11/06/07 9:38 pm
11/06/07 9:38 pm
BSA_WM20 Offline
BSA_WM20  Offline
Gordo.
What type of guides depends upon what type of valves.
The guides need to be harder than the valves so that the stems wear rather than the guides as replaceing the valves is much easier than the guides and you can do it at infinitum with little problems for the head.
OTOH there is a very limited number of times that you can remove the guides before the head is cactus.
For this reason I have changed my ideas & go for guide sleeveing rather than guide changing.
If you do decide to replace the guides, remove the old ones first, then check the head for damage &/ or wear as often removal takes significant amounts of the head with them thus requiring you to replace them with oversized guides but you will not know till the old ones are out & you measure up ( or rather down) the hole.
Re: Cast Iron or Bronze Guides for A65? #30966
11/06/07 10:24 pm
11/06/07 10:24 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Phosphor bronze (Ampco 45 or similar) is used on modern engines. That with hard chromed stems will last. Plus you can put in oil seals.
Re: Cast Iron or Bronze Guides for A65? #30967
11/06/07 10:45 pm
11/06/07 10:45 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
I do not have good experience with phosphor bronze guides in A65 ( specially exhaust guides get used fast ). I changed them to cast iron + Black Diamond valves and after 1500 miles had a opportunity to check them ( seized engine smile ).
They didnt have any sign of getting worn - no difference comparing to the new ones.
Adam M.
Re: Cast Iron or Bronze Guides for A65? #30969
11/07/07 7:25 am
11/07/07 7:25 am
Norway
MiG16 Offline
MiG16  Offline
Norway
Cast iron has self-lubricating properties that bronze lacks. Cast iron could be an advantage when valve gear is inadequately lubricated.
Michael
Re: Cast Iron or Bronze Guides for A65? #30970
11/07/07 2:41 pm
11/07/07 2:41 pm
Ipswich England
wbabojo Offline
wbabojo  Offline
Ipswich England
I use 'COLSIBRO', an alloy of copper,silicon and bronze. This enables the guide to be made with a 0.001" valve to guide clearance. This makes for a quieter engine, less likely to bounce and rattle. I've had two BSA unit twins with this mod, work done by P.Seager Engineering, IPSWICH UK. He turns a guide from scratch on the lathe after measuring the head and rather than an off the shelf guide, his actually WORK and FIT properly. Highly recommended A+
Gavin
Re: Cast Iron or Bronze Guides for A65? #30971
11/08/07 12:54 am
11/08/07 12:54 am
hamilton on. can.
H
highway Offline
highway  Offline
H
hamilton on. can.
A Petro Canada told me the gas we're getting here,( unleaded, low sulpher, ethanol) no longer has any lubrication qualities. Transfer of bronze to the valve stem causing stickng or siezure is not uncommon. (mainly on Triumphs) I've switched to Rowe cast guides and black nitrated valves, no sticking and long life.
The vast majority of engines now use cast guides, high quality valves. Rick
Re: Cast Iron or Bronze Guides for A65? #30972
11/08/07 1:09 am
11/08/07 1:09 am
Auckland New Zealand
Lightning 7a Offline
Cast Iron guides for me every time valves are easier to replace than guides as suggested above Cheers
Re: Cast Iron or Bronze Guides for A65? #30973
11/08/07 10:30 am
11/08/07 10:30 am
bromley uk
norton bob Offline
norton bob  Offline
bromley uk
If the lubrication is poor (domminator)cast iron is the only way.If lots of oil you will need seals on a shorter guide(not good for support)Ho-Hum,round in circles,how about a rotary engine!
Re: Cast Iron or Bronze Guides for A65? #30974
11/09/07 5:16 pm
11/09/07 5:16 pm
gavin eisler Online content
gavin eisler  Online Content
iron exhaust guides and bronze inlets for me, maybe its just my bike but the bronze exhaust guides wore very rapidly.
pod
Page Time: 0.067s Queries: 14 (0.005s) Memory: 1.0533 MB (Peak: 1.2393 MB) Zlib disabled. Server Time: 2018-04-23 23:00:28 UTC
