bluzdoctor
bluzdoctor
west virginia
20 registered members (Allan Gill), 231 guests, and 449 spiders.
10419 Registered Users
btour 85
Rohan 77
Triless 70
reverb 68
713,669 mail-order LSR
Topics68,327
Posts665,188
Members10,419
wiring diagram for 72' triumph tr6 #292310
01/04/10 10:39 pm
01/04/10 10:39 pm
Bristol, TN. USA
DennisRa1 Offline OP
Bristol, TN. USA
Any one have a picture or source that would help.
Thanks in advance.
1968 Triumph Tiger Competition T100C
2001 HD Road King
Re: wiring diagram for 72' triumph tr6 [Re: DennisRa1] #292464
01/05/10 8:14 pm
01/05/10 8:14 pm
Andover, MN
JGTR6R Offline
JGTR6R  Offline
Andover, MN
Here is the schematic from my Clymer hand book. Just this past winter I used it while restoring my bike and it matched perfectly to the factory wiring.
Mike D
72 650 Tiger 4 speed
Re: wiring diagram for 72' triumph tr6 [Re: DennisRa1] #292518
01/06/10 1:31 am
01/06/10 1:31 am
JubeePrince Offline
JubeePrince  Offline
http://www.classicbike.biz
Re: wiring diagram for 72' triumph tr6 [Re: JubeePrince] #292598
01/06/10 5:15 pm
01/06/10 5:15 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Of course, GABMA has one.
What is it you're trying to discern?
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: wiring diagram for 72' triumph tr6 [Re: RF Whatley] #293535
01/11/10 8:59 pm
01/11/10 8:59 pm
Bristol, TN. USA
Bristol, TN. USA
Rf,
To set the stage...
friend of mine bought 72 frame and engine and a wiring harness
and a few other pcs
bike almost together, have 2 connections that we're not sure of.
location ..close to coils and condensors
1 brown and 1 brown with blue tracer in one connector
where does it connect to?
1 brown and 1 brown with green tracer in another connector
where does it connect?
2001 HD Road King
Re: wiring diagram for 72' triumph tr6 [Re: jim.c] #293540
01/11/10 10:04 pm
01/11/10 10:04 pm
JubeePrince Offline
JubeePrince  Offline
Brown - Stop Lamp/Stop Lamp Switch (front and rear)
Brown/Blue - ignition to rectifier/zener/ neg. battery terminal (assuming pos. earth)
Brown/Green - Tail Lamp
Re: wiring diagram for 72' triumph tr6 [Re: JubeePrince] #293558
01/12/10 12:31 am
01/12/10 12:31 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
JP is correct, except that I would say that Brn/Blu is power from the battery which is not controlled by the ignition switch. In other words it's always ON. Your terminal probably connects to the rectifier DC output. The charging system is never disconnected, since stopping the engine in effect turns it OFF.
PS. A 1972 should have 2 harnesses: 1 front, 1 back.
:bigt
RF Whatley
Cornelia, GA
Re: wiring diagram for 72' triumph tr6 [Re: RF Whatley] #293574
01/12/10 3:18 am
01/12/10 3:18 am
Andover, MN
JGTR6R Offline
JGTR6R  Offline
Andover, MN
:bigt
Thats not counting the head light harness and the breaker point harness(these both connect to the main harness under the gas tank). smile
In the schematic the little rectanle blocks that the wires go to are Lucas female bullet connectors. If multiple blocks are touching then it is a single connector block made for multiple wires. For example, the one for the rear harness is an isolated 4-in/4-out connector.
Mike D
