Todd Porter
Todd Porter
Georgetown, Kentucky
51 registered members (Andy Haldeman), 319 guests, and 458 spiders.
eberhard, Norman Woollons, LandoLando, MikeA, Jay Gilling
10255 Registered Users
Stuart 75
Lannis 70
607,571 mail-order LSR
Topics67,091
Posts651,065
Members10,255
Wheel Offset A65 1967 #294884
01/20/10 5:15 pm
01/20/10 5:15 pm
Butler PA
rightshifter Offline OP
Butler PA
Has anyone made a list of the factory wheel offsets for the BSA. I am looking for a 1967 A65 Lighting offset for the front and rear wheel.
Re: Wheel Offset A65 1967 [Re: rightshifter] #294921
01/20/10 8:05 pm
01/20/10 8:05 pm
Many will tell you to relace and center the wheels in place on the bike. This is the best way to insure proper spacing, clearance and alignment...
If you have the original wheel and they are correctly positioned you can use those as a guide. Place the wheel on the brake drum face on a flat surface and measure the offset either under the rim or the drum itself with drill bits or round stock. A drill index full of all sizes works for me...
1956 Zundapp KS601EL
1960 Greeves Scottish/Hawkstone Velorex 560
1963 BSA Gold Star Spitfire
1964 Triumph T20SM
1965 BSA C15T
1966 BSA VE
1968 Bonham Tote Gote
1969 BSA VS
1970 BSA A65L (with a "Y")
1972 Husqvarna 450 WR
1986 Yamaha TT 225
1987 BMW K75C
Re: Wheel Offset A65 1967 [Re: D.Bachtel] #294930
01/20/10 9:12 pm
01/20/10 9:12 pm
Butler PA
Butler PA
Thanks for the reply, but,the wheel is is pieces and ready to lace. I measured two old ones and they have two differet measurements. There has to be a list somewhere with this information. The factory did not lace these on the bikes.
Re: Wheel Offset A65 1967 [Re: rightshifter] #294974
01/21/10 12:29 am
01/21/10 12:29 am
Dartmouth NOva Scotia
stevehi1 Offline
stevehi1  Offline
Try installing the two old ones on the bike. And go with the measure that fits the bike the best.
1969 A65L
1969 A65TC
2005 FLHTI
2007 Vespa LXV 150
Re: Wheel Offset A65 1967 [Re: stevehi1] #294980
01/21/10 12:59 am
01/21/10 12:59 am
Butler PA
Butler PA
The bike is still in pieces, out to be painted. Can't try that yet. Just wanted to get things ready when the parts come back.
Re: Wheel Offset A65 1967 [Re: rightshifter] #295005
01/21/10 3:19 am
01/21/10 3:19 am
Lace them up loosely right now then, your offset will pull over easy enough when it's time to fit up. Every bike varies a bit, you'll never know for sure til you mount them on the bike.
Your spoke/nipple supplier/wheel building shop should be able to supply you with a figure... they do offsets all day long.
1964 Triumph T20SM
1965 BSA C15T
1966 BSA VE
1969 BSA VS
1986 Yamaha TT 225
1987 BMW K75C
Re: Wheel Offset A65 1967 [Re: D.Bachtel] #295202
01/22/10 9:15 am
01/22/10 9:15 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
G'day,
I had this problem when I did my rear wheel. For the rear, SRM gave me an offset of 7/16" between a straight edge laid over the outer edge of the splines on the drive side of the hub and the rim (ie 7/16" gap between the straight edge and rim). If you need a diagram, I'll scan what they sent to me and send it through. This was for a WM3 alloy flanged rim and I'm thinking it would be much the same for a steel rim.
Can't help with a a '67 hub but for the late 68-70 hub the rim is flush with the edge of the drum on the backing plate side. Looking at 2 wheels in my shed one on a '66 hornet and the other off anything (swap meet item), for the front the edge of the rim would lie pretty much in line with the first or second fin going outwards fron the spoke flange on the backing plate side. HTH.
BTW I spent a couple of years in Pittsburgh in the late 90's. So not far from you.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: Wheel Offset A65 1967 [Re: BrizzoBrit] #295208
01/22/10 10:33 am
01/22/10 10:33 am
BSA_WM20 Offline
BSA_WM20  Offline
I have never seen such a table and several times started to do one but as you have already found out there seems to be little consistency.
There are some odd dealers sheets giving notice as to a change ut they are usually specific to one bike.
