lit67
lit67
Central Illinois, USA
37 registered members (Adam M.), 263 guests, and 80 spiders.
10389 Registered Users
NickL 98
Triless 88
Mori55 83
reverb 80
Rohan 80
DavidP 72
btour 66
690,580 mail-order LSR
Topics68,051
Posts662,152
Members10,389
Norton Clutch Problem #304032
03/20/10 7:59 am
03/20/10 7:59 am
bbc Offline OP
bbc  Offline OP
Hello Everyone,
I have a 1974 850 Norton Commando. It has a 5 Friction plate Barnett clutch. It will not release the plates all the way. It wants to Pull the bike with the clutch pulled in. I have adjusted it several times at the primary cover. The plates are Not stuck together when I pulled it apart. Your help is greatly appreciated.
Thank you in advance.
Re: Norton Clutch Problem [Re: bbc] #304057
03/20/10 1:41 pm
03/20/10 1:41 pm
FLORIDA
Alan Prudhomme Offline
FLORIDA
Your clutch operating lever could be out of position or warped plates will cause this. Go to search, there is a lot of info on this.
Re: Norton Clutch Problem [Re: bbc] #304198
03/21/10 12:08 pm
03/21/10 12:08 pm
Hamilton, Mass. USA
Dave Comeau Online content
Crew Chief
Dave Comeau  Online Content
Crew Chief
Hamilton, Mass. USA
The amount of clutch freeplay is absolutely not critical for the commando.
educate yourself here:
http://atlanticgreen.com/ndnsclutch.htm
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: Norton Clutch Problem [Re: Dave Comeau] #304294
03/22/10 1:01 am
03/22/10 1:01 am
HawaiianTiger Offline
Whilst mine did drag at one time like yours it slipped as well. The culprit was the center drum that had a multitude of notches beaten into it. Some of these drums are hardened and some are not. They're not cheap either but a new hardened one may be the solution to your problem.
Re: Norton Clutch Problem [Re: HawaiianTiger] #304316
03/22/10 5:43 am
03/22/10 5:43 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Did you buy the right plates? There are two thicknesses.
By the way, when machining new aluminum clutches I found the Barnett drive (steel, outer notches) plates are slightly undersize compared to the Norton plates so they will rattle in the basket more.
Re: Norton Clutch Problem [Re: DMadigan] #304431
03/23/10 12:23 am
03/23/10 12:23 am
Springfield Nebraska
Richrd Online content
Richrd  Online Content
common problem. the hub center gets grooved and this holds the plates in position instead of allowing them to slide.
I have tried to file or reshape the spines but it never works so I just replace the center.
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Norton Clutch Problem [Re: Richrd] #305031
03/26/10 4:57 pm
03/26/10 4:57 pm
bbc Offline OP
bbc  Offline OP
Thanks Everyone
Moderated by  Dave Comeau
