ADC
ADC
CALIFORNIA
32 registered members (Beach), 166 guests, and 386 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 87
Triless 66
754,293 mail-order LSR
Topics68,905
Posts671,177
Members10,485
primary chain - half link ok?? #274720
09/15/09 3:02 pm
09/15/09 3:02 pm
Switzerland
zambu Offline OP
zambu  Offline OP
Switzerland
While doing a service on my A10 RR 56, I noticed that I need to tension the primary chain. As the gearbox was already almost at the rear end of its way (as well as the rear wheel), I tried to shorten the chain. Then it was too short.. The only solution was to fit one of these half links. The chain expert who had this in stock told me, it has 30% less strength. Do I have to worry about it?
Re: primary chain - half link ok?? [Re: zambu] #274755
09/15/09 8:13 pm
09/15/09 8:13 pm
uk
gram Offline
gram  Offline
uk
You might worry if it breaks suddenly.A friend of mine suffered serious head injuries when he and his wife were deposited on the road after their A10's primary chain broke.He was'nt quick enough to de-clutch,plus the additional weight of a passenger was more than he could handle during the resulting slide.
Gram
Re: primary chain - half link ok?? [Re: zambu] #274759
09/15/09 8:19 pm
09/15/09 8:19 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Zambu:
If your chain has streched to the extent it needs shortening that much I personaly would be inclined to replace it. Primary chain takes a lot of load the way it whips about under varying loads. I cant imagine it would be that expencive even for a top brand. Worn out chain also wrecks sprockets!
Lay the cleaned/deoiled chain out on the bench and see how much length you can make it gain by pulling it and compressing it lenghways to see how much play you have in each link (divide amount of streach by number of pins) that will tell you if the streach is pin wear or plates have streached (most likley both) .....you might feel diffrent about replacing it after than exercise. You can calculate the lenght it should be new by number of pitches X pitch
Personaly I wouldnt use a half link on a primary for other than a real temporary fix (like to get you home or something) Im sure others will chip in.
Re: primary chain - half link ok?? [Re: Ignoramus] #274774
09/15/09 10:14 pm
09/15/09 10:14 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
Some A10s had 1/2 links standard in both primary and rear chains.
I don't use them, I just use a chain one pitch shorter in the primary and rear to fit.
Trev.
Re: primary chain - half link ok?? [Re: trevinoz] #274803
09/16/09 2:44 am
09/16/09 2:44 am
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Trev:
Big diffrence between a 1/2 link fitted as standard with a new chain and using a 1/2 link to compensate for chain streach/wear on an old chain though.
Re: primary chain - half link ok?? [Re: Ignoramus] #274813
09/16/09 6:37 am
09/16/09 6:37 am
A Trident rear chain came with a half link. Only catch was that by the time you could do without the half link, your chain was shot.
Don't think I'd trust one on a primary chain, though.
Re: primary chain - half link ok?? [Re: Ignoramus] #274815
09/16/09 6:52 am
09/16/09 6:52 am
Switzerland
zambu Offline OP
zambu  Offline OP
Switzerland
Thanks for the infos! The chain (Renold) has 5000km on it, not that much I think. Even when new, I could not adjust it to a middle position. One pitch less was way too short. So I shifted the gearbox near the end and it was ok without the 1/2 link. But now with the streched chain it is not possible anymore. I just had a close look into my Haynes manual and on one of the pictures I saw a 1/2 link!! Like Trev said, some A10 must have had this as standard...
Re: primary chain - half link ok?? [Re: zambu] #275102
09/17/09 10:20 pm
09/17/09 10:20 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
Ignoramus,
I agree with you. Chain is not expensive compared to unobtainable parts!
Trev.
Re: primary chain - half link ok?? [Re: trevinoz] #275147
09/18/09 6:51 am
09/18/09 6:51 am
Switzerland
zambu Offline OP
zambu  Offline OP
Switzerland
I measured the chain as Ignoramus proposed. The difference from streched to non streched was 7mm. This is 0.1mm per pitch. A lot! This is worn out. So I went to the Renold-Distributor which is close to me and got a new one. Costs 24 Euros. Interesting detail: The old type is no longer produced any more. They have a new design which they told me is better. Different plates, improved steel treatment. It is the 1/2 x 5/16 08B.
Thanks for your help! Have a nice weekend, in the workshop, on the road or wherever!!
Re: primary chain - half link ok?? [Re: zambu] #275234
09/18/09 6:24 pm
09/18/09 6:24 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Zambu:
You have made a good decision I recon. If you want to know if your A10 chain was standard with the 1/2 link find in the manual how many pitches it is supposed to be. If it is an ODD number it uses the 1/2 link. If it is an EVEN number it does NOT. Eg 81 pitch = 1/2 link 80 pitch = no 1/2 link. (just random numbers as example).
Your chain should have lasted way longer than 5000 miles. Has it been run dry? or sprockets miss aligned?
The thing about Renolds chain is that there are at least 3 grades. Just becasue it is renolds doesnt mean its suitable for motorcycle! Renolds supply lots of industrial users (eg electric motors driving gearboxes at low speed and constant loads) and the industrial grades of chain are not intended for bikes. Typicaly industrial grade chain will have narrower plates of a diffrent Rockwell hardness. They are intended to be routinley replaced in maintanance work at specified hours of use. I susspect your 5000 mile chain may have been an industrial grade. Same applys to rear chain.
Back in the day when i didnt have any money or experience and couldnt afford a new rear chain on my A65 I got some industrial chain "end of rolls" free at a job and made one up with 4 joiners, it lasted till i could afford a decent one, I oiled it weekly! and greazed it 2 weekly!.
Some times a mans gotta do what a mans gotta do
Good luck
PS
dont forget to keep a close eye on your new chain you will probably need to retension it 2-3 times in 1000-2000 miles before it takes up its perminamt "set"..first adjustment should be at 250 miles or less!.Running a new chain with too much play will stuff it in short order! After it takes up its "set" it should last for ages.