Re: Wheel Offset A65 1967 [Re: BSA_WM20] #295221
01/22/10 1:35 pm
01/22/10 1:35 pm
Butler PA
Butler PA
Thanks for the replys, I am will lace them up loose and fit them when the parts return. Thanks for all the help.
Re: Wheel Offset A65 1967 [Re: rightshifter] #295278
01/22/10 7:45 pm
01/22/10 7:45 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
I would suggest Not being concerned with 'offsets' if you have the bike at hand. Roughly assemble the wheel on the bench and finnish the project on the bike. Pull up a stool and have at it. BTW, I have a nice Rowe wheel building stand I seldom use.
With the bike up on prop stands, spoke the front wheel to center the rim between the fork legs and running true.
With long straight edges (I use 1" alu tubing) clamped to the front rim and held dead parallel beneath the bike extending either side of the rear rim. If the front rim is narrower than the rear, tape on amd shim with some thin, ~ 1/4" wood moulding trim.
Spoke the rear rim to center it between the straight edges and running true. Using a dial indicator you can usually get a good rim within 20-40 thou both radial and axial run out.
Be Sure to use a proper wide jaw spoke wrench and not a bodge crescent wrench or something. You can make a perfect fitting wrench by fileing the gap in a japper mm spoke wrench from your local dealer.
Insure the spokes are equally tight by the 'ding' sounds when tapped.
If fitting SS spokes, be sure to lube the threads.
Grind down any protruding spoke ends inside the rim.
Do it right. It might take a couple of evenings the first time, depending on the beer supply... but that's OK.
dave - NV
Re: Wheel Offset A65 1967 [Re: rightshifter] #295279
01/22/10 7:53 pm
01/22/10 7:53 pm
The issue is really where the centre of the rim should be for the application. Before I take a rim off a hub I first measure the offset of both rim edges in relation some key points on the hub. Then I measure the width of the rim and convert the measured offsets to the rim centre. With this data I am able to use a different rim without worrying about any difference in the width. I am not sure that new rims are always the exact same width for any given size. I am always leery about an offset given from only one side of the hub without a discussion of the exact width of the rim in question.
Re: Wheel Offset A65 1967 [Re: Gordo in Comox] #295283
01/22/10 8:04 pm
01/22/10 8:04 pm
Good points on the retrofit of different width rims Gordo!
Thanks.
Dave... you're way too modest, even I can achieve 10 to 20 thou axial and radial with a good used rim and two dial indicators!
1964 Triumph T20SM
1965 BSA C15T
1966 BSA VE
1969 BSA VS
1986 Yamaha TT 225
1987 BMW K75C
Re: Wheel Offset A65 1967 [Re: D.Bachtel] #295303
01/22/10 11:10 pm
01/22/10 11:10 pm
John Healy Online content
John Healy  Online Content
And if using stainless steel nipples, also be sure to lubricate the nipple where it bears on the rim.
Failing to do this can cause the contact area of the nipple/rim to gaul. This can lead to the head of the nipple physically reaming out the nipple hole in the rim as the nipple is being tightened. The result is a rim that will have to be replaced.
John Healy
Re: Wheel Offset A65 1967 [Re: John Healy] #295334
01/23/10 3:38 am
01/23/10 3:38 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Wow, you guys are good. I can never get an original rim that close to true where the welded hump is.
Re: Wheel Offset A65 1967 [Re: Gary E] #295341
01/23/10 5:22 am
01/23/10 5:22 am
No,no,no... the weld is always way off the dials and beyond my parameters.
I try to ignore the big bump. Alloy and cast wheels are better.
1964 Triumph T20SM
1965 BSA C15T
1966 BSA VE
1969 BSA VS
1986 Yamaha TT 225
1987 BMW K75C
Re: Wheel Offset A65 1967 [Re: D.Bachtel] #295739
01/25/10 7:45 pm
01/25/10 7:45 pm
CAB Offline
CAB  Offline
Hello
My BSA workshop manual (1966/1967/1968 500 & 650 Unit Construction Twins) quotes the following:
Quick-release rear wheels, are built with the rim central to the spoke flanges.
Quick-release front wheels are built with the edge of the brake drum 1-15/16 in. from the centre line of the rim.
190 mm. brake wheels using WM2 or WM1 alloy or steel rims are built with the edge of the rim 7/8 in. from the right-hand hub barrel end.
CAB
