Buckshot1
Buckshot1
Diamond Springs, Kalifornia
38 registered members (Al Eckstadt), 334 guests, and 364 spiders.
10419 Registered Users
btour 88
reverb 75
Triless 75
711,216 mail-order LSR
Topics68,310
Posts665,061
Members10,419
A65 steering neck roller bearing source? #27692
07/23/07 9:18 pm
07/23/07 9:18 pm
Texas Gulf Coast
Curmudgeon Offline OP
Texas Gulf Coast
I am looking to upgrade a '70 A65 Lightning. Would like to replace the loose ball neck bearings with some tapered roller bearings. Anyone know of a source where I could get them? Thanks.
reliccycles.com
Re: A65 steering neck roller bearing source? #27693
07/24/07 6:13 pm
07/24/07 6:13 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
I dont know if an actual retrofit kit is available but what I have done(from feeble memory , FWIW) is simply buy the tapered bearings from an industrial bearing supplier to fit the top and botto of the stem, as I recall they are different diameter , and turn some cups to mate the ID of the frame to the OD of the new bearing . Preetty simple , but you will end up with a gap that might make the stock headlamp mounting ears look awkward . I have found that the Triumph covers seem to fit well .
FWIW-BONZO
Re: A65 steering neck roller bearing source? #27694
07/24/07 6:20 pm
07/24/07 6:20 pm
kommando Offline
kommando  Offline
Again from a feeble ,memory, you can get some Timkin bearings with the correct ID but the OD is 2.25" instead of the 2.125" needed, I got the OD ground down. The length of the bearing is also greater leaving toofew threads engaged at the top, so I got the inners shortened by EDM machine.
Re: A65 steering neck roller bearing source? #27695
07/24/07 6:59 pm
07/24/07 6:59 pm
I believe Frank Diehl at classic cycle works has 'em. Not cheap, but still cheaper than getting them ground down.
Re: A65 steering neck roller bearing source? #27696
07/24/07 7:40 pm
07/24/07 7:40 pm
Essex,England.
rebelpaul Offline
rebelpaul  Offline
Essex,England.
If its of any help SRM in Aberystwyth,Wales do a direct replacement headstock taper bearings for the pre-oil in frame A65. As I remember they cost about 65 for the set,apparently they manufacture the bearings themselves.Their email address is www.srm-engineering.com.Cheers,Paul.
78 TRIUMPH T140v BONNEVILLE
52 TRIUMPH 6T THUNDERBIRD (custom)
64/65 BSA A65 ROCKET (trike)
68 BSA B25 FLEETSTAR
Re: A65 steering neck roller bearing source? #27697
07/25/07 4:10 pm
07/25/07 4:10 pm
Texas Gulf Coast
Texas Gulf Coast
Thank you all. I think my best bet is to contant Frank Deihl and find out how much it's going to hurt.
reliccycles.com
Re: A65 steering neck roller bearing source? #27698
07/28/07 3:25 am
07/28/07 3:25 am
wisconsin
BSAketcase Offline
BSAketcase  Offline
wisconsin
please post after callin frank, Im interested in the same set-up.
Re: A65 steering neck roller bearing source? #27699
07/28/07 2:09 pm
07/28/07 2:09 pm
Texas Gulf Coast
Texas Gulf Coast
I called Frank and he has the bearings for around $65 for the pair.
reliccycles.com
Re: A65 steering neck roller bearing source? #27700
07/28/07 3:01 pm
07/28/07 3:01 pm
Saint John, New Brunswick
BSACafe Offline
BSACafe  Offline
If you manage to get a set for $65 then let me know. I downloaded his catalog, and it has a taper roller bearing set listed at $89.95.
Jer
http://www.caferacer.ca
1968 BSA Lightning Cafe
1968 BSA Thunderbolt
1969 BSA Royal Star
1972 BSA Thunderbolt
Re: A65 steering neck roller bearing source? #27701
07/29/07 12:37 am
07/29/07 12:37 am
wisconsin
BSAketcase Offline
BSAketcase  Offline
wisconsin
yeah, I would order a set for $65, if it is a direct fit... but would the ears still have to be modded with these bearings?
Re: A65 steering neck roller bearing source? #27702
07/29/07 3:41 pm
07/29/07 3:41 pm
Texas Gulf Coast
Texas Gulf Coast
I've done this mod on Triumphs and there is a noticeable gap between the top of the headllight ear and the top tripple clamp. Frank said that it's the same thing with BSA. He suggested installing an Oring there to take up the slack and prevent water from getting in.
The bearings should be arriving this week and I will post what my final cost was.
reliccycles.com
Re: A65 steering neck roller bearing source? #27703
07/31/07 7:00 pm
07/31/07 7:00 pm
Texas Gulf Coast
Texas Gulf Coast
OK gents, the roller bearings arrived today. They are indeed listed for $89.85 retail, but I got a dealer discount on them because I have a Britbike shop, Relic Cycles. Cheers.
reliccycles.com
Re: A65 steering neck roller bearing source? #27704
08/01/07 12:42 am
08/01/07 12:42 am
wisconsin
BSAketcase Offline
BSAketcase  Offline
wisconsin
still not a ridiculous price if they are a good fit. I used the stock ball bearings, tightened them just enough to stop the fall-away of the frontend, and now they have some bad flat spots(ratcheting). I dont want to buy another set of races, so this deal is the way to go, especially to prevent problems down the road...
If you remember, throw up a quick post once you get them installed, and let me/us know how they fit and work.
thanks
jay
