The Bonneville Shop
wadeschields
wadeschields
10528 Registered Users
franko 90
NickL 66
785,188 mail-order LSR
Topics69,221
Posts674,274
Members10,528
Mikuni needle jet removal? #289201
12/16/09 7:40 am
12/16/09 7:40 am
DavidP Offline OP
DavidP  Offline OP
OK, I bought the Victory book. The chart says the jet just pulls out, yeah, right.
So, how does one remove the needle jet without messing it up with pliers?
Maybe strip everything from the carb and put the body in the oven?
Re: Mikuni needle jet removal? [Re: DavidP] #289204
12/16/09 9:13 am
12/16/09 9:13 am
Central TX
bones_bir Offline
bones_bir  Offline
Central TX
pull the bowl, and remove the slide. turn it upside down, remove the main jet and ring. then use a soft drift to push the needle jet up through the upper part of the body.
Re: Mikuni needle jet removal? [Re: bones_bir] #289294
12/16/09 10:06 pm
12/16/09 10:06 pm
Yeah,
DON'T use pliers, or anything hard! ..... MAYBE tweezers to re-insert the needle jet, upon reassembly...
There is a machined step in the carb body, the needle jet cannot be pushed 'down'. It must be pushed up through the [round] slide area.
There is also a locating pin... It orientates the needle jet...
You can also, on most Mikuni's I've seen, put the main jet back on the needle jet, after removing the 'ring', or washer as I call it, and use the flat face of the main jet as a pushing surface. JUST snug the jet...
Anything else?
Re: Mikuni needle jet removal? [Re: Rickman] #289318
12/17/09 1:23 am
12/17/09 1:23 am
Springfield Nebraska
Richrd Offline
Richrd  Offline
when all that fails, torch the carb body until it's just too hot to hold, then push the jet out. (wear gloves)
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Mikuni needle jet removal? [Re: Richrd] #289375
12/17/09 8:54 am
12/17/09 8:54 am
DavidP Offline OP
DavidP  Offline OP
Thank you gentlemen.
That was easy enough with a wee bit of heat. I'm always leery of taking even a small hammer to anything without advice.
Now, at least I know they both have p-4 needle jets.
