Velo-Felo
Velo-Felo
Forest of Dean, Gloucestershire UK
37 registered members (Adam M.), 248 guests, and 84 spiders.
10383 Registered Users
NickL 98
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,477 mail-order LSR
Topics68,027
Posts661,821
Members10,383
How do you solder a stainless cable? #307465
04/10/10 9:26 pm
04/10/10 9:26 pm
Minnesota, US
Jim Hultman Offline OP
Minnesota, US
I've never been able to make up a control cable (clutch or brake cable) from a stainless inner. I have a stash of old Japanese cables I came across at a swap meet once that would make perfect custom cables, if only I could figure out a way to solder the ends. They are apparently stainless, and solder simply doesn't stick to them.
I've tried various methods, including a little tinning cup that I can melt the solder in and dip the end. Still no luck. I even tried sandblasting the end to make sure it isn't just some coating on the wire. I have a good stock of ends and fittings, and I can make cables easily if the inner isn't stainless.
So I thought I'd throw it out on the board and see if there is a trick or if perhaps it just can't be done. Of course since the cables I have were built somehow, I guess it's obvious that it can be done. I just don't know how. Does anyone know what I'm missing?
Re: How do you solder a stainless cable? [Re: Jim Hultman] #307467
04/10/10 10:23 pm
04/10/10 10:23 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
Jim,
I am sure there is a special flux for stainless steel, I seem to remember soldering it in the past.
You could always silver solder the nipples on.
Trev.
Re: How do you solder a stainless cable? [Re: trevinoz] #307470
04/11/10 12:01 am
04/11/10 12:01 am
Minnesota, US
Minnesota, US
Trev.
Tried that too. Nothing sticks to this crap.
Re: How do you solder a stainless cable? [Re: trevinoz] #307483
04/11/10 2:02 am
04/11/10 2:02 am
Minnesota, US
Minnesota, US
I think that is the answer, Trev, but what is the flux and where would I find it?
Re: How do you solder a stainless cable? [Re: Jim Hultman] #307487
04/11/10 2:17 am
04/11/10 2:17 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
yes you can,grainger has the fluxes and the solders. as an engineering exercise i soldered aluminum to stainless,304
Re: How do you solder a stainless cable? [Re: Jim Hultman] #307488
04/11/10 2:19 am
04/11/10 2:19 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
Re: How do you solder a stainless cable? [Re: Jim Hultman] #307491
04/11/10 2:29 am
04/11/10 2:29 am
JubeePrince Offline
JubeePrince  Offline
Hi Jim -
Try and look here:
http://www.azom.com/details.asp?Articleid=1178#_Brazing_(Silver_Soldering)
Just for grins I googled: "soldering stainless steel wire" Came up with a lot of hits...
HTH,
Re: How do you solder a stainless cable? [Re: JubeePrince] #307548
04/11/10 12:40 pm
04/11/10 12:40 pm
Minnesota, US
Minnesota, US
Originally Posted By: JubeePrince
Hi Jim -
Try and look here:
HTH,
Thanks for the link Steve. Looking at that, I'm afraid it's a bit over my head. I have no idea of what kind of stainless this is, and I have no idea of where to start. When they talk about soldering stainless, the considerations seem to be color and effects on food! And Graingers has all kinds of solder and flux, but that's the problem...TOO many.
But from what little I do understand about this, it appears to take a phosphoric acid based flux and a more than 50% tin content solder. Not likely to find that stuff out here in the boonies where I live, and I can't seem to figure out what to order from Graingers, but I'm going to Seattle next week, so I'll look around there.
In the meantime, I tried the "stone axe" approach. Stuck the cable in the vice, between two pieces of tin with a notch for the wire. Heated it up with the acetylene torch and mashed it with a hammer. That made a nice little flat nub that I then fixed in position with solder in the cable end.
I know, crude and primitive, and probably won't hold, but it is on the bike and the clutch is working for now.
Re: How do you solder a stainless cable? [Re: Jim Hultman] #307591
04/11/10 3:59 pm
04/11/10 3:59 pm
SK , Canada
koob Offline
koob  Offline
SK , Canada
Not sure if this is available state-side, but I've been using "Metal solder flux #1744 " made by Canada Metal. It's liquid you dab on with a small paint brush, works dandy on all cables I've made, including jap 10-speed bicyle SS cable.HTH.
Re: How do you solder a stainless cable? [Re: koob] #307903
04/13/10 5:15 am
04/13/10 5:15 am
Diamond Springs, Kalifornia
Buckshot1 Offline
Buckshot1  Offline
Searching 'brazing' on Grainger's brought up 21 results. Click on 'more info' and it will show the applications for each. Any described for use with sst should be fine. The white flux that comes with some of the selections is what I've always used with good results. Very important to have everything *clean*. If you leave a couple strands of the cable long, you can bend them so the end piece won't fall off or otherwise move around while brazing. Cover generously with flux and use a soft flame to gradually heat the joint to a cherry red. You must get the work hot enough to make the filler flow into the joint with the flame removed. It only needs a small amount of filler, so don't gob it on. When you have filler in joint, return flame at a distance and sweeping across the work to make for a gradual cooling off. Don't disturb until fully cooled, then wash off dried flux, & dress off excess filler.
Michael
currently owned by a 72 T120R
maker of plunger conversion jig
Re: How do you solder a stainless cable? [Re: Buckshot1] #308209
04/15/10 3:54 am
04/15/10 3:54 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
i was trying to steer you towards a lower temp solder which grainger carries much like plumbing solder only it is high silver bearing,this would be much better for cables imo.
Re: How do you solder a stainless cable? [Re: jaycee] #308211
04/15/10 3:56 am
04/15/10 3:56 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
ive got this stuff at work if i can remember ill write down the ESAB numbers from grainger
Re: How do you solder a stainless cable? [Re: jaycee] #308272
04/15/10 3:02 pm
04/15/10 3:02 pm
Minnesota, US
Minnesota, US
Thanks!
Re: How do you solder a stainless cable? [Re: Jim Hultman] #308280
04/15/10 4:28 pm
04/15/10 4:28 pm
Buckshot1 Offline
Buckshot1  Offline
You need the 56% silver content. Have you checked with a weld or machine shop near you? Probably get what you need for a 12 pack & save the retail expense. Probably get some personal instruction, too.
Michael
Re: How do you solder a stainless cable? [Re: Buckshot1] #308339
04/15/10 10:42 pm
04/15/10 10:42 pm
Minnesota, US
Minnesota, US
Thanks Michael
Do you know the specs on the flux?
Re: How do you solder a stainless cable? [Re: Jim Hultman] #308352
04/16/10 1:20 am
04/16/10 1:20 am
Buckshot1 Offline
Buckshot1  Offline
Ask for the white stuff. It's a paste you can brush on. Put some on cable before assy and thoroughly coat the work. Heat with soft flame (oxy/fuel) gradually. Flux will liquefy before turning chalky looking. Keep heating until your joint is hot enough to make the silver run without the flame. After the braze sets in several seconds, I like to sweep the flame across the joint while gradually pulling it away so things will cool slowly. A good silver solder job is remarkably strong. IIRC, the optimum space to fill between parts should be .003-.005. The strands of cable have nice nooks & crannies for fill in.
Michael
