kllrjo
kllrjo
sunny tampa fla
35 registered members (AML), 274 guests, and 409 spiders.
10294 Registered Users
Stuart 99
Lannis 68
Mori55 67
639,578 mail-order LSR
Topics67,412
Posts654,559
Members10,294
Sweetening the exhaust note #263583
07/08/09 3:06 am
07/08/09 3:06 am
Florida
F
Florida TR6 Offline OP
F
Florida
In the wonderful book Big Sid's Vincati, there's the following comment (page 256) regarding the great Vincent tuner Sid Biberman using a trick he learned from Denis Manning (BUB company):
Sid told Denis that he still used an old trick of his - pouring a can of classic Coke down the muffler to sweeten the exhaust note
1. Anyone ever tried this for a vertical twin stock or repo muffler and what was the result (mellower sound, no change, negative results, a sticky mess)?
2. Regardless, a Mr. Wizard question: how the heck can pouring Coke through a muffler alter the exhaust note -- seemingly, though not so stated in the book, the change in exhaust note is not short-lived or SId and Denis wouldn't bother to do it??
"For every problem, there is a solution that is simple, neat, and wrong." H.L.MENCKEN
'06 T100 Bonneville
'70 TR6 Bitsa, Pazon EI
Re: Sweetening the exhaust note [Re: Florida TR6] #263609
07/08/09 8:41 am
07/08/09 8:41 am
Try this in the evening of March the 31st, leave overnight and start the bike the next morning... grin
Re: Sweetening the exhaust note [Re: Ger B] #263879
07/09/09 6:45 pm
07/09/09 6:45 pm
US citizen in Lisbon, Portugal
snowbeard Offline
snowbeard  Offline
I think someone's having you on there. it could be a joke, like putting that NOS energy drink in your gas tank. (don't do this either)
it could be something along the lines of eating out the packing a bit, coke is an acid, and might break down the steel wool type packing?
maybe the sugar blocks up some of the spaces? or maybe it just gurgles in there until it dries?
whatever it is, I certainly don't plan on trying it, but let us know how it went, eh? wink
/1957 BSA A10 Spitfire Scrambler (in a friend's shed)
/1960 BSA Super Rocket Basket Case (in the attic!)
/1987 BMW K100LT nekkid
Re: Sweetening the exhaust note [Re: snowbeard] #263907
07/09/09 9:58 pm
07/09/09 9:58 pm
White Rock, BC
R Model Tony Offline
White Rock, BC
Classic Coke should only be poured into RUM. Unless it's aged rum, in which case the rum should be poured into ice ;-). Tony
Re: Sweetening the exhaust note [Re: R Model Tony] #263914
07/09/09 10:18 pm
07/09/09 10:18 pm
Maybe it was supposed to sweeten the SMELL of your exhaust? Do you think I'm KIDDING?
Re: Sweetening the exhaust note [Re: Ger B] #263967
07/10/09 9:49 am
07/10/09 9:49 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
I understood Ger, and thought it quite witty.
1969 TR6R
Re: Sweetening the exhaust note [Re: Tiger] #263978
07/10/09 12:35 pm
07/10/09 12:35 pm
Listen very carefully I shall say zis only one more time: Aged rums as aged single malts are not poured onto ice.
They are carefully poured into crystal, slowly so no air enters.
Than, and only than, one small teaspoon of fresh well water is added with either a silver or an ivory spoon, and allowed to disperge on it's own force. whisky whisky whisky
Ice... grumble grumble...
I understood Ger,
I think you were the only one so far laughing
Re: Sweetening the exhaust note [Re: Ger B] #264018
07/10/09 5:13 pm
07/10/09 5:13 pm
White Rock, BC
White Rock, BC
"Ice... grumble grumble..."
Geeze Ger...I was trying to be witty...
Guess it didn't work ;-)
Last night my sip of Moorleys went directly into a shot glass, (no crystal) and then slowly across my tongue. The only thing I put ice in is a martini shaker. :-)
I think the best way to "sweeten" the exhaust note is to add a little Castrol R to the fuel. Unfortunately YOU can't smell it...only those riding behind.
Sorry for hijacking the thread guys...
Tony
Re: Sweetening the exhaust note [Re: R Model Tony] #264022
07/10/09 5:35 pm
07/10/09 5:35 pm
So was I... Guess it didn't work laughing
Re: Sweetening the exhaust note [Re: Ger B] #264075
07/11/09 2:36 am
07/11/09 2:36 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Last week I was given a sealed 1L bottle of "Castrol A747" which is apparently a castor/synthetic high performance two stroke lubricant.
To be run at 50:1 in water cooled engines that operate at 12-13,000 RPM and between 16-25:1 in engines that run between 12-18,000RPM.
