39 registered members (Adam M.), 229 guests, and 123 spiders.
10383 Registered Users
NickL 98
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,466 mail-order LSR
Topics68,027
Posts661,819
Members10,383
Mikuni Carbs and Manifold Adapter #274910
09/16/09 7:59 pm
09/16/09 7:59 pm
Farmington,Connecticut,USA
JBMorris Offline OP
JBMorris  Offline OP
Hi Guys,
The carb kit i have recommends the body and the alloy adapter should be 1/16" clear to prevent 'Frothing'.(And keep them from rattling)
I'm planning on using a fat O-ring to separate the two.
Good idea?
Bad idea?
I have replaced the rubber connector from radiator hose to an auto gas filler hose- much stiffer and should wear better.
Original hose cracked after one year's use.
All info welcome
1978 Bonneville T140V PX
Re: Mikuni Carbs and Manifold Adapter [Re: JBMorris] #274932
09/16/09 11:20 pm
09/16/09 11:20 pm
Mark Z Offline
Mark Z  Offline
I've never had a problem with rattling, and I just shove 'em together. I think when you tighten the hose clamps, the hose pushes them apart just a bit. Or the hose is so stiff that it prevents any movement.
I figure that little space can't be good for fuel flow - the original couplers (from MAP) were "stepped" on the inside to fill the gap. But, they were way soft and only lasted a couple of months. Yeah maybe an o-ring or a rubber washer, but it better be neoprene or Viton.
Yeah fuel filler hose - that's the stuff!
