Zombie
Zombie
Florida PanHandle
22 registered members (Bougor), 196 guests, and 405 spiders.
mtbackroads, goatroper, Hawaii70BSA, itomtom, Wristpin
10451 Registered Users
NickL 77
franko 66
Jeff K. 58
736,977 mail-order LSR
Topics68,613
Posts668,211
Members10,451
Lucas Controls - Engine stop "kill" switch: 1978 #306344
04/03/10 7:58 pm
04/03/10 7:58 pm
Farmington,Connecticut,USA
JBMorris Offline OP
JBMorris  Offline OP
Hi folks,
There are two switches, one above, one below the red kill switch.
Owners handbook (for 1977)and the workshop manual for '78 don't identify these two animals.
It may have been brought up before, but i don't recall what they are intended for. . .any help?
Section H19 wiring diagram shows 17,18,19: indicator switch,kill button,left hand handlebar switch.
Ive seen 1978 bikes with much cleaner controls than mine and i believe my bike was built in November of '78?
. . . but i'm not absolutely sure.
1978 Bonneville T140V PX
Re: Lucas Controls - Engine stop "kill" switch: 1978 [Re: JBMorris] #306350
04/03/10 8:31 pm
04/03/10 8:31 pm
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
The upper button is for the headlamp flasher. The lower button is a spare.
By calendar date "November '78" (PA prefix) the Co-op would have been several months into building their '79 model year production (P = Nov. A = 1979 season model) starting at HA11001 in July 1978. The '79 year models (T140D & E*) had the parallel inlet port heads with Mk2 Amals, Lucas RITA ignition, T160, style instruments and black handlebar switch units.
*(Some T140E's were also built during the '78 season, but they didn't have the RITA ignition)
T140VPX01562
A date code prefix of PX (X = '78 season) could easily be misread as being November '78 manufacture, when it is actually the date code for November '77.
Disregard that information, as the '78 season models would normally have had a different (T160 style) L/H switch unit.
Re: Lucas Controls - Engine stop "kill" switch: 1978 [Re: L.A.B.] #306362
04/03/10 11:05 pm
04/03/10 11:05 pm
Stuart Offline
Stuart  Offline
Hi Les,
You sure? That'd make it entirely different to the externally-identical cluster fitted to the T160, and the pattern ones available today. On the T160 and pattern ones, the upper button is for the electric start (White and White/Red cables).
Moreover, except on early T160's, where the appropriate cable wasn't connected in the cluster, the headlamp flasher is on the same (lower left) button as the horn - push in for horn, push up for flash.
Re: Lucas Controls - Engine stop "kill" switch: 1978 [Re: Stuart] #306408
04/04/10 7:58 am
04/04/10 7:58 am
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
Originally Posted by Stuart
You sure?
Well, that's how my '78 T140V is wired!
Entirely different? No, the "starter" button (White & White/Red wire) becomes the"Headlamp flasher", that's all, as I see it.
[Edit] This could possibly have been a PO modification, as the '78 owners handbook doesn't mention a headlamp flasher (in fact it still shows the old up to '75? switch units) nor does it show one in the late wiring diagram, however it would seem odd to me if the factory didn't actually make use of the "starter" button as a headlamp flasher because the L/H switch wasn't wired for it, and a headlamp flash button was included in the earlier version T140 switchgear? (see the early T140 wiring diagram)
There's no headamp flash facility on my (presumably original) T140V's L/H switch unit (which you'd expect to find on a T160 = push horn button upwards to flash the headlamp) or any sign that there ever was either a wire connection or internal switch contact for that purpose.
Also there's no second Blue/White wire from the switch to the 6-way multi-connector plug, or any corresponding Blue/White wire in the harness 6-way plug, so there's only eight wires (5 + 3) and not the nine (6 + 3) you'd expect to find coming out of the T160 L/H switch unit!
Re: Lucas Controls - Engine stop "kill" switch: 1978 [Re: L.A.B.] #306454
04/04/10 1:41 pm
04/04/10 1:41 pm
JBMorris Offline OP
JBMorris  Offline OP
L.A.B., Stuart,
Thanks for the info - i like the idea of a headlight flasher, mine doesn't work, as iv'e just tried it out.
As far as the horn button serving two functions, that's a new one on me!
Here's the wiring diagram from the '77 owners manual (downloaded from www, somewhere)
L.A.B., Thanks for the build date info- i still can't figure out the system!
"Spurious " sparks and spurious instrumentation is par for the course, i guess.
As far as PO modification, i guess that's possible, the redneck that i bought it from claims he assembled the bike straight from the crate, and he fitted earlier tank badges.
FWIW, i still wear the solid brass "Baron Buckle" with Triumph script that came in the crate, circa 1978, made in Taiwan!
Re: Lucas Controls - Engine stop "kill" switch: 1978 [Re: L.A.B.] #306574
04/05/10 1:21 am
04/05/10 1:21 am
Stuart Offline
Stuart  Offline
Hi Les,
Hmmm, possibly I didn't explain my use of "entirely different" clearly enough ...
Ime, Lucas didn't supply stuff that required different-coloured cables to be connected together on assembly. So, if the function of the push-button had changed officially to a 'headlamp flasher', I would've expected to find a Blue/White cable in place of the White/Red cable supplied for an electric starter.
Looks like it didn't change officially, so Lucas were supplying the cluster still with a White/Red cable and, as you say, someone in the bike's past simply connected that cable to the Blue/White cables for a headlamp flasher. Fwiw, 'great minds think alike' - I've done exactly the same on the T100DBWIB (T100 Disc-Brake Wot I Built), which uses these switch clusters. wink
Yeah, that's the way it is on the early T160's; the additional Blue/White cable's missing from the cluster harness (although the multi-pin plug's the same) and there's a small hole in the top of the horn button unit that should take the end of the missing Blue/White cable.
Surprising that the fault reappears on Co-op twins built after the T160's. confused Wonder if Lucas made a mistake on the early T160 clusters, NVT moaned about it, Lucas made more correctly and put the remaining 'wrong' ones on the shelf, later palming 'em off on a cash-strapped Co-op?
Re: Lucas Controls - Engine stop "kill" switch: 1978 [Re: Stuart] #306642
04/05/10 1:44 pm
04/05/10 1:44 pm
Westfield, Indiana, USA
Geoff Offline
Geoff  Offline
Off topic - but I think it is neat as I have a T140VPXxxxx as well. The electical part of the bike is a frankenstein though. Kewl.
'78 T140V
'74 Commando
'69 TR6R
'67 Starfire
'64 Greeves TES
'58 Allstate (Puch) 175
