Mark Taylor
Mark Taylor
Alexandria, Virginia; U.S.A.
35 registered members (Beach), 173 guests, and 55 spiders.
10383 Registered Users
NickL 100
Mori55 89
Stuart 80
reverb 75
DavidP 71
Triless 70
Rohan 69
689,113 mail-order LSR
Topics68,023
Posts661,774
Members10,383
Exhaust pipe Blues - Prevention #295158
01/22/10 1:12 am
01/22/10 1:12 am
SE Florida
ClutchCargo Offline OP
SE Florida
Will high temp grill paint (1200 degree) coated inside a new set of pipes prevent blueing ?
Re: Exhaust pipe Blues - Prevention [Re: ClutchCargo] #295261
01/22/10 6:09 pm
01/22/10 6:09 pm
chatham kent UK
john toghill Offline
chatham kent UK
I've heard of people using high temp aluminium paint to coat the inside of exhaust pipes and I used this:
http://www.kreemproducts.net/p-19-blue-shield.aspx
on a Hinckley T100 from new and it worked very well. The problem is any of these remedies only work on new unused pipes, unless you can find a way of cleaning old pipes completely.
The blue shield stopped the pipes from turning blue (which the new T100s have a reputation for due to the fact they run very lean) but they did go a nice golden colour. If your pipes turn blue very quickly it may be an indication that you're running too lean.
all the best
the trouble with the world today is apathy; but I don't care.
British Motorcycles, built to last, till worn out.
Re: Exhaust pipe Blues - Prevention [Re: john toghill] #295296
01/22/10 10:27 pm
01/22/10 10:27 pm
Massachusetts, U.S.A.
btour Offline
btour  Offline
I freaked about pipes turning blue. But it is nothing. It is an indication that plenty of copper was used in the plating process. A good thing.
If the blue color runs all the way down the pipe, than that may be a sign of something to worry about. Else not.
Coating new pipes on the inside may work or not. I think the straw color is prettier than the blue, but not really important.
Re: Exhaust pipe Blues - Prevention [Re: btour] #295309
01/23/10 12:08 am
01/23/10 12:08 am
Collierville TN
Alan in TN Offline
Alan in TN  Offline
Collierville TN
I thought the "straw color" occurred when stainless steel pipes were used rather than chrome plated steel. I think it is also correct that if the motor is running lean the chrome pipes will turn blue mainly near the head and sometimes further down the pipe (a pulse from the engine cycle?). If one uses stainless steel pipes they will develop a straw color as described in the thread.
If I am erring please set me straight. I also have not been able to successfully get rid of the blue pipe syndrome.
Alan
Re: Exhaust pipe Blues - Prevention [Re: Alan in TN] #295347
01/23/10 7:13 am
01/23/10 7:13 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Stainless ONLY go straw, chrome go straw on the way to going blue.
Re: Exhaust pipe Blues - Prevention [Re: Blapper] #295350
01/23/10 9:39 am
01/23/10 9:39 am
chatham kent UK
chatham kent UK
I've got stainless on my T140/TR7 and they have gone straw with a hint of blue at the head. The pipes on the Hinckley bonnies are chrome plated SS and I can assure you, if untreated they WILL go very blue a long way along their length due to the air injection system and the lean settings Blap.
Trying to remove the blue from pipes is not easy. Mine are unchromed polished SS and came back clean after putting them on my polishing machine but with chrome pipes you'd be likely to go through the plating, I think.
Best bet is to ensure your carbs are set up correctly, plus timing spot on, correct plugs, gapped right and then learn to love any blue you get. wink
Re: Exhaust pipe Blues - Prevention [Re: john toghill] #295398
01/23/10 4:01 pm
01/23/10 4:01 pm
SE Florida
SE Florida
I think I'll use high temp powder coat (1200 degree) inside before install. What can I loose?
Re: Exhaust pipe Blues - Prevention [Re: ClutchCargo] #295439
01/24/10 12:20 am
01/24/10 12:20 am
hampshire, england
t120mike Offline
t120mike  Offline
hampshire, england
IMO, blueing on a Meriden machine is almost obligatory. Shows it's getting used as ET intended! If you are worried about normal blueing on chrome pipes, I would say that's the least of your worries!
mike
Member #: 147
1960 T120 Bonneville
1999 H*%^a VFR 800 FI
V4 Triton Project (still keeping me sane (Ha-Ha!))
Re: Exhaust pipe Blues - Prevention [Re: t120mike] #295450
01/24/10 1:36 am
01/24/10 1:36 am
Tennessee
Fisherman Offline
Fisherman  Offline
Tennessee
I have used hi-temp paint on the inside my last two sets of new chromed pipes, one on the '72 TR6 and one on the '66 BSA. Both sets of pipes turned a nice gold color. I set the idle jets a little rich as I was breaking in the pipes, and didn't let the bike idle for any length of time.
If it works on a Hinckley, it works. They run as lean as a west Texas jackrabbit.
'Never argue with an idiot, they'll bring you down to their level, and beat you with experience'
'72 TR6
'12 Hinckley Scrambler
'95 FLHTC Road Sofa
Re: Exhaust pipe Blues - Prevention [Re: Fisherman] #295471
01/24/10 4:24 am
01/24/10 4:24 am
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
If you are really concerned about your pipes going blue, get them Jet-Hot coated.The pipes on my Hot-Rod look exactly the same as they did when I got them done by Jet-Hot 4-5 years ago. In fact they(Jet-Hot) guarantee no blueing. Jack
Re: Exhaust pipe Blues - Prevention [Re: john toghill] #295483
01/24/10 7:22 am
01/24/10 7:22 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Hi John,
"The pipes on the Hinckley bonnies are chrome plated SS and I can assure you, if untreated they WILL go very blue a long way along their length due to the air injection system and the lean settings Blap"
That's because as far as the temps are concerned they are chrome John - don't let the stainless insides fool you. Question: Stainless inside chrome outside - WHY? confused
I have had prolly six bikes with stainless zorsts and never had them go further than straw. Ever.
