GOLD S-TARvin R.I.P.
Ohio, U.S.A.
24 registered members (Boomer), 126 guests, and 374 spiders.
Nomdegom, Andy Mac, kwbikr, RandomTask, George Henstorf
10379 Registered Users
Mori55 94
NickL 86
Stuart 82
DavidP 81
reverb 73
Triless 68
687,906 mail-order LSR
Topics67,995
Posts661,419
Members10,379
What Spark Plug A65 #30719
11/02/07 5:40 pm
11/02/07 5:40 pm
Gordo in Comox Offline OP
The NGK listed plug for the A65 is BR8ES but I am interested in what folks are actually using with the modern "fuels" and electronic ignitions.
Re: What Spark Plug A65 #30720
11/02/07 5:53 pm
11/02/07 5:53 pm
Rich B Offline
Rich B  Offline
Asking what plug is best is almost as bad as asking which oil is best. You will get lots of opinions....and since I have yet to see anyone post here here that is a qualified spark plug expert, it will be just opinion.....
So, now that you ask...I run Champion N3's in both of my A65's. Occasionally run Autolite's which seem to work well too. IME, NGK's are nothing but grief for me in an A65. Short life, easily fouled, etc. Though they work great in my Y@m@h@ trials bike. :rolleyes:
Re: What Spark Plug A65 #30721
11/02/07 6:09 pm
11/02/07 6:09 pm
I have real good luck with Champion N3.
Have had bad luck with NGK.
Re: What Spark Plug A65 #30722
11/02/07 6:18 pm
11/02/07 6:18 pm
Ran NGK B8ES's and N3C's (no discernible difference, though I understand N3 is a little hotter) when the royal star was an A65 now run B7ES's in the A50 and they last about 10K miles.
Re: What Spark Plug A65 #30723
11/02/07 9:25 pm
11/02/07 9:25 pm
Mark Parker Offline
Mark Parker  Offline
I've been running denso iridiums, and have bought some 'halo' plugs to try, but haven't tried them yet because the poor old A65 is all pulled apart for renovations, it was going to get bearings and rings but had a cracked piston, so I'm waiting on some better suited forged ones from MAP. Aparently the halo plugs ignite and burn the mixture faster and more completely and need the timing retarded a bit but give better power and economy? So I'm interested to find out, has anyone tried them?
http://cgi.ebay.com.au/HALO-premium-ulti...5QQcmdZViewItem
Re: What Spark Plug A65 #30724
11/02/07 10:19 pm
11/02/07 10:19 pm
NJ
6
66 Bonny Offline
66 Bonny  Offline
NJ
Gordo,
Always N3's for me. Seem to run better in the Lightning. Doesn't seem to run as well with the NGK's. Just my beerchug Cheers,
Re: What Spark Plug A65 #30725
11/02/07 10:20 pm
11/02/07 10:20 pm
I use Champion N3. The bike is a one kick starter. In my A65T these plugs burn to a light choclat (spelling?) brown. Other plugs may work, but I never felt the need to try an other type.
Re: What Spark Plug A65 #30726
11/02/07 11:59 pm
11/02/07 11:59 pm
Auckland New Zealand
Lightning 7a Offline
Hi I use NGK B7ES with no problem Any good brand and the right heat range will be fine if your engine is in good fettle Plugs get blamed for all sorts of issues Cheers
Re: What Spark Plug A65 #30727
11/03/07 1:28 pm
11/03/07 1:28 pm
My A65 runs poorly on NGK plugs for some reason. I tried several heat ranges, but they all acted the same; after a few hundred miles, the bike would start running rough and be harder to start.
Switched to Champion N3 plugs and no more issues. Could be some weird coincidence but I've got no reason to switch back and test the theory, so just sharing the experience and you can draw your own conclusions.
Re: What Spark Plug A65 #30728
11/03/07 2:01 pm
11/03/07 2:01 pm
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
I would agree with Lannis. I tried NGK's, had all sorts of problems, including uncontrollable fouling, on my 70 Lightning and switched to Champion's. They run better, are easier to start the bike with, and they don't foul any more.
Josh
Re: What Spark Plug A65 #30729
11/03/07 2:04 pm
11/03/07 2:04 pm
Ghana
H
Harry Spitfire Offline
H
Ghana
Hi Guys,
I'm using the NGK B8ES because that was the plug allready installed & it is the equivalent for
Champion N 3. Unable to get Champion here so
can not compair. Bike runs OK. Last month had one time bad starting & running rough till warmed up but my gaps were far too wide.
Normal start first time. (Like to try N 3)
Regards to all.
Spit 67 Boyer ign.
GER can't spell chocolate,just say shiit colour.
Re: What Spark Plug A65 #30730
11/03/07 4:14 pm
11/03/07 4:14 pm
Harry, I like your sense of humour laughing
Re: What Spark Plug A65 #30731
11/03/07 4:41 pm
11/03/07 4:41 pm
, Lower -Lower michigan
Bob S Offline
Bob S  Offline
i`ve got throw in my 2c Iwouldn`t use champions in a street rod. i`d sell it first. always used a.c.`s. in my bsa champion, seems to do alright. i haven`t been as far as most of yous smile
bob s
Bob S
Street Rods, Kustom Kars,A BSA,Cushmans,H.Shadow ACE, Now a 2004 triumph america . "More than enough!!!!
Re: What Spark Plug A65 #30732
11/03/07 9:04 pm
11/03/07 9:04 pm
uk
gram Offline
gram  Offline
uk
I've been using NGK B8EVs(the ones with the tiny centre electrode) which i got from an ex-Bantam racer.I don't think that they are made any longer,although i have seen them for sale on eBay.
Gram
Re: What Spark Plug A65 #30733
11/04/07 12:57 am
11/04/07 12:57 am
CA
BSA Mark Offline
BSA Mark  Offline
CA
Hi Chaps,
Champion N3C's on the Lightening and N4C's on the T-Bolt. I've been running these with a Boyer and stock coild and always fire up first / second kick.
I have to add initially I was a five to ten times kicker, but after a lesson in high speed kicking techniques where one learns to kick at lightening speeds (maybe that's how the ike got its name), now each times a winner.
A Honda CBR1000RR guy asked if he could try to kickstart my T-Bolt. He gave up after five very embarrising attemts. I climbed on and first try the T-Bolt fired into life.
Now the CBR rolled over a few times on it's electric starter before firing up. Interestig huh?
Take care
Mark
1971 BSA Thunderbolt
