Panhead EL
Panhead EL
Virginia
37 registered members (79T140E), 255 guests, and 438 spiders.
LandoLando, MikeA, Jay Gilling, scratchedtank, Magic Monkey
10253 Registered Users
Stuart 72
Lannis 67
NickL 48
606,779 mail-order LSR
Topics67,086
Posts650,981
Members10,253
T100R tappets, blocks #279437
10/17/09 7:33 am
10/17/09 7:33 am
Berkeley, Ca. USA
ACWilkins Offline OP
Berkeley, Ca. USA
Engine is a "69 T100R parts basket missing its barrels and tappet blocks. I have new old stock barrel w/o tappet blocks,and also the tappets from the original engine. I will be buying new blocks- is it possible to re-use the old tappets? New ones are expensive, reground are less so, but if the old ones will work OK that would be good. Obviously, they are not going to go back into the bores they came out of and the flanges are not likely to be exactly the same tolerance either.Then,what about the cams and cam/tappet wear in the future? Is it necessary to replace everything here (cams, tappets, and blocks ) to avoid early failure? What to do here? Thanks in advance for the help, Alan T100R
Re: T100R tappets, blocks [Re: ACWilkins] #279459
10/17/09 1:18 pm
10/17/09 1:18 pm
spfld vt
phantom309 Offline
phantom309  Offline
spfld vt
They will be fine as long as they are free and don't have any flat spots.
Tim Joyce
sponsors
D@D cycles
Works shocks
Glass from the past
Re: T100R tappets, blocks [Re: phantom309] #279562
10/18/09 2:09 am
10/18/09 2:09 am
Berkeley, Ca. USA
Berkeley, Ca. USA
I have read that the factory race bikes in '66&'67 used tappets ground to 3" radius. I am thinking that the larger radius eased the stress on the cams and tappets. Are these available? Anyone knowledgeable care to comment on why this was done? Thanks, Alan T100R
