GOLD S-TARvin R.I.P.
Ohio, U.S.A.
24 registered members (Boomer), 130 guests, and 370 spiders.
Nomdegom, Andy Mac, kwbikr, RandomTask, George Henstorf
10379 Registered Users
Mori55 94
NickL 86
Stuart 82
DavidP 81
reverb 73
Triless 68
687,906 mail-order LSR
Topics67,995
Posts661,419
Members10,379
Bent lower yoke/ Triple Tree #286740
12/01/09 4:29 pm
12/01/09 4:29 pm
Canada
dracko Offline OP
dracko  Offline OP
Canada
Hey guys, I recently bought a set of Trees from a member on the board here and the lower yoke is bent. Just wondering if anybody has a tried and true method of straightening them. I was thinking about using some shims and a vice and clamping them/bending them a little at a time, but I'm all ears because I've never attempted this before. They are 68-70 Triumph 650 trees.
Thanks in advance!
Re: Bent lower yoke/ Triple Tree [Re: dracko] #286749
12/01/09 5:54 pm
12/01/09 5:54 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Typically the crown does not bend becasue there is not enough fork stantion engagement there to effect a bend. So it's the triple tree you need to worry about.
The triple tree either looks like a piece of spaghetti (big crash; non-fixable), or it's only out a couple of degrees (little crash; repairable). Additionally, 95% of the time the forks get pushed to one side. That is to say, it's hardly ever a straight-on hit, owing to the fact that most riders try to react in some way to the car/ guard rail/ animal blocking their path. Typically, these type crashes result in damage to only one side of the tree most of the time.
The best way to straighten a triple tree in this common condition is to assemble the tree and crown onto the bike and install 2 brand-new naked stantion tubes (with snug top caps and pinch bolts). By simple observation of the parallelism you can tell which tube has been pushed back. [Based of course on the assumption that a passing motorist did not yank the bike's front end forward. laughing ]
All you have to do then is pull the lagging stantion back to it's original forward position. This is done by turning the fork assembly in the opposite direction of the wreck, placing the foot firmly upon the forward motor mount, and making a judicious application of physical strength at the bottom of the affected stantion to pull it back into parallel with its neighbor.
Works every time. Takes about 4 or 5 tugs and 15 minutes.
Your back will only hurt for a week. bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Bent lower yoke/ Triple Tree [Re: RF Whatley] #286756
12/01/09 6:18 pm
12/01/09 6:18 pm
I think you will be surprised how soft the triples are. Before I start with the straightening I put good tubes into the crown tapers (off the frame) and tighten up the top nuts to bring the tubes solidly into the tapers. This will give you an idea if the crown is bent when you look at the distance between the tubes as you move toward the bottom. The fore and aft issue is also somewhat evident but not easy to see this way.
Re: Bent lower yoke/ Triple Tree [Re: Gordo in Comox] #286935
12/02/09 7:46 pm
12/02/09 7:46 pm
Canada
dracko Offline OP
dracko  Offline OP
Canada
Hey Whatley and Gordo, thanks alot for the info. The trees aren't bent much, so it sounds like it won't take much to straighten them out. I don't have a new pair of tubes to use, nor will I any time soon as I've since bought a new lower tree locally and have the front end partially assembled with some "used" tubes. But maybe down the road I'll straighten them out before selling them. Unless someone is looking to buy a slightly tweaked lower tree for a 68-70 Trump?
thanks again! I appreciate the info.
Re: Bent lower yoke/ Triple Tree [Re: dracko] #286954
12/02/09 10:55 pm
12/02/09 10:55 pm
redondo beach, ca
Bob G Offline
Bob G  Offline
redondo beach, ca
You can easily straighten triple trees on a hydraulic press and a v-block. If any one wants the procedure just let me know. I have probably done a couple dozen over the years.
Bob Gregor
Re: Bent lower yoke/ Triple Tree [Re: Bob G] #287403
12/05/09 10:09 am
12/05/09 10:09 am
Devonport Tasmania
TJD Offline
TJD  Offline
Devonport Tasmania
Have a look at section G4 of the workshop manual.
