SBoyd
SBoyd
Virginia, USA
43 registered members (Al Eckstadt), 259 guests, and 475 spiders.
MikeA, Jay Gilling, scratchedtank, Magic Monkey, Hybris
10252 Registered Users
Lannis 64
NickL 48
606,169 mail-order LSR
Topics67,072
Posts650,871
Members10,250
1966 MK11 Spitfire rear hub and removing the bearings. #294166
01/15/10 11:58 pm
01/15/10 11:58 pm
CAB Offline OP
CAB  Offline OP
Hello
My Spitfire is kept at my dad's and I asked him to measure the bearings in the rear hub. I'm changing the bearings (the brake drum bearing is smooth but the hub bearings are rough). I want to make sure that the bearings I buy match the originals before I have a wasted trip and find out that I have been sent the wrong ones.... Dad has taken the drive side bearing out (the retainer has a left hand thread).
The parts book shows from the drive side the threaded retainer cap, the bearing, a thrust washer (looks more like a spacer that can only fit against the outside race due to it's size), then a tubular spacer, a large rubber cylinder and the hub. The thrust washer/spacer and rubber cylinder were both missing from the hub. The hub doesn't have a grease nipple hole which makes me believe it is a 1967 type (the 1966 parts book shows a grease nipple the 1967 parts book doesn't). I can't see the point of the rubber cylinder unless it is there to direct grease in to the bearing from the grease nipple (which isn't fitted).
Should the thrust washer/spacer be fitted?
What holds the right hand side bearing in to the hub and what direction is the thread? The parts book shows the hub, the bearing, a retainer (looks like a washer/spacer), a felt washer and then another retainer (this also looks like a washer/spacer). I can't see another threaded retaining cap to keep the bearing in. Does the right hand bearing come out the right hand side of the hub?
Thanks for any advice.
CAB
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: CAB] #294187
01/16/10 2:29 am
01/16/10 2:29 am
Minnesota, US
Jim Hultman Offline
Jim Hultman  Offline
Minnesota, US
Yes, the right bearing comes out the right side, the speedo drive is the retaining cover, and it is a left hand thread. Be careful not to damage the speedo drive notches. I built a tool to remove these, as they can be difficult. Just find a socket that fits nicely inside the hub, slide the socket in to the hub, mark the notches with a scribe and drill holes in it (exactly at 180 degrees). Then drive in a piece of 3/16 inch key stock.
You'll probably burn up a couple drill bits, and the key stock will round off a bit when you drive it in, but if you get the holes exactly right, it will fit nicely into the speedo drive slots in the cover. I can take a picture of this if you like.
Or you can just have at it with a water pump pliers, but I prefer the tool. Plus I like making tools! laughing
Jim
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: Jim Hultman] #294203
01/16/10 7:38 am
01/16/10 7:38 am
Cab
The large rubber ring 67 6051 just fills the space and keeps out the dirt and water from getting in behind the drive spline. It does not put any pressure on the bearing. I suppose it really protects the splines.
The speedo drive does thread on but any pressure it puts on the bearing is through a felt washer and two retainers (washers). In use the right side bearing is held inplace by the tightening of the long axle which in turn exerts pressure through the series of spacers/distance pieces #28, #26 and #25 and the speedo gearbox onto the centre of the right side bearing. A key bit is the tubular spacer as it has two shoulders on it to position the hub via the bearing centres.
The retainer on the left side is needed to prevent the above force from pushing out the left side bearing when the axle is tightened. The retainer only holds the bearing in place and does not touch anything else on the left side. The hub stops moving left when the splines bottom out.
This shows how the rubber fits into the hub
When you take the speedo drive off you will see a large washer
Behind the first washer is a felt washer and a second steel washer. The 66 book only shows one steel washer (retainer). They are not the same. Maybe in 66 there was only one washer but it would have been hard to thread on the speedo drive without wrecking the felt washer.
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: Gordo in Comox] #294214
01/16/10 11:08 am
01/16/10 11:08 am
CAB Offline OP
CAB  Offline OP
Thanks gents.
I really appreciate your help.
Jim a photo of the tool would be very useful.
There are lots of small bits missing from my bike (practically all the fasteners for a start). I'm building it with the parts manual as my reference.
Is the small left hand thrust washer/spacer 65-5584 often left out?
CAB
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: CAB] #294216
01/16/10 11:38 am
01/16/10 11:38 am
Cadillac, MI
JT441 Offline
JT441  Offline
Cadillac, MI
I found the bearings to be quite expensive from the British bike suppliers. I measured the bearings for my MK II and ordered them from AST http://www.astbearings.com/p-brng-ci.php . They were about 1/4 the price, fit perfectly and were sealed. AST was great to work with too. I just tried to find the invoice, but seem to have lost track of it.
