mike treloar
mike treloar
new zealand
42 registered members (Adam M.), 274 guests, and 337 spiders.
10476 Registered Users
NickL 89
franko 71
Triless 67
747,003 mail-order LSR
Topics68,810
Posts670,260
Members10,476
BSA C15 - Largest Oversized Piston Possible #287583
12/06/09 9:59 am
12/06/09 9:59 am
England
ceefer Offline OP
ceefer  Offline OP
England
I have been working on my C15's brakes and forks for ages and finally I am getting near to working on the engine. I have been reading the advice that I have received from this site before on increasing the performance of the engine, trying to settle upon the most sensible modifications, short of fitting a larger motor altogether.
One suggestion has been to fit a larger Triumph piston to increase the capacity and the compression at the same time. I am coming around to this idea as being most sensible and cost effective.
My question is: what is the largest overbore that a C15 can take and will a Triumph 650cc Tiger piston fit? Does anyone know whether 10:1 Triumph piston will give 10:1 in the C15 or does it alter dramatically? I seem to recall reading somewhere or other that these bikes can be taken out to about 320cc, but I might have imagined this. Any suggestions?
Thank you.
James.
James Alford
Copper Water Features and Garden Ornaments
www.craftedcopper.co.uk
Re: BSA C15 - Largest Oversized Piston Possible [Re: ceefer] #287697
12/06/09 11:44 pm
12/06/09 11:44 pm
James: I've no idea, but I'm another of those guys hates to see a question never responded to. Have you seen this nice website? http://www.bsa-c15.org.uk/
Re: BSA C15 - Largest Oversized Piston Possible [Re: leon bee] #287701
12/07/09 12:33 am
12/07/09 12:33 am
Hmmm,
You might also look at the thread "BSA's for daily use", or something like that?
Maybe those guys over there might have some suggestions?
I've heard of other alternative uses, with parts from other various manufacturers.... It just takes research... Maybe some sort of alterations...
Re: BSA C15 - Largest Oversized Piston Possible [Re: Rickman] #287783
12/07/09 4:20 pm
12/07/09 4:20 pm
A .040" over (70 mm) triumph 500 piston is about as big as I'd want to go. The skirt gets pretty thin at this point. Daytona pistons will give you about 9:1. Remove 1 mm from the head or barrel and you get 10:1 and a better squish.
Re: BSA C15 - Largest Oversized Piston Possible [Re: Alex] #287791
12/07/09 5:26 pm
12/07/09 5:26 pm
British Columbia
hh Offline
hh  Offline
British Columbia
If you sleeve the cylinder, you can use the low compression 650 piston.
Re: BSA C15 - Largest Oversized Piston Possible [Re: hh] #287794
12/07/09 5:32 pm
12/07/09 5:32 pm
I believe that's the case for a B25? Dont see how that would change things for a c15..
Re: BSA C15 - Largest Oversized Piston Possible [Re: Alex] #287799
12/07/09 5:55 pm
12/07/09 5:55 pm
British Columbia
hh Offline
hh  Offline
British Columbia
Alex, is the crankcase spigot hole too small for a bigger sleeve? I've seen Commando barrels with a sleeve that poked through the fins, so I don't think that would necessarily be a problem. I could be confused with the B25.
Re: BSA C15 - Largest Oversized Piston Possible [Re: hh] #287890
12/08/09 3:47 am
12/08/09 3:47 am
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
James, There are a bunch of things you could do to increase power. What is the year and type of motor? The scrambler motors had hotter cams then the road version. They had a different head with a larger intake valve and a bigger choke to take a bigger carb. If you have an early C15 road type bike, not a SS80 you might want to be careful about too much compression. The crank design went through at least 3 improvements to handle more power and compression. If you really want to have high 10:1 compression you might want to consider replacing your timing side bush with a roller conversion. If you have an old bushed crank don't do anything until you replace it with a newer better caged roller bearing one. I guess it all depends on what motor, head, carb you are starting with. A bigger bore and higher compression need to be complimented with the other items I mentioned otherwise wasted effort or blown up motor. Peter
Re: BSA C15 - Largest Oversized Piston Possible [Re: Peter Quick] #287909
12/08/09 8:23 am
12/08/09 8:23 am
England
ceefer Offline OP
ceefer  Offline OP
England
Thank you for the advice: as usual, so helpful.
Alex: thank you for the recommendations on the piston and skimming. This is exactly what I was trying to find out. Do you think that a 650 Triumph piston would be suitable as I have been offered some!
PeterQ: I have a C15F side points engine. It has a roller bearing big-end and the needle-bearing conversion on the timing side. I have already fitted a different cam, larger carb, inlet valve and opened out the inlet ports.
Other suggestions that I have received include changing the entire top end for one from a B25. This does need the barrel spigot to be reduced and a plate (1/4", I think) under the barrel to allow it all to fit. This seems the "obvious" route to take, but having carried out the other work to the head, I am undecided.
I need to consider carefully the most sensible option for my purpose which is to add a little more sparkle to the performance for road use.
James.
James Alford
Re: BSA C15 - Largest Oversized Piston Possible [Re: ceefer] #288355
12/11/09 8:31 am
12/11/09 8:31 am
England
ceefer Offline OP
ceefer  Offline OP
England
Decison reached: I will look out for a 500 Daytona piston and try that along with the 1mm skim.
Next step - searching for a piston.
James.
James Alford
Re: BSA C15 - Largest Oversized Piston Possible [Re: ceefer] #288371
12/11/09 10:23 am
12/11/09 10:23 am
melbourne, australia
7
76degree-triumph Offline
Gday James, I reckon I have a pair of used (never seized) 69 mm pistons from my '69 T100c. If you pay for postage they are yours. tribsa70@hotmail.com if you are interested.
Chris.
1950 Speed Twin outfit
1951 Thunderbird outfit (76 degree racebike, or is it 90 deg now?)
1955 BSA D3 minibike outfit
Triumph solo's
Re: BSA C15 - Largest Oversized Piston Possible [Re: 76degree-triumph] #288544
12/12/09 9:39 am
12/12/09 9:39 am
England
ceefer Offline OP
ceefer  Offline OP
England
Chris. Thank you. I shall e-mail you.
James.
James Alford
Re: BSA C15 - Largest Oversized Piston Possible [Re: ceefer] #292227
01/04/10 4:41 pm
01/04/10 4:41 pm
Houston, Texas (West end of th...
Lucky Strike Offline
76degree-triumph,
Since you have a pair of pistons, and ceefer needs but one, may I ask for the other for my 1960 C15??
Fast. Cheap. Good. Pick any two....
1973 T140V
1960 BSA C15
