Crazy
Crazy
Australia Tweed Heads
45 registered members (AML), 271 guests, and 410 spiders.
10476 Registered Users
NickL 89
franko 71
Triless 67
746,989 mail-order LSR
Topics68,810
Posts670,256
Members10,476
Opinions on a pair of butchered crank cases . . . #280962
10/26/09 6:36 pm
10/26/09 6:36 pm
Derbyshire
RossP Offline OP
RossP  Offline OP
Derbyshire
Hello folks,
I picked up a pair of perfect condition (eBay's words not mine!) late T100 unit cases a while ago only to find they had been drilled around the drive side bearing. Presumably by some previous 'craftsman' wanting to drift out the bearing race. . .
So what does everyone think?
Should I:
Build up the motor and not worry about it?
Weld up the holes and hope not to distort the machining for the bearing?
Fill the cases with soil, plant some tulips and look forward to Spring?
Ross
Re: Opinions on a pair of butchered crank cases . . . [Re: RossP] #280967
10/26/09 6:51 pm
10/26/09 6:51 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Would you get unintentional sharing of fluids through them?
Blapper redwine
Re: Opinions on a pair of butchered crank cases . . . [Re: Blapper] #280971
10/26/09 7:00 pm
10/26/09 7:00 pm
Derbyshire
RossP Offline OP
RossP  Offline OP
Derbyshire
Well they're late cases so the primary and cranckcase oil are shared anyway. So I doubt the extra holes would be the end of the world in that respect.
And in any case, a bit of JB weld would soon make them oil tight.
Ross
Re: Opinions on a pair of butchered crank cases . . . [Re: RossP] #280974
10/26/09 7:07 pm
10/26/09 7:07 pm
sharing of fluids
blush
Blapper please explain... I get certain ideas reading this. crazy
Re: Opinions on a pair of butchered crank cases . . . [Re: Ger B] #280976
10/26/09 7:30 pm
10/26/09 7:30 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
laughing laughing laughing
Steady on old chap!
Re: Opinions on a pair of butchered crank cases . . . [Re: Blapper] #280992
10/26/09 8:33 pm
10/26/09 8:33 pm
Melbourne Fl
Terry_tr6 Offline
Terry_tr6  Offline
Melbourne Fl
considering that the bearing isn't sealed and the outer race would occlude the holes anyway, i'd forgo the JB(and that's saying a lot from me) and eliminate the chance of it coming loose. the holes thru the bearings are a lot bigger than the ones in the case even if they weren't blocked by the race
Re: Opinions on a pair of butchered crank cases . . . [Re: RossP] #280998
10/26/09 9:21 pm
10/26/09 9:21 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
As long as the holes are carefully de-burred at the bearing locating shoulder,I can't see a problem.
Normally,if you heat the case to running temperature,or a little beyond,and drop it on a block of wood these bearings will just fall out.Maybe this one was a little tighter,and you may have more crush on the bearing.If you use the proper C-3 clearance bearing,you should still have some bearing clearance when the engine is cold(do check this).
If you wanted to run a sealed primary,you'd have more holes than this to tap out and plug up.
Re: Opinions on a pair of butchered crank cases . . . [Re: Pete R - R.I.P.] #281006
10/26/09 10:23 pm
10/26/09 10:23 pm
australia
douglas Offline
douglas  Offline
australia
They're stuffed! Send them to me,i have this huge back garden to bury them!
Re: Opinions on a pair of butchered crank cases . . . [Re: douglas] #281016
10/26/09 11:13 pm
10/26/09 11:13 pm
John Healy Online content
John Healy  Online Content
There is a Triumph TriCor service bulletin describing drilling these holes when you run into a situation when you run into a drive side roller bearing that will not come out using heat. If you heat the entire crankcase, this bearing will typically fall out like Pete described above. If you heat the entire case to 225 to 250F you will find the bearing easily removed.
The mistake most people make is to localize the heat to the area around the bearing. Because the aluminum around the heated area isn't expanding in concert with the area around the bearing, the aluminum extensibly can only expand inward and bearing housing actually gets tighter around the bearing. You can throw enough heat at the casting doing it this way (450F plus), but it is kinder to heat the entire crankcase.
Re: Opinions on a pair of butchered crank cases . . . [Re: John Healy] #281072
10/27/09 7:42 am
10/27/09 7:42 am
Derbyshire
RossP Offline OP
RossP  Offline OP
Derbyshire
Thanks for that John, I've luckily never come across a drive side bearing that wouldn't come out easily with a bit of heat - can usually get the cases up to temperature just using a hot air paint stripping gun. Other than that they go in the oven!
It being mentioned in the service bulletin is re-assuring, and I'm tempted to just run the cases as they are. But I'm also interested in your views on whether the holes are likely to raise the chances of the cases/bearing failing.
I'd say the purpose of the part of the bearing housing thats been drilled is more to hold the seal than support the bearing - but that could just be wishful thinking on my part!
Ross
