SBoyd
SBoyd
Virginia, USA
43 registered members (Al Eckstadt), 259 guests, and 475 spiders.
MikeA, Jay Gilling, scratchedtank, Magic Monkey, Hybris
10252 Registered Users
Lannis 64
NickL 48
606,169 mail-order LSR
Topics67,072
Posts650,871
Members10,250
T120 Inlet cam rotory breather? #304136
03/20/10 11:48 pm
03/20/10 11:48 pm
oklahoma
knifesmashr Offline OP
oklahoma
I'm rebuilding a 1971 T120. Does this motor require the rotary breather valve disc and spring that usually goes in the left case inlet cam bushing? One was not installed when I disassembled the motor.
Re: T120 Inlet cam rotory breather? [Re: knifesmashr] #304137
03/20/10 11:55 pm
03/20/10 11:55 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
No. The engine breaths through the crank end into the primary case and out a tube to rear of the bike.
Re: T120 Inlet cam rotory breather? [Re: desco] #304139
03/21/10 12:19 am
03/21/10 12:19 am
oklahoma
oklahoma
Thank you and much appreciated. Looks like I might be able to get these cases together tonight. Cheers.
Re: T120 Inlet cam rotory breather? [Re: knifesmashr] #304153
03/21/10 1:58 am
03/21/10 1:58 am
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
FWIW,it breaths through the main bearing on the primary side due to the seal not being there. Repeat,No seal on the crank. Jack
Re: T120 Inlet cam rotory breather? [Re: Jack Adams] #304168
03/21/10 4:55 am
03/21/10 4:55 am
oklahoma
oklahoma
Thanks! That helps a lot too. This is my first Triumph build and I've been going off the Four Aces vid, a Haynes manual, and the factory parts book.
Re: T120 Inlet cam rotory breather? [Re: knifesmashr] #304260
03/21/10 9:36 pm
03/21/10 9:36 pm
Clarksburg, WV USA
Ken Holby Offline
Ken Holby  Offline
Clarksburg, WV USA
I have a '70 TR6R and all of the books show a breather, but it doesn't have one. Inside the "drive side" case you'll notice 3 or is it 4 small holes by the cylinder wall. It breathes there, plus the main bearing. So, you can sleep tonight - lol.
'70 TR6R Chop (always in process)
Re: T120 Inlet cam rotory breather? [Re: Ken Holby] #304599
03/24/10 12:46 am
03/24/10 12:46 am
oklahoma
oklahoma
I have 3 small holes in the case. Thanks! I do feel better.
