27 registered members (AML),
173
guests, and 393
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,550
Posts645,144
Members10,170
Most Online3,995 Feb 13th, 2017
Smiths Instrument Repair?
#287657
12/06/09 7:00 pm
12/06/09 7:00 pm
Posts: 188 Missoury
pokie
Missoury
Pardon if this is redundant but I have tried previous threads to no avail. Does anyone have a shade-tree technique for removing the chome bezel on Smiths magnetics without ruining it? Merely cleaning and lubing chronometrics often restored full function without expensive repairs. But, since access to magnetics is virtually denied by the bezel configuration, this clean and lube treatment is also denied. I can`t believe odometer fraud was so rampant as to justify this approach. More likely the cheapo stamped tin "bottom-line" syndrome. Any method of cracking these safes at home without damage would be greatly appreciated.
The fewer there are, the greater the value of each......particularly human beings.
Re: Smiths Instrument Repair?
[Re: pokie]
#287670
12/06/09 8:30 pm
12/06/09 8:30 pm
Posts: 1,524 Auckland NZ
Ignoramus
Auckland NZ
Pokie Ive done a few of them , its impossible not to damage the underside of the bezil but you dont see it when refitted. All ive done is carefully work around the edge with a screw driver lifting the swaged down edge a little at a time, like take many many small "bites" and work around the diameter about 4 times lifting the swage a little more each time. Eventualy you can get the bezil off. To reassemble using old bezil ive made a hard wood disc machined out into a cup which the bezil fits into. Then using a suibale peice of steel bar (about 5/16 or less) just go around the edge pressing it back down with a drill press, again a little at a time. You get a shitty looking underside but hey it beats buying a new bezil each time. Some say you cant reuse the bezil but ive had the same one on and off 3 times! Another great idea someone had on here was that you dont crimp down the bezil again untill you are happy with the speedo (incase it has to come apart again in short order) you just tape it back temporary with black electrical tape. have a look here: not comprehensive but a good start, http://members.shaw.ca/randell/Smith/Speedo.htmlPS you are dead right about magnetics just being a cheeping down of production. When you see the quality of components materials ect in the magnetic that will remove all doubt.....plastic gears ect and muck metal castings crimped to hold shafts, adjuster screws ect ....wonderfull. PPS what ever you do dont demount the needle return spring from its carrier....they are impossible to retension and refit without all manner of special tools.
[Re: ca7a]
#287739
12/07/09 6:04 am
12/07/09 6:04 am
Posts: 4,934 Gnashville
DavidP
I have replaced the glass in a few. As was said, it takes a steady hand and a lot of patience to get the bezel off, even more to get it back on without cracking the new glass. As for being able to do anything once you get inside, I'm stumped. I can't find out what, if any, lubrication is recommended. Outside of the information in the previous link the rest seems to be a deep dark secret known only to the Druids and the few folks who specialize in repair, and they're not talking. I wonder why those Indians on eBay don't start making copies of the magnetic instruments. Somebody does, but they never make 3:1 tachometers.
71 A65L "Zelda" 92 BMW K100rs "Gustav" 72 T120V cafe project "Mr. Jim"
[Re: Whisper]
#287762
12/07/09 1:21 pm
12/07/09 1:21 pm
Posts: 2,213 Atlanta, GA USA
Semper Gumby
Atlanta, GA USA
In Atlanta-
Joel Levine Co. 1178-A Zonolite Place Atlanta, GA 30306 404-219-0594
He did the instuments on my 1969 Firebird.
Gaggle of BSAs a Honda an old BMW and a Montesa Parking lot Elf in training
[Re: Semper Gumby]
#287797
12/07/09 5:47 pm
12/07/09 5:47 pm
Posts: 188 Missoury
pokie
Missoury
Now that`s why this is a great forum. Thanks fellows for the ideas/experience. Ca7a and Gumby,...I appreciate the leads, but would like to cobble it meself, being cheap and handy. And Gumby,..haven`t seen you since the B&W television series. Ignoramus,...I have tried your technique...outcome was lame because of the repairman and tools, but I`ll attempt to make some special tool that might work better. I will follow your other advice. And, your avatar is the finest motorcycle ad ever produced. Whisper...very encouraging advice. Where do you score the tabbed replacement bezels? Would love to see a photo...email: muncie1942@sbcglobal.net. And DavidP,...I have an old bottle of typewriter oil that is the nuts for this type endeavor. Thanks again very much.
[Re: pokie]
#287828
12/07/09 8:38 pm
12/07/09 8:38 pm
Ignoramus
Auckland NZ
Pokie ...there are 2 types of crimped standard bezils , one is chromed bronze/brass the other is polished stainless. The stainless ones realy are a pig to get off but they can be done.
Best solvent Ive found for the actual cleaning is iso-hexane used carefully (laquer thinners is also ok but not as good as hexane), dont get it on the milage wheels or it will lift the white paint off, but works real well if carefully squirted between magnet and alloy plate with a little plactic bottle to losen bits of crap that cause needle to jump, then CAREFULLY blow it out with LOW pressure air 20/25 psi.Any stuborn peices of crud in there can be super carefully lossened with 1000 grit paper working the needle back and foward to buff them off. It does work.
They dont need much in the way of lube but your typewritter oil sounds fine, you can get special clock oil which is also good. Just around bottom bushing with maybee just the faintest trace of oil on the ally disc shaft.
Ive sealed some back up with "plumbers putty" around the glass/bezil join , its as water proof as. Not between the glass and the housing or you will never get it apart again when the putty dries.
Its a real sence of satisfacion when you repair something like that yourself which "experts" charge you a fortune for and some say you cant.
Keep us posted on how you get on, there are lots of common problems on those which are pretty easy to fix in "non standard" ways.
Good luck
[Re: Ignoramus]
#287965
12/08/09 7:27 pm
12/08/09 7:27 pm
Posts: 188 Missoury
pokie
Missoury
Igno,...Damn, you Auckers know your business. Have you thought of doing seminars on this?...This info has to be helpful to a goodly amount of folks. Thanks again for sharing the expertise.
