jim schmidt
jim schmidt
Sanger, CA
31 registered members (Alan_nc), 225 guests, and 446 spiders.
10257 Registered Users
Stuart 75
Lannis 55
TBolt72 47
610,901 mail-order LSR
Topics67,152
Posts651,660
Members10,257
Combustion chamber volumes #305494
03/29/10 9:45 pm
03/29/10 9:45 pm
atlanta, ga
British Bike Guy Offline OP
atlanta, ga
What is the consensus for the combustion chamber volume on the average unadulterated (not milled) cylinder head for a:
750 Norton Commando Head (not combat)?
850 Norton Commando Head?
Sorry one more.
On a stock bike with stock pistons.
How far out from the deck is a 750 stock cast piston??
How far down from the deck is an 850 stock cast piston??
Thanks all
Mark
Re: Combustion chamber volumes [Re: British Bike Guy] #306126
04/02/10 1:01 pm
04/02/10 1:01 pm
atlanta, ga
atlanta, ga
With all of the Norton hot rods out there, can any of the guru types help me out with this.
Mark
Re: Combustion chamber volumes [Re: British Bike Guy] #306155
04/02/10 4:37 pm
04/02/10 4:37 pm
The NOC Commando Service Notes covers all the permentations of heads (there's a lot of variations not just std and combat) and Compression Ratios, you can work backwards from the swept volumes.
http://archives.jampot.dk/Book/Workshop_manuals/Norton_750cc_Service_Notes.pdf
PS its Easter so things are a bit slow.
Re: Combustion chamber volumes [Re: British Bike Guy] #306188
04/02/10 7:44 pm
04/02/10 7:44 pm
Peter R Offline
Peter R  Offline
For a stock 750 Commando (CR 9:1)the calculated combustion chamber volume works out as 46.5 cc.
For a stock 850 emgine (CR 8.5:1) this will be 55.2 cc
As stated by the above posting, there are several variations.
The only reliable way to verify the combustion chamber volume is by holding the engine in a position with the spark plug hole uppermost, and pour liquid in the cylinderhead with a burette.
Sorry I do not know the answer to the second part of your question.
Re: Combustion chamber volumes [Re: Peter R] #306237
04/03/10 1:28 am
04/03/10 1:28 am
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
If you are doing accurate calcs of chamber volume for compresh, with the head off the engine, you must measure. Make a plexi cover for the head that's sealed with grease on the edges with a hole in the middle and fill the chamber with water.
I use a low cost 60cc medical syringe vs a messy/expensive burett to acurately measure the water needed to fill the chamber.
The largest variable to deal with when calculating static compression is accurately measuring the volume of your piston crown. I have a proven accurate procedure used by engine builders for many years. I will Email a copy. Ask.
dave - NV
Re: Combustion chamber volumes [Re: dave - NV] #307165
04/08/10 2:42 pm
04/08/10 2:42 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
Doing these heads is a pain, since I have to pull the head studs to get the domed acrylic disc to seat over the chamber.
The 850 measured 50cc almost on the money. This RH10 head might not be a full depth chamber.
The 68-70 06-0380 750 is original but had a little carbon in the chamber and on the valves and also read 50CC.
You may get further variation on top of that due to different valve head profiles.
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Moderated by  Dave Comeau