JT441
'70 B44
'71 T120
'66 Spitfire
'85 Honda Shadow (the SO's bike)
'90 Honda Pacific Coast
'96 Honda Pacific Coast
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: CAB] #294221
01/16/10 12:13 pm
01/16/10 12:13 pm
Lincolnshire, England
trickytree Offline
trickytree  Offline
Thanks gents.
CAB
Dont see how it can be realy...on my hub there is only a very small step machined into it...10 thou or so...the spacer is a snug fit in the hub and acts more like a shoulder for the bearing to butt up against.
65 A65 bobber
A10 bitza...not (re)born yet
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: CAB] #294235
01/16/10 2:44 pm
01/16/10 2:44 pm
Minnesota, US
Jim Hultman Offline
Jim Hultman  Offline
Minnesota, US
Here you go. Simple to make and sure makes it easy to get the speedo drive off these wheel hubs!
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: Jim Hultman] #294259
01/16/10 6:08 pm
01/16/10 6:08 pm
I love that tool of Jim's, but haven't needed it yet. I put a piece of flat steel in the big vise, some strap that fits the slots real nice. Then just put hub down on there and turn the wheel. Has worked every time..........not my idea, I learned it from somebody here on the board.
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: leon bee] #294368
01/17/10 1:27 pm
01/17/10 1:27 pm
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
My parts book says LS9. They're imperial not metric and not everyone keeps them in stock. Can be a bit hard to find. Use to be a good reference here for BSA bearings:
http://www.bsansw.org.au/pages/bearings.html
but the link didnt work for me just now, but it might for you.
Sounds like you are halfway there. I have found fitting the drive side bearing first, setting it in place with the screw-in retainer and then fitting the speedo side works best. As per the manual. Dont ask how I know this is best (2 hours in the shed saves 2 minutes reading the book).
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: BrizzoBrit] #294496
01/18/10 8:42 am
01/18/10 8:42 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Further to my last post.
Size is: 2.000 x .8750 x .5625
I had to get a couple at the bearing shop today. Timed it so I would pick it up on the way home from work and fit tonight. Rang this morning and the young bloke said yeah I got 'em (at about a third the price the local bike shop sells them for) roll up and he's tried to sell me RLS-9!!! Way too big. So make sure they get the equivalents correct.
Modern SKF # is RLS-7 and I use the rubber shielded both side which makes it RLS-7-2RS. For further equivalents try this:
http://www.consbrgs.com/page.taf?detail=71_2_4&print=yes
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: BrizzoBrit] #294772
01/19/10 10:24 pm
01/19/10 10:24 pm
CAB Offline OP
CAB  Offline OP
Hello Ray
Is that the equivalent of 65-5883?
The two bearings (65-5883) in the hub are ever so slightly rough and I am going to change them. I'm not replacing the bearing in the brake drum as this seems fine. I think I have a 1967 hub as it does not have a greas nipple. The bearing in the brake drum is listed as 65-2045. Do you have an equivalent part number for this bearing. I'll try and get a price from Bearing Services Limited.
CAB
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: CAB] #294849
01/20/10 1:00 pm
01/20/10 1:00 pm
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
CAB
Yes, that's the equivalent for the 65-5883.
I dont have an equivalent for the brake drum bearing (65-2045) which my parts book lists as a Hoffman 125 ?? which I can't make out too clearly. I'm working from a 1970 parts manual. I dont have one apart at the moment to check.
But there was a thread here mentioning bearings and in that there are 2 indendent listings that give 6205-2RS as the bearing for the brake hub (65-2045). Odd because this is a metric size - but then I believe the front (on the '70) use a metric.
There is a 6205-2RS box sitting in the bits and pieces from when I rebuilt my hub, but I wouldnt be betting my left nut on it at this stage.
go here for the thread: http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=30343
Hope this helps.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
Re: 1966 MK11 Spitfire rear hub and removing the bearings. [Re: BrizzoBrit] #300203
02/23/10 11:35 pm
02/23/10 11:35 pm
CAB Offline OP
CAB  Offline OP
Hello gents
I fitted the new bearings to the hub at the weekend. There is a spacer (65-5884) in the drive side. I ordered a new one and it was then obvious that there was one already in the hub. I also ordered the end cover (68-6142) that fits on the speedo drive. It is the cover under the socket in the above photo. The only problem is that the new one is stamped 'LH' and the hub has a right hand thread.... I didn't know it until I looked but I had the old end cover in the box. The old cover is much smaller in diameter (it doesn't cover the outside of the hub) and has a matching right hand thread. Any ideas?
CAB