IME, bikes who's chrome pipes get well sooted before they are pushed harder don't blue much or at all whereas those classic bikes whose pipes are pounded on from new go blue quickly. The soot acts like ceramic coating the insides.
As to set-up, agreed. For sure.
Re: Exhaust pipe Blues - Prevention [Re: Blapper] #295567
01/24/10 6:24 pm
01/24/10 6:24 pm
chatham kent UK
chatham kent UK
Hello Blap,
"I have had prolly six bikes with stainless zorsts and never had them go further than straw. Ever."
Perhaps it's to do with the quality or grade of the SS? Maybe the amount of chrome in the SS? I dunno, I have to admit to knowing nothing about metallurgy whistle
But my pipes are definitely not chrome plated and are straw the whole length, now going brown by the head with a hint of blue patches. Not pretty frown
My timing is spot on and I set up my single carb with a colour-tune and the plugs are a very good colour, although I have to admit that now it's pretty much run in I do like to give it a little thrash now and again.
I may consider getting new pipes soon and if so will use blue shield to maintain their looks as much as poss.
As an aside, went for my first ride today grin Now the snow's gone and the rain has washed the salt away it was good to go for a quick spin. For various reasons I've been unable to use the bike for about three months or more and my petrol had gorn orf cry bike didn't wanna go mad
After draining the tank and putting in a gallon of fresh stuff it started on the first kick laugh But while checking the old beast over saw some bubbles and oil seeping out of the front rocker spindle ! my Krankvent was stuck shut!!!!! Not had this happen with one of these before and for the time being I've disconnected it and now all is well. I'm aware that you, and a few others have Kranvents hooked up so keep your peepers on it.
Re: Exhaust pipe Blues - Prevention [Re: john toghill] #295610
01/25/10 12:37 am
01/25/10 12:37 am
hampshire, england
t120mike Offline
t120mike  Offline
hampshire, england
John,
Was in Himmel ist ein Krankvent? Hat man das Fenster im Krankenhaus auf lassen?
Just curious!
mike
Member #: 147
Re: Exhaust pipe Blues - Prevention [Re: t120mike] #295649
01/25/10 8:01 am
01/25/10 8:01 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Hi John/Mike,
Thanks for the warning John. Where do you have yours fitted (incl. distance of the valve from wherever)? Mine is off the front cavity and the valve is up under the steering head.
Mike, it is a high quality PCV (sort of) that we use in our breathers to establish negative pressure in the crankcases.
True.
Re: Exhaust pipe Blues - Prevention [Re: Blapper] #295716
01/25/10 6:09 pm
01/25/10 6:09 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
At one time I too had the 'Krankvent valve' on my Goldie crud up with moisture and oil fumes in the winter time. A soak in hot soapy water cleaned it up nicely. I would be wary of using solvents or compressed air to clear the valve for fear of damage.
BTW, aren't the exhaust pipes on a Well Ridden BI supposed to be a beauteous blue changing to yellow? Art.
Dave - NV
Re: Exhaust pipe Blues - Prevention [Re: t120mike] #295717
01/25/10 6:11 pm
01/25/10 6:11 pm
chatham kent UK
chatham kent UK
Originally Posted By: t120mike
John,
Just curious!
Google translation:- Heaven is a Krankvent? If you leave the window at the hospital? help
What you smokin Mike? Or have you had some dodgy liquor ?
Re: Exhaust pipe Blues - Prevention [Re: john toghill] #295721
01/25/10 6:25 pm
01/25/10 6:25 pm
auf lassen
Aufgelassen.
Do not believe every internet translation machine. laughing
some dodgy liquor
Weinbrand maybe?
whisky
Re: Exhaust pipe Blues - Prevention [Re: Blapper] #295723
01/25/10 6:27 pm
01/25/10 6:27 pm
chatham kent UK
chatham kent UK
Had mine fitted about 6" up from the primary case vent, just before the T for the oil tank breather Blap.
Re: Exhaust pipe Blues - Prevention [Re: dave - NV] #295724
01/25/10 6:33 pm
01/25/10 6:33 pm
chatham kent UK
chatham kent UK
Hi Dave, once it was removed it unstuck itself without any assistance. I've got one on my Sunbeam and it's never stuck even after being left for long periods but for the time being I'm going to leave it off the triumph, as without it, there's no sign of any leaking from pressure and the bike is going very well. Obviously the T140's standard breathing system is up to the job, which isn't true for the Beam.
I don't mind a bit of blue, it's this orrible brown and the rest of the stainless pipes are gold right down to the silencer. Not really a big deal but my vanity may make me want to do something about one day
Re: Exhaust pipe Blues - Prevention [Re: john toghill] #295732
01/25/10 7:11 pm
01/25/10 7:11 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
I was thinking that if it happens to me I would be using Diesel but if soapy water works, I'll use that.
Mike: Boycott still bores for England, but he does it on Test match Special (Radio 4). Jeez, his braying gets on yer tits dunnit?
