Go2fer
Go2fer
39 registered members (Andrew Dunham), 191 guests, and 221 spiders.
10173 Registered Users
Lannis 93
reverb 82
Stuart 77
NickL 67
koan58 61
551,048 mail-order LSR
Topics66,569
Posts645,348
Members10,173
Wheel rim widths [ WM2/ WM3] #303856
03/18/10 10:50 pm
03/18/10 10:50 pm
IL,USA
W
WayneJ Offline OP
WayneJ  Offline OP
W
IL,USA
Hi, Can anyone verify the wheel rim widths for the WM2 and WM3 wheel rims ?
I believe that the WM2 is 2.5 inches wide and the WM3 is 3 inches wide , is this correct? Thanks
Re: Wheel rim widths [ WM2/ WM3] [Re: WayneJ] #303859
03/18/10 11:16 pm
03/18/10 11:16 pm
John Healy Offline
John Healy  Offline
Rims:
WM2 inside 1.85" (47mm) outside 2.72" (69mm)
WM3 inside 2.15" (55mm) outside 3.080" (78.2mm)
hth
Re: Wheel rim widths [ WM2/ WM3] [Re: WayneJ] #303860
03/18/10 11:17 pm
03/18/10 11:17 pm
Westminster, MD, USA
J. Charles Smith Offline
On the inside, where the tire seats (the critical width), I recall WM2s as being 1.85" wide and WM3s as being 2.15" wide. The outside width will vary between brands.
Re: Wheel rim widths [ WM2/ WM3] [Re: J. Charles Smith] #303861
03/18/10 11:17 pm
03/18/10 11:17 pm
Damn, JH is quick at those keys!
Re: Wheel rim widths [ WM2/ WM3] [Re: J. Charles Smith] #303877
03/19/10 1:31 am
03/19/10 1:31 am
Harveys Lake, PA. USA
dirtymartini Offline
How wide of a tire can be mounted on a WM2?
75 Norton Commando Mark II
75 Penton Mint 400
'72 Ossa MAR
Re: Wheel rim widths [ WM2/ WM3] [Re: dirtymartini] #303879
03/19/10 1:47 am
03/19/10 1:47 am
MN
Shades34 Offline
Shades34  Offline
MN
Re: Wheel rim widths [ WM2/ WM3] [Re: Shades34] #303890
03/19/10 2:46 am
03/19/10 2:46 am
IL,USA
W
WayneJ Offline OP
WayneJ  Offline OP
W
IL,USA
Hi All, Thanks for everyones reply , it appears I have a WM2
rim on the back of my 64 Bonneville and one of the previous ownwers monted a 4 inch rear tire and removed the security bolts , maybe they couldn't fit them back in with the oversized tire. I am going to replace the tire with a 3.50 and replace the security bolts.
Wayne
Re: Wheel rim widths [ WM2/ WM3] [Re: WayneJ] #303979
03/19/10 7:47 pm
03/19/10 7:47 pm
Stuart Offline
Stuart  Offline
Hi Wayne,
You might want to take a look at the recent "Cheap Tires" and "Replacing Tires" threads on the British Motorcycles In General Board. Domiracer sell a 3.50x18 but, like most small Imperial sizes, it's Far Eastern-made.
Otoh, 4.00x18 isn't really "oversized"; if the US-market '64 Bonny wasn't fitted with it originally, Triumph went to the size (with a 3.25x19 on the front) shortly afterwards (albeit fitted on a WM3 rim) on US-market twins and carried on fitting 'em 'til the mid-1970's. Also, those are the two Imperial sizes available in modern tyre ranges from premier makers like Avon and Continetal.
Otoh2, you could consider a 100/90x18, which is about as wide overall as a 3.50x18 but has an overall diameter about 1/2" smaller.
In theory, they should've been easier to fit in the bigger tyre? confused Only reason I can think they were left out was the p.o. couldn't deal with 'em. If you do a forum search with keywords like "Rim Lock", you should come up with plenty of advice on how to make sure they aren't a pain during tyre fitting.
Page Time: 0.085s Queries: 15 (0.005s) Memory: 1.0393 MB (Peak: 1.2181 MB) Zlib disabled. Server Time: 2018-04-23 02:07:01 UTC
