maylar
maylar
Connecticut
35 registered members (AML), 234 guests, and 451 spiders.
10257 Registered Users
Stuart 77
Lannis 60
TBolt72 46
609,133 mail-order LSR
Topics67,118
Posts651,344
Members10,257
New Amals or sleeved? #275094
09/17/09 9:56 pm
09/17/09 9:56 pm
Connecticut
YankeeJerry Offline OP
Connecticut
I have 1967 Triumph T120R. Should I buy new Amals for it or get mine sleeved? How about a new body and slide? Help me decide please.
Re: New Amals or sleeved? [Re: YankeeJerry] #275097
09/17/09 10:08 pm
09/17/09 10:08 pm
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
have you considered an oriental replacement?pkw carbs are 1/2 the price.i just put two on a bitsa project they solved some problems.but i havent started the bike yet so i cant vouch for anything else yet. ive read in the forum about them but havent heard any thing good or bad yet.
Re: New Amals or sleeved? [Re: jaycee] #275099
09/17/09 10:11 pm
09/17/09 10:11 pm
Get yer amals sleeved, clean out the pilot and flatten the joint faces and they'll work forever and not look like a tutu on a boxer.
Re: New Amals or sleeved? [Re: Alex] #275111
09/17/09 11:40 pm
09/17/09 11:40 pm
gastonia nc
raf940 Online content
raf940  Online Content
gastonia nc
if you clean out the pilot jet first and make sure there are no air leaks you might find they do not need sleeving at all....
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: New Amals or sleeved? [Re: Alex] #275167
09/18/09 11:01 am
09/18/09 11:01 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Must agree with Alex, a well sorted AMAL is a great carb, good performance and economy and a lot less complicated than the Tutu option.
1969 TR6R
Re: New Amals or sleeved? [Re: Tiger] #275178
09/18/09 12:29 pm
09/18/09 12:29 pm
John Healy Offline
John Healy  Offline
" Should I buy new Amals for it or get mine sleeved?"
Could you hold them a bit closer to the computer so we can see which carbs you have and their condition.
Re: New Amals or sleeved? [Re: John Healy] #275205
09/18/09 3:10 pm
09/18/09 3:10 pm
I do not want to start another "AMAL yes - no... why yes - why not" discussion, but... (there's allways a but) smile
I've got my PWK sorted out now. It took some time due to lack of time, but (yes I told you) the bike runs perfectly with it.
[click to read]
Re: New Amals or sleeved? [Re: Ger B] #275344
09/19/09 10:08 am
09/19/09 10:08 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
I bought new Amals for my lightning a couple of years ago. I have had to address a sticking slide when I changed slides for a leaner mixture. If I had to do it over I would resleeve.
Re: New Amals or sleeved? [Re: Mr Mike] #275360
09/19/09 12:16 pm
09/19/09 12:16 pm
gavin eisler Offline
"Like a tutu on a boxer" , very well put sir, I agree completely,
re sleeve would be my preference, be prepared to lean out the slide cutaway though, re sleeving is usually done to a tighter slide clearance than the rattling fit of a stock AMAL.
Stock is at least 3 thou clearance. A friend who is a good machinist resleeved his concs to 1 thou clearance then had to borrow a set of old carbs from me to get the bike running properly until he got new leaner slides .
My own bike still has its original carbs, there like my favourite hammer only had 3 new shafts and one new head since I got it.Pod
Re: New Amals or sleeved? [Re: gavin eisler] #275384
09/19/09 2:43 pm
09/19/09 2:43 pm
Phoenix, AZ
Dale Hoover Offline
Dale Hoover  Offline
Phoenix, AZ
Responding to the original question, I think you have to consider the condition of your current carb, the longevity you're seeking, and your budget. The only way to go for long lasting solution IMHO is a installing a carb that has dissimilar slide/body materials. But there are options based on your budget.
If your old carb body is decent, and the brass is in serviceable shape, then I would re-sleeve. Lund does a great job with the rebore, sleeving, and machining the mounting surface for a virtually new fit to the manifold.
But if your carb body is funky and/or your jets are worn anyway, it may make more sense to buy a new AMAL. You'll get like-new performance...for a while. Eventually the slide will wear out again and you'll be faced with sleeving or replacing once more.
So, a new chrome slide ($65USD) on a new AMAL is the way to go for longevity. Kind of spendy, but will avoid costly and maddening tuning hassles in the future.
Sleeving = $80USD ea. plus $30 worth of new jets
New AMAL with chrome slide = $350USD(?)
My 2cents...
Dale
Re: New Amals or sleeved? [Re: YankeeJerry] #275485
09/20/09 12:57 am
09/20/09 12:57 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
I recently fitted stainless sleeves to a pair of slides,didn't rebore the bodies.These carbs are more than 30 years old and run better than new.
I am running less than the 0.004"clearance, and opened the cutaway slightly.
The main things to get right are needle jets and cleared out pilot jets.
Re: New Amals or sleeved? [Re: Dale Hoover] #276120
09/24/09 7:59 am
09/24/09 7:59 am
Nanaimo, B.C. Canada
W
Wilfred Online content
Wilfred  Online Content
W
The 930 on my T100 was sleeved over 25,000 MILES ago and is still a treat, as they say. Mind you, I do use an air cleaner and I do change the filter and all those silly things. I think that a well done resleeve job should last longer than a new carb if they are made of the same similar materials that they originally were. Walridge had mine done for me and we also had a 930 done for a Victor, too. My thoughts......Wilf.
"It's about the ride..."
Re: New Amals or sleeved? [Re: Pete R - R.I.P.] #276130
09/24/09 10:50 am
09/24/09 10:50 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
I would be interested to hear how you achieved that Pete.
The std AMAL slide is very thin wall and quite delicate structurally. presumably you reduced that further to fix your sleeve ?
Sweating the sleeve to an original slide would appear to be impractical, did you use epoxy ?
1969 TR6R
Re: New Amals or sleeved? [Re: Tiger] #276221
09/24/09 8:12 pm
09/24/09 8:12 pm
Vic. Australia
Vic. Australia
I suppose everyone who sleeves slides uses a similar technique.The sleeves I used are about 1/16" thick.The slide wall is about 2mm at the thinnest part,so there is still 0.020"or so when its turned down to fit a sleeve,which is just pressed on,then finish turned or ground.I ground mine.
All turning/grinding is done on a mandrel inserted in the bottom of the slide,and the slide is secured with a 1/8" screw where the needle fits in.
Re: New Amals or sleeved? [Re: Dale Hoover] #276263
09/25/09 2:30 am
09/25/09 2:30 am
Rowayton, CT, USA
john zabel Offline
john zabel  Offline
Rowayton, CT, USA
I would agree with Dale, I replaced 2 early 932's on my 1966 Spitfire two weeks ago with new 930's from Ken Jackson. The new 930's come from remanufactured molds and have removable pilot jets. I had a mismash of early 932's and I was chasing a problem in the right carb. In my case, it made more sense to me, to replace both carbs rather than continue with replacing jets and working on the carb bodies. If I had sent them to Lund for resleeving, they could have corrected the problem, however, I felt going with two new 930's was the safest route and only cost a few dollars more. The new carbs are great. On the first test drive I took the bike to 6,200 in first and second very easily, which I couldn't do with the old carbs. Just my 2 cents.
Re: New Amals or sleeved? [Re: YankeeJerry] #287741
12/07/09 6:23 am
12/07/09 6:23 am
australia
coopers Offline
coopers  Offline
australia
Has anyone had Amals Resleeved by someone in Australia. I need mine done and am having trouble finding someone in Aus who do it. Cheers Coopers