Very tempted to try 200:1 in the tank of the TR6.
1969 TR6R
Re: Sweetening the exhaust note [Re: Tiger] #271640
08/23/09 2:39 pm
08/23/09 2:39 pm
USA
Tigerguy Offline
Tigerguy  Offline
USA
This reminds me of another little known racer trick from back in the day; strip your bike down to the bare frame and immerse it in a bath of Diet Coke for a month. It will be several pounds lighter afterwards, giving you a competitive advantage. Judges and race stewards will be oblivious, who weighs a frame? Note that this only works with Diet Coke, if you use regular Coke by mistake the frame will become heavier. You have been warned.
I once cut a piece of Swiss cheese to the exact size of my rear sprocket. I then laid the cheese on the sprocket and poured Diet Coke in the holes. The cheese resisted the Diet Coke but the holes were neatly eaten through the sprocket - a perfect lightening job without using a drill press!
Re: Sweetening the exhaust note [Re: Tigerguy] #271746
08/24/09 12:50 am
08/24/09 12:50 am
Camden NJ USA
Bob~NJ Offline
Bob~NJ  Offline
Camden NJ USA
Hi all,
Just to keep the thread on the technical side of things it has to be kept in mind that a can of Coke will sink in water but a can of Diet Coke will float.
Cheers~Bob
A65LB
Re: Sweetening the exhaust note [Re: Bob~NJ] #271780
08/24/09 12:00 pm
08/24/09 12:00 pm
melbourne, australia
7
76degree-triumph Offline
Evigee, A good egg sinks and a rotten or shabby one floats. Is this your way of saying leaded Coke with sugar is better than Diet/Zero with no sugar, but now with calorie free untested chemicals? I stick to the leaded version, sugar cain must be better than flavour enhancer 100-999.
P.S I have tried to disolve a tooth in coke (my son's whilst asleep waiting for the tooth fairy)over night and it appeared as normal the next morning. So I came to the conclusion that either Coke does not rot teeth or the tooth fairy is a lie.
Please be gentle on me as I've been good all year and waiting for Christmas.
Cheers, Chris.
1950 Speed Twin outfit
1951 Thunderbird outfit (76 degree racebike, or is it 90 deg now?)
1955 BSA D3 minibike outfit
Triumph solo's
Re: Sweetening the exhaust note [Re: 76degree-triumph] #271795
08/24/09 3:52 pm
08/24/09 3:52 pm
British Columbia
hh Offline
hh  Offline
British Columbia
All Coke is poison and it definitely eats teeth. An overnight test without careful weighing won't demonstrate this however. Read this:
http://news.softpedia.com/news/Cola-Destroys-Your-Teeth-50000.shtml
Regarding diet vs. "regular" sugar Coke: diet contains a synthetic neurotoxin, aspartame; regular Coke contains high fructose corn syrup which causes diabetes and obesity and also contains the neurotoxin mercury. And if that weren't enough, it's mostly from genetically modifed corn which has been shown to disturb normal human metabolism and immune function and will likely be shown to be much worse than originally believed as actual test results on humans are studied in the future.
So as the saying goes: choose your poison, or not (my choice.)
Re: Sweetening the exhaust note [Re: hh] #271813
08/24/09 5:28 pm
08/24/09 5:28 pm
Western Oregon
enigmaT120 Offline
enigmaT120  Offline
Western Oregon
At our Costco I noticed they sell cases of Coke made in Mexico. The ingredients list showed cane sugar instead of the corn syrup. I still didn't buy it, 'cause I had no rum.
I like beer better than I do Coke.
Ed
1970 Bonneville
Re: Sweetening the exhaust note [Re: enigmaT120] #271816
08/24/09 5:47 pm
08/24/09 5:47 pm
British Columbia
hh Offline
hh  Offline
British Columbia
Here's a 2004 story about the Mexican Coke:
http://www.signonsandiego.com/uniontrib/20041109/news_1b9mexcoke.html
Interesting that it's making it all the way to Oregon now. With a pH of 2.5 (similar to regular table vinegar), compared to battery acid at 1, I still wouldn't recommend it for human consumption in beverage quantities regardless of the sweetener.
Re: Sweetening the exhaust note [Re: Florida TR6] #271860
08/24/09 10:45 pm
08/24/09 10:45 pm
Houston Texas
Britbodger R.I.P. Offline
Houston Texas
Dunno about the Coke thing but, IMHO, the absorption type mufflers have a much sweeter sound than do the baffled type the latter sounding kinda harsh whereas the former have a throatier sound.
Dry frame Triumphs came stock with absorption type (made by Burgess I think). Not sure about later model Triumphs.
My 2c
