Unclviny
Unclviny
Houston, Texas
51 registered members (Andy Haldeman), 319 guests, and 458 spiders.
eberhard, Norman Woollons, LandoLando, MikeA, Jay Gilling
10255 Registered Users
Stuart 75
Lannis 70
607,571 mail-order LSR
Topics67,091
Posts651,065
Members10,255
57 A10 Clutch adjustment #274130
09/10/09 7:21 pm
09/10/09 7:21 pm
Cape Cod
Shewrench Offline OP
Cape Cod
cant seem to keep from slipping.no book instructions.
Double nut six stud, new basket and clutch, chain and engine sprocket.
tried w/nuts just equal to end of threads, adjusted pushrod w/1/16 play. still slipping.
any suggestions? thanks.
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Shewrench] #274146
09/10/09 9:15 pm
09/10/09 9:15 pm
Have the corks ever been replaced? Might need to replace the cork inserts... Or friction plates...
Another effort that has assisted me before, is to have the steel plates lightly sand blasted.
Perhaps the springs have lost their tension?
Looking back at your post, you may not have enough tension applied to the springs, adjust the nuts equaly tighter, but not so tight that the coils bind. Somewhere between the nuts at the end of the studs, and 'clutch in' coil bound, you should find the sweet spot.
You have lubed your clutch cable, right??? A drop of oil on the pivot of your clutch lever?
If you disassemble your clutch pack, while it's apart, check that the steel plates are flat. If not, replace.
Re: 57 A10 Clutch adjustment [Re: Rickman] #274195
09/11/09 9:42 am
09/11/09 9:42 am
BSA_WM20 Offline
BSA_WM20  Offline
Have a good look at the corks.
if they get too dry it is not unheard of for them all to move in a plate so that on one side they are flush with the steel with the expected outcome
Re: 57 A10 Clutch adjustment [Re: BSA_WM20] #274214
09/11/09 1:08 pm
09/11/09 1:08 pm
Cape Cod
Cape Cod
hey thanks for responses,
I replaced all plate and corks,new springs, new corks on sprocket too.
also back filed all burs off each stamped steel plate
will try bringing spring tension in equal measure and try.
keep posted
gg
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Shewrench] #274215
09/11/09 1:09 pm
09/11/09 1:09 pm
Cape Cod
Cape Cod
I roughed up all steels w/150 grit.
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Shewrench] #274225
09/11/09 3:24 pm
09/11/09 3:24 pm
Asheville, North Carolina
ca7a Offline
ca7a  Offline
Are you running the clutch wet or dry?
David
Re: 57 A10 Clutch adjustment [Re: ca7a] #275196
09/18/09 2:17 pm
09/18/09 2:17 pm
Cape Cod
Cape Cod
wet and dry, I tried both ways.
Now the beast wont start, charged battery , no help.
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Rickman] #275198
09/18/09 2:19 pm
09/18/09 2:19 pm
Cape Cod
Cape Cod
A great suggestion to blast the plates, they are flat...but very smooth. now she's not starting
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Shewrench] #275209
09/18/09 3:19 pm
09/18/09 3:19 pm
The only way the clutch can contribute to "not starting" is if the clutch is now slipping, and the kickstarter can't turn the engine over.
Is the engine turning over when you kick it? If so, it's time to drop the clutch and start checking compression, ignition, fuel ....
Re: 57 A10 Clutch adjustment [Re: Shewrench] #275210
09/18/09 3:41 pm
09/18/09 3:41 pm
Orleans Massachusetts
Skeet Offline
Skeet  Offline
It is not a beast, and it will start. I'm on my way over to get it some good healthy kicks. bigt
Skeet
1964 Hornet
1970 TR6R
1971 Norton
1972 XLH
Re: 57 A10 Clutch adjustment [Re: Skeet] #275215
09/18/09 4:29 pm
09/18/09 4:29 pm
Cape Cod
Cape Cod
Now we got it . thanks to dave and his good leg.
still dragging a -bit
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Shewrench] #275220
09/18/09 4:59 pm
09/18/09 4:59 pm
Skeet Offline
Skeet  Offline
Chripes. Now I feel like a gosh darn hero. grin Anyway the owner of this wonderful little Golden Flash will get that clutch spot on. No question in my mind. Very talented mechanical abilities. Just needs a little encouragement from us older folks every now and then.
Skeet
1964 Hornet
1970 TR6R
1971 Norton
1972 XLH
Re: 57 A10 Clutch adjustment [Re: Skeet] #275390
09/19/09 3:13 pm
09/19/09 3:13 pm
Oslo Norway
Per B Offline
Per B  Offline
Oslo Norway
If you are running the 6 spring clutch originally mounted on your bik yoy will find it very difficlt to work propoerly. This clutches are yust crap. If you adjust it to free out completely, enabeling easy to find neautral at standstill it will slip. If you adjust for no slip you are not able to engange neutral at standstill and you will have problems with creeping. The only way is to replace the clutch for a later 4 spring Triumph type used on later A10's. Several shops in UK among them C&D Auto and Draganfly sells complete kits at reasonable prices.
Per
best regards
Per
Goldi Clubmans
Goldi Scrambler
Rob North R3
OIF A65
Re: 57 A10 Clutch adjustment [Re: Skeet] #280263
10/22/09 1:33 pm
10/22/09 1:33 pm
Cape Cod
Cape Cod
SHE IS RUNNING GREAT, THANKS TO SKEET'S HELP. CLUTCH STILL DRAGS A LITTLE BUT DOES NOT SLIP. I AM GOING TO RUN IT FOR A WHILE AND SEE IF IT BREAKS IN CONSIDERING THAT ALL THE COMPONENTS ARE NEW.
MAYBE I WILL SAND BLAST THE PLATES IF IT DOESN'T.
THANKS FOR ALL THE HELP.
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Shewrench] #280269
10/22/09 1:53 pm
10/22/09 1:53 pm
Cape Cod
Cape Cod
GETTING A 4 SPRING CLUTCH IS MY LAST RESORT , JUST SPENT ALL MY DOUGH ON THIS ONE , POINT TAKEN THOUGH AND ITS GREAT FEEDBACK,THANKS
gg
57 A10
71 TR6
Re: 57 A10 Clutch adjustment [Re: Skeet] #280271
10/22/09 1:59 pm
10/22/09 1:59 pm
Cape Cod
Cape Cod
YOU ARE A GOOD TEACHER.
57 A10
71 TR6
